OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Nov 17, 2012 at 5:48 PM
    #821
    Dewey7015
    Dewey7015 Well-Known Member
    Massachusetts, USA
    2018 TRD sport
    Absolutley! I figure i will replace the bearings and the bushing..I have no play in the wheels when I jack them up..
  2. Nov 17, 2012 at 5:55 PM
    #822
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    I have a toyota dealership in the area that will put in parts that I bring them. They gave me the whole "this will void your warranty" speech.. I just laughed. just turned 71,000 miles, and I have to replace wheel bearings, and a crap bearing coming out of the diff... wonder if they will make me pay the tech to sit down and watch the video on how to use the bearing removal tool from Chase? Forgot to re-ask you guys...will I need an alignment after this work?
  3. Nov 17, 2012 at 7:38 PM
    #823
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    No alignment needed.
  4. Nov 17, 2012 at 7:44 PM
    #824
    thegreatwall23
    thegreatwall23 Well-Known Member
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Armor Shrockworks front bumber Shrockworks Rock Sliders Brute Force Rear Bumper XRC8 with synthetic rope Relentless Full Skid Pack Suspension Icons 2.5 extended travel all around with King 14" 700# Springs Icon Tubular UCA's All Pro Standard Leaf Pack 3 degree axle shims Wheelers front bumpstop U bolt flip kit Timbren rear bumpstop Mods rear diff breather fog light anytime ABS Disable TPMS disable Door Chime disable Seat Belt Chime Disable Cab Mount Chop Pinch Weld Mod BHLM Other 4.56 Nitro gears FX-R Retrofit HID's with Halos PIAA fogs and driving lights Wet Okole seat covers Weather-Tech floormats Access LiteRider bed cover AMP bed extender Viair 450P-A Rocky Clutch SD mounts Pop-n-lock tailgate lock Aux rear lights Rear sliding window security bar B.A.M.F Light Bar Ultragauge 48" Hi Lift Jack with Bed Rail Mount Bushwacker Fender Flares ECGS PTFE Bushing SS Brake Lines Brembo Blanks Hawk HPS In cab winch control (12voltguy) Tint
    Cool, good luck! I hope it works, because we sound like we have the exact same problem! I have no play in my wheels either and noise doesn't stop when turning one way either. I am starting to think it may be the wheel bearings even though the mechanic said they were fine.
  5. Nov 17, 2012 at 7:48 PM
    #825
    thegreatwall23
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Also, like he said, no alignment needed. I have heard, I have never had experience with it, but your wheel bearings can wear oddly to were the wheel won't have play, but when you actually spin the wheel you get a small hang or noise while spinning. But that would make me think it would make the noise no matter what speed.
  6. Nov 17, 2012 at 8:24 PM
    #826
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Only time you would need to align is when you change the way the vehicle sits(lift or drop), or you hit a curb too hard and knock the alignment out. The wheel bearings don't necessarily have any play in them if they are bad. I just checked mine for play, none, but when I spin the wheels, I hear a loud, what seems like break drag, noise on the driver side, and passenger side is much quieter. So I said eff it and replace both sides. I pull the driver side bearing apart, and it was toast, again, zero play in the wheel. The passenger side bearings were nice and shiny compared to the driver side, which was black and brown tinge on the race and bearings. Pretty quick n easy job if you got the right tools.
  7. Nov 18, 2012 at 4:09 AM
    #827
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    I agree, I was thinking of trying a floor jack, bench vise, and a piece of rebar from the part to the ceiling joist in the garage... Or just pay napa $20. :)
  8. Nov 18, 2012 at 1:43 PM
    #828
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    Hey I just have a question for you guys who have seen the bearing removal tool.How thick is the material of the piece on the end of the puller that goes in behind the bearing to pull it out. Im just in the process of making one , was gonna use 1\8 thick aluminum, thats not too thick is it?
  9. Nov 18, 2012 at 7:34 PM
    #829
    Taco'09
    Taco'09 Well-Known Member
    ^^ My advice to you is give up early on trying to make the insert part of the tool, the part that reaches on the backside of the needle bearing, out of aluminum. I have pulled two of the needle bearings now using the ECGS tool. Their tool is made of pretty tough steel. Even with the ECGS tool I ended up bending the ears on the tool because one of the needle bearings was in so tight.
  10. Nov 18, 2012 at 8:22 PM
    #830
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Same here, my puller has been used and abused. Even with the end being steel, it broke. Aluminum that thin will just bend and be worthless. But, easiest way to make the tool end with the right dimensions is to get the bushing and measure for yourself so you have a solid reference.
  11. Nov 19, 2012 at 4:16 PM
    #831
    kieth
    06 trd
    i have the bushing and can make the piece the right size OD, i now realize aluminum is a shitty idea and im gonna use steel, my question is the thickness. is the ECG tool made from 1\8 steel plate,im worried about the thickness. thanks, im in canada and i cant get the tool in time, want to do it this weekend in my buddies shop on his lift.
  12. Nov 19, 2012 at 7:52 PM
    #832
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    total thickness looks like 1/4" and the ears look like 1/8"
  13. Nov 20, 2012 at 3:46 PM
    #833
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    vibe here too right around 40 km drivers side diff bearing has a fair bit of play i have 2.25 spacer with diff drop and 22 000 kms on the truck 2012 dc lb 4x4
  14. Nov 21, 2012 at 4:25 AM
    #834
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    Has anyone had the diff output bearing go, on a non-lifted truck? Maybe I should just start with the bearings.. Doesn't go away in 4 hi... Hmmm
  15. Nov 21, 2012 at 9:03 AM
    #835
    05Moose
    Jim
    If it doesn't go away in 4Hi, then it isn't the front diff.
  16. Nov 21, 2012 at 10:06 AM
    #836
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
  17. Nov 23, 2012 at 5:54 AM
    #837
    racemybuick
    racemybuick Well-Known Member
    Hopatcong, NJ
    07 Tacoma SR5 lots of goodies finally
    K&N filters, 3" front lift toytec, aal with spacer in rear, bull bar, 4" tube steps, ecgs bushing successful!
    Just shake the cv shaft... If it shakes at the diff, guess what, it's the diff.
    My truck is a bone stock sr5 with 110k miles. I bought the Toyota gold extended warranty thinking I was covered to 125k. Turns out the mileage was limited... A year ago, they told me nothing was wrong with my truck. I bring it back 2 weeks ago, they say I need a new diff... Exact same sound from a year ago, only this time, I'm out of my warranty!!!
    It's the bearing. My truck makes the noise no matter what gear or 4wheel pattern I'm in. I can shake the cv shaft up and down almost 1/4 inch at the diff. Wheel bearings check out fine, cv shafts are in good shape.
    Going to swap out for bushing soon...
  18. Nov 23, 2012 at 9:34 AM
    #838
    05Moose
    Jim
    You're the first person (I think) in the last few years that had the problem even in 4hi. Good to know.
  19. Nov 28, 2012 at 8:59 PM
    #839
    wareagle1
    wareagle1 Well-Known Member
    Brad
    Fayetteville, TN
    07 Tundra DC 5.7
    notta
    I was really hoping I wouldn't encounter any of these problems when I finally did my lift. Should've known better. Got the vibes everyone else has been living with. ECGS bushing, here I come! Anyone know if this also gets rid of the steering wheel shake at 50-60 mph? Also, I need a puller if anyone has one. Thanks
  20. Nov 28, 2012 at 10:25 PM
    #840
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I just dropped mine off at dealer today. Carrier cut loose and took front drivers driveshaft with it. Still have 3000 miles left on warranty.
