OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Oct 29, 2012 at 10:33 AM
    #801
    BlueJay
    BlueJay Well-Known Member
    Jayson
    Las Vegas
    '11 Sport 4x4 Speedway Blue
    Yellow-Wire Mod, Any-time backup camera, Bilstein 5100's @ .85, Rear TSB Springs, FX-R Projectors
    ECGS puller is sold.
    Not sure if its any different with the 2013's but in my opinion a $60 fix isn't much to hassle with. Especially if your going to be lifting it at the same time, kill two birds with one stone. You'll wanna make sure that the 2013s have the same issue before spending the $60 though, that is something i cant verify for you.
  2. Oct 29, 2012 at 10:37 AM
    #802
    Mountaincanuck
    Mountaincanuck Member
    Brodie
    Canmore, Alberta, Canada
    09 Access Cab 2.7 4x4
    -2009 access cab 2.7 4x4
    -5100 at 1.75
    -100,000 KM
    -vibration after installing lift, went away when engaged in 4x4
    -Installed ECGS solid bushing, smooth as butter!
    :D
  3. Oct 29, 2012 at 2:49 PM
    #803
    Defined
    Defined Well-Known Member
    mike
    southern california
    i've put up with this vibration for 100k miles too long. i was very apprehensive to switch over to a solid bearing, but after talking to Chase at ecgs i grew a little more confident about the replacement part.
    the bronze bushing is tight clearance wise and has the appropriate clearance even if the cv shaft got up to 400+ degrees. the stock needle bearing has a little over .020" of play, one could instantly realize that this is where the problem is....
    it was a breeze to install and it instantly took the vibration away. after a couple hundred miles all still seems well and i am very satisfied with the product up to this point.
    if your in the socal area i can do installs if your not confident doing it yourself
    thank you ECGS for your creativity and ingenuity......
    -mike with defined engineering
  4. Oct 30, 2012 at 9:36 AM
    #804
    BlueJay
    Jayson
    Las Vegas
    Still have ECGS puller available if anyone needs it.
    I have about 500 miles on the new bushing now and still puts a smile on my face while driving. Only now, i dont have the vibe that tells me when im doing speed limit lol
  5. Oct 30, 2012 at 10:28 AM
    #805
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    Actually it is a $220 fix plus tax and labor.I still haven't decided.I'm thinking about waiting til tax time and buy one.This way I can go ahead and buy an air actuated locker.
  6. Oct 30, 2012 at 8:27 PM
    #806
    Nater
    Nater Active Member
    Nate
    Vernal, UT
    '10 Sport Access Cab
    Bestop, custom storage in bed, many more to come she's only two months old!
    Well after having the entire front diff and drivers cv replaced twice under warranty only to have the bearing fail again (23,000 miles), I got frustrated and traded her in. Gonna miss the Tacoma, but the new Power Wagon is making the transition easier. :)
  7. Oct 31, 2012 at 5:47 PM
    #807
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    Hey guys , i'm gettin pretty frustrated with the front end of this truck. About six months ago I started to notice a whirrrr whhirrr whirrrr sound\slight vibration when Im doin between 40-60 km/hr in 3rd gear. I changed both front wheel bearings, no difference. It wasnt there when i first put the ome lift in and still had stock ucas and shitty dunlop tires. So i bought the bushing a few weeks ago but havent put it in yet and today i threw her in 4hi, and it didnt go away. not sure what to do now, maybe try rotating my tires, I always grease my ujoints and have redline fluids in everything. Any ideas
  8. Oct 31, 2012 at 6:57 PM
    #808
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Do your CV's look ok? Alignment ok? Try rotating tires.
  9. Nov 4, 2012 at 1:31 PM
    #809
    kieth
    06 trd
    my cv's seem fine, i rotated the front cvs during the reinstall of my wheel bearings, everything seems fine. I am going to rotate my tires and retorque my axle nuts and have a good look at everything. how can you tell if a front u-joint is bad. Im also just gonna put the bushing in, fuck it.
  10. Nov 10, 2012 at 5:52 PM
    #810
    BenWA
    Boston burbs
    Finally got the ECGS bushing in my front diff, along with a new wheel bearing and CV half shaft. SO much better, holy #$%&. I can't belive I lived with those vibes for as long as I did. The truck drives like new, with 140+K miles now. Many thanks to Chase and ECGS for this fix.
    Overall, the fix took about 5 hours which includes pressing a new wheel bearing. The ECGS bushing was a breeze to install, once the CV was removed.
    The bushing seriously makes alllllll the difference in the world! :thumbsup:
  11. Nov 10, 2012 at 8:59 PM
    #811
    Taco'09
    Taco'09 Well-Known Member
    ^^ This fix may have not come about without the efforts of BenWA the OP, who began this giant thread, 05Moose and others who were in there trying to do the initial fix, tim allen who brought this to the attention of ECGS, Chase at ECGS who took the matter seriously to design and produce the bushing, and all the rest throughout this thread who contributed with pictures, observations, etc. etc.
    My hat goes off to all of you! I will never meet most but in the end I too have a front diff. CV joint bearing that I can live with. :)
  12. Nov 10, 2012 at 9:09 PM
    #812
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    X10000000000000
  13. Nov 11, 2012 at 9:03 AM
    #813
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I have 10k now on the ECGS bushing and still smooth as glass.
    Thanks for this thread and for the fix from ECGS.
  14. Nov 11, 2012 at 11:37 AM
    #814
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Thanks guys for the mention.
  15. Nov 16, 2012 at 12:02 AM
    #815
    Teeps1206
    Teeps1206 Well-Known Member
    Omaha, NE
    '12 DCSB MGM Off Road 4x4
    Roof Rack Rear step (not my choice)
    Never saw this reply. Very good point!
  16. Nov 16, 2012 at 7:12 PM
    #816
    Yotabilly
    The Bluegrass
    Is there any kind of mild lift that doesn't cause this?
  17. Nov 17, 2012 at 4:03 AM
    #817
    Dewey7015
    Dewey7015 Well-Known Member
    Massachusetts, USA
    2018 TRD sport
    Hey Guys,
    Same old story here...I get a vib when I am doing 60+.. Goes away when I coast under 60, or am in any gear, and coast under 60mph.
    I am going to replace both wheel bearings and buy the bushing from Chase.
    Will I need an alignment after installing the bushing?
    thanks,
    And If anyone is close to cape cod MA, and wants to help.. Beer and striper filets are on me!
    thanks again
    Dewey
  18. Nov 17, 2012 at 6:03 AM
    #818
    NiceTaco
    NiceTaco Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    I just spent an early Saturday morning reading this thread and am now scared to lift my truck!!!! I have a 12 and I already have some driveline vibe brought to dealer who said its the first time he has heard of it. He did do some research and said he does see a lot of complaints online but he couldn't feel it when he drove it. They did put a note on my account that I complained about it. I think this is a stock problem that gets elevated with a lift... F$&@in Toyota. Now my concern is when I lift it they will just blame the lift. It's not bad now almost intermittent I guess I will see if it gets worse.
    FML!
  19. Nov 17, 2012 at 1:42 PM
    #819
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    when the vibe starts..
    #1 change the bushing
    #2 the end..
  20. Nov 17, 2012 at 2:27 PM
    #820
    thegreatwall23
    thegreatwall23 Well-Known Member
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Armor Shrockworks front bumber Shrockworks Rock Sliders Brute Force Rear Bumper XRC8 with synthetic rope Relentless Full Skid Pack Suspension Icons 2.5 extended travel all around with King 14" 700# Springs Icon Tubular UCA's All Pro Standard Leaf Pack 3 degree axle shims Wheelers front bumpstop U bolt flip kit Timbren rear bumpstop Mods rear diff breather fog light anytime ABS Disable TPMS disable Door Chime disable Seat Belt Chime Disable Cab Mount Chop Pinch Weld Mod BHLM Other 4.56 Nitro gears FX-R Retrofit HID's with Halos PIAA fogs and driving lights Wet Okole seat covers Weather-Tech floormats Access LiteRider bed cover AMP bed extender Viair 450P-A Rocky Clutch SD mounts Pop-n-lock tailgate lock Aux rear lights Rear sliding window security bar B.A.M.F Light Bar Ultragauge 48" Hi Lift Jack with Bed Rail Mount Bushwacker Fender Flares ECGS PTFE Bushing SS Brake Lines Brembo Blanks Hawk HPS In cab winch control (12voltguy) Tint
    Keep us updated on this. It's driving me nuts and I have to figure this out. I have the same thing going on... 2009, I hear it and feel it the worst right at 70 mph, it doesn't go away in 4X4. I do have some play in my cv. I had a mechanic look at my wheel bearings and he said they were fine, but he just "tested" them, he didn't take anything apart and look at it. I might just replace the wheel bearings just because. I ordered the part from ecgs, but don't have wheel bearings. I will post any updates as well.
