OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Dec 21, 2012 at 3:56 AM
    #861
    ECGS
    ECGS Well-Known Member
    Chase
    RALEIGH
    Tech Note: When Doing the Needle bearing Removal / Bushing install, Go drive the vehicle for 15 minutes and warm the diff up. The heat expansion makes the Needle bearing come out much smoother. Have a plan and have your needed tools ready for removal.
  2. Dec 21, 2012 at 3:52 PM
    #862
    Draht
    Draht Member
    Utah
    06 TRD Off Road
    3" lift
    Truck is all tore apart just waiting for bushing to arrive.... Up to this point it has went very smooth!!!! However I did notice the gear oil that leaked out of the front diff is pretty dark??? Is this normal??? I just noticed on some of the posted videos the oil that comes out look really clean/ clear?
  3. Dec 21, 2012 at 4:08 PM
    #863
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    Noticed a leaking CV boot on the driver side while doing my oil change the other day. I figure I should change out the bearing for the bushing at the same time I replace it.
    Anyone have the removal tool for sale or rent?
    I gotta wait till after Christmas to do all this, broke for the time being:(. Hope things will stay together for a couple weeks.:notsure:
  4. Dec 21, 2012 at 4:35 PM
    #864
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    Used gear oil is dark, fresher oil is what you saw on the video. Sounds like a perfect time for you to change it. No worries unless chunks of metal come out when you drain the oil. :)
  5. Dec 21, 2012 at 6:12 PM
    #865
    Draht
    Draht Member
    Utah
    06 TRD Off Road
    3" lift
    Thanks! I figured this much just had to ask! Also I have a little bit of grease on the inside of the spindle?? Would that have come from the cv boot leaking? I didn't see any cracks or tears in the boot????
  6. Dec 21, 2012 at 6:14 PM
    #866
    Draht
    Draht Member
    Utah
    06 TRD Off Road
    3" lift
    I will have a tool here in few days I would sale you. Let me know if your interested.
  7. Dec 21, 2012 at 6:31 PM
    #867
    P9HST2
    Iowa
    2012 MGM AC TRD OR
    I'm not sure what you're describing. Maybe a bad seal where the outer CV shaft goes into the steering knuckle? Got a pic?
    Disclaimer - I've worked on lots of 3/4 ton 4WD vehicles but never tore this apart on any IFS, especially a Tacoma. ;)
  8. Dec 21, 2012 at 6:38 PM
    #868
    Draht
    Draht Member
    Utah
    06 TRD Off Road
    3" lift
    I'm currently at work so I don't have a pic. It is where th cv goes through the steering knuckle, where does the grease com from? And I have read that those seals are hard to find?
  9. Dec 21, 2012 at 6:45 PM
    #869
    P9HST2
    Iowa
    2012 MGM AC TRD OR
    Hard to say where it's coming from. Sounds like it pretty much has to be from the CV boot or the wheel bearing area. A pic would help, we're just kind of guessing right now. Any seals and other parts should be easy to get, we're not working on an antique. :)
  10. Dec 21, 2012 at 6:59 PM
    #870
    Draht
    Draht Member
    Utah
    06 TRD Off Road
    3" lift
    Its a sealed bearing so i wouldnt think it would come from the bearing unless it was shot and from what I can see the bearing looks good! thanks for your help.:) I hope I can get the bugs worked out of this truck! only owned it a couple weeks and have put alot of time and money into it and have only put maybe 100 miles on!!! thats just my good luck.....
  11. Dec 23, 2012 at 3:43 PM
    #871
    Draht
    Draht Member
    Utah
    06 TRD Off Road
    3" lift
    I spoke to soon...... Mushroomed the bushing while trying to get it in..... Another $75 bucks hope it gets here soon? Any tips on getting it in? I put it in the freezer for a couple hours prior to attempting to install and soaked it in oil. Any tips or advice would be greatly appreciated!!!! Merry Christmas to all!!!
  12. Dec 24, 2012 at 9:52 AM
    #872
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    that's a hopeless feeling :cringe:
    just get it started with light taps, make sure it's going in straight then send it home. easier said than done but just take your time.
  13. Dec 26, 2012 at 7:47 AM
    #873
    thegreatwall23
    thegreatwall23 Well-Known Member
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Armor Shrockworks front bumber Shrockworks Rock Sliders Brute Force Rear Bumper XRC8 with synthetic rope Relentless Full Skid Pack Suspension Icons 2.5 extended travel all around with King 14" 700# Springs Icon Tubular UCA's All Pro Standard Leaf Pack 3 degree axle shims Wheelers front bumpstop U bolt flip kit Timbren rear bumpstop Mods rear diff breather fog light anytime ABS Disable TPMS disable Door Chime disable Seat Belt Chime Disable Cab Mount Chop Pinch Weld Mod BHLM Other 4.56 Nitro gears FX-R Retrofit HID's with Halos PIAA fogs and driving lights Wet Okole seat covers Weather-Tech floormats Access LiteRider bed cover AMP bed extender Viair 450P-A Rocky Clutch SD mounts Pop-n-lock tailgate lock Aux rear lights Rear sliding window security bar B.A.M.F Light Bar Ultragauge 48" Hi Lift Jack with Bed Rail Mount Bushwacker Fender Flares ECGS PTFE Bushing SS Brake Lines Brembo Blanks Hawk HPS In cab winch control (12voltguy) Tint
    I just wanted to give everyone an update on this... I have a 2009 TRD OR double cab. I had a terrible noise between 67-73. I did NOT go away in 4x4. I went ahead and replaced the bushing while installing my 4.56 gears and the noise is gone! I am so happy. Thanks ECGS. So anyone out there with the same issue and it doesn't go away in 4x4, doesn't mean that isn't the problem. I guess for some people it went away, but not in my case.
  14. Dec 26, 2012 at 12:19 PM
    #874
    nj636
    Kev
    Jersey
    i had a similar issue, replaced the bushing and then a week later i did the wheel bearings/hubs.. it was the hubs making noise.
    peace of mind knowing the bushing has been replaced
    .02
    *edit* just to clarify: wheel bearings/hub assembly making noise
  15. Jan 1, 2013 at 8:12 PM
    #875
    Carmaniac
    Carmaniac Member
    Tim
    Cheyenne, WY
    06 Double Cab TRD OR
    OME ARB Bumper Warn Winch Topper Duratracs 3-kid Mod
    Anyone around the front range in Colorado or norhtern Wyoming have a tool they can lend/rent? I live in Cheyenne, but travel down to Denver and Colorado Springs frequently and I'm looking to install this bushing. Thanks!
    Tim
  16. Jan 2, 2013 at 9:10 PM
    #876
    Shinshi
    Shinshi Member
    Calgary, Alberta
    2012 Toyota Tacoma DC SB
    Installed the bushing from ECGS yesterday in my 2012. Only 6000 miles, but with a 3" lift, was getting the vibration. Knowing it would only get worse and if the bearing failed, could do further damage, I changed it out for the bushing. Test drive yesterday and driving to work today, absolutely no vibration. Very happy with the results! :)
    If anyone in Calgary, Alberta wants to borrow the tools, send me a message.
  17. Jan 4, 2013 at 3:00 PM
    #877
    cdub105
    cdub105 Active Member
    Florida
    05 Tacoma Access Cab 4x4
    I'm in between Longmont and Louisville and have the tool.
  18. Jan 4, 2013 at 3:53 PM
    #878
    cdub105
    Florida
    Well guys, I had the same problem and no shop could figure it out. Bought the bearing from ECGS installed it and just recently drove from Virginia to Colorado with no issues. Highly recommend it and way cheaper than a new differential. Thanks for all the post from everyone who did this.
  19. Jan 4, 2013 at 4:01 PM
    #879
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    Is everybody simply reusing the circlip on the inboard end of the driveshaft? Or, is a new circlip the better option when reinstalling?
  20. Jan 4, 2013 at 4:36 PM
    #880
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    Ok, I'm trying to get some opinions on my vibration symptoms detailed below. Can you guys please tell me what you think it might be? My new 2013 has a slight vibration in the gas peddle that occurs only at exactly 2k rpm, no matter what gear or drive I'm in. Do you guys think it could be this bearing?
    When the truck is cold it's worse then when it's warmed up and driven for a while. It's also worse in lower gears than in higher gears. I don't really notice it change much when going into 4HI and back though.
    Out of all the posts on this site about vibrations, I haven't seen anyone ever mention it being related to a specific rpm, just mph ranges. Mine occurs at all different mph (depending on what gear I'm in). It's completely related to my rpms. As soon as the top of the rpm needle hits the bottom of the 2k line vib starts, when the bottom of the rpm needle clears the 2k line vib goes away.
