OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Jan 4, 2013 at 4:48 PM
    #881
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    That statement alone says that the vibe you're experiencing is not the vibe in this thread.
  2. Jan 4, 2013 at 4:55 PM
    #882
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    How do you explain the post below on page 44 of this thread then?
    I'll add that it only happens when accelerating not decelerating through the 2k line. Anyone have any ideas on most likely causes?
    Quote:
    Originally Posted by racemybuick [​IMG]
    Just shake the cv shaft... If it shakes at the diff, guess what, it's the diff.
    My truck is a bone stock sr5 with 110k miles. I bought the Toyota gold extended warranty thinking I was covered to 125k. Turns out the mileage was limited... A year ago, they told me nothing was wrong with my truck. I bring it back 2 weeks ago, they say I need a new diff... Exact same sound from a year ago, only this time, I'm out of my warranty!!!
    It's the bearing. My truck makes the noise no matter what gear or 4wheel pattern I'm in. I can shake the cv shaft up and down almost 1/4 inch at the diff. Wheel bearings check out fine, cv shafts are in good shape.
    Going to swap out for bushing soon...
    You're the first person (I think) in the last few years that had the problem even in 4hi. Good to know.
  3. Jan 4, 2013 at 5:05 PM
    #883
    DR Da_da
    Alabama
    Then the vibe you're experiencing is the vibe described in this thread.
    Bump for my question below . . .
  4. Jan 4, 2013 at 5:14 PM
    #884
    Snowbrdr1220
    PA
    Well I don't know, and it doesn't sound like you do either. I did provide what I feel are more detailed symptoms then most have provided. So I'm hoping the combination of all these things I detailed in my last two posts might help someone narrow it down to only one or two possibilities. Anyone have any ideas?
    The increased vibration when the truck is cold compared to when it warms up (driven for a half hour or so) really throws for me a for a loop.
  5. Jan 4, 2013 at 5:40 PM
    #885
    DR Da_da
    Alabama
    You're right - I don't. But, for $100+/- (depending on if you get the bearing removal tool and a new oil seal as well) you might want to go ahead and knock it out just to eliminate this from the list of suspects. Plus, if you do decide to lift your truck, it's already taken care of. However, since your truck is under warranty you could push it all on the dealer and have them do all of the trouble-shooting to rule out other possibilities.
    For the increased vibe when cold issue, maybe it's due to no oil on the bearing after the truck has been parked for a period of time. Once you drive it a bit, the oil in the front differential flows to the bearing thereby lubing it and reducing the vibe? Just a guess. Either way, it sucks that you're experiencing this on a new, non-lifted truck. This isn't right, especially for a Toyota.
  6. Jan 4, 2013 at 6:01 PM
    #886
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I have a weird vibe/grind feel ans sound from my front end. But putting it ;hi doesnt get rid of the sound and feel. So im not sure if it is the diff bearing... I will most likely change it out for the ECGS bushing anyways, just to be safe..
    I had the bad bearing in my 07 that the dealer replaced. But for my new truck im not sure if its the bearing or just the tires im hearing/ feeling..
  7. Jan 4, 2013 at 6:02 PM
    #887
    Taco'09
    Taco'09 Well-Known Member
    The FSM says the snap ring is a non-reusable part. Some come out rather beat up. Getting them back in that way makes it more difficult. It is pretty common engineering practice to not reuse such things as clips, cotter pins, etc. Also, the FSM says to orient the snap ring on the half shaft with its opening pointed downward, and coat the splines of the shaft with ATF.
  8. Jan 4, 2013 at 6:25 PM
    #888
    DR Da_da
    Alabama
    Rock on - thank you very much!!! I'm doing this job tomorrow morning. I called the local dealer this evening to inquire about the clip . . . of course they don't have it. Once I remove it tomorrow I may get a friend to drive me to the local hardware store and try to find a match.
  9. Jan 4, 2013 at 7:38 PM
    #889
    Taco'09
    What! The stealer does not have a half shaft snap ring?
    Try this. Plan A: Help the stealer out a bit. Call them back and ask them if they have this part number: 43425-04040, Ring, Drive Shaft Snap. Plan B: Call an independent repair shop and ask them if they have one. Plan C: Be patient, wait until next week and order one or two. Plan D: Reuse the old one. I don't reuse them but frankly, I'm going to bet that, despite the fact that the FSM says it is not reusable, most people are reusing them, including the dealer.
    I would suggest you not waste any time looking at a general hardware store looking for a substitute. You are not going to find one and you will have a really, really bad day if you try to use something that breaks off inside the differential (Murphy's Law you know).
    Good luck.
  10. Jan 7, 2013 at 6:59 AM
    #890
    Skadumz
    Skadumz Well-Known Member
    Lehigh Valley, PA
    2008 tacoma dual cab, long bed, 4x4, TRD Spor
    3" lift 265/70/17 nitto, Grille Craft Grille, Tinted windows, 17x9 Moto Metals Matte Black, Carrier barring drop
    Here is my issue. I had the issue everyone has with vibe up front. Changed out needle bearing with the new bushing and changed CV axle at the same time no more issue. Then I Could not stop front seal from leaking. went through 5 seals some I replaced and some the dealer did. No visible difference or rips in any on the seals. Now the last one was done by the dealer and they replaced the cv with factory (the last was aftermarket due to price). and now it is leaking again. The only two things I can think of is either the front diff relief is clogged or I have a diff drop up front maybe it is making my front diff not centered, maybe alittle to the passenger side.
    Maybe anyone have some suggestions.
  11. Jan 7, 2013 at 7:20 AM
    #891
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    You can get it here http://www.toyotapartsales.com/part...make=Toyota&action=oePartSearch&siteid=214074
    That blows big time. Since the dealer did it last time take it back. Is it possible oil is getting around the outside of the seals or maybe the bushing is not pressed in flush?
  12. Jan 7, 2013 at 8:30 AM
    #892
    Taco'09
    Another person was reporting the same problem awhile back. I don't remember if the solution was ever posted. I agree with the previous comment, take it back to the dealer.
    Also, check the easy stuff first. The two lines that clip to the inside of your left fender well are both vent lines: the smaller vents the ADD actuator, and the larger the diff. The large line starts out on the right side of the diff. just above where the ADD tube bolts to the diff. It is a bit hard to see. Look for possible kinks or a place where line might be pinched. Make sure the cap on the top of the line is free to vent. Touch not the line coming off the ADD actuator itself, at the actuator, as it likes to break off just looking at it.
  13. Jan 8, 2013 at 2:24 AM
    #893
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    WTF Adam, you still dealing with that damn seal. Dealer replaced CV and seal with factory parts. Diff drop has nothing to do with it. I would rule out the bushing not being driven in far enough, that SOB is in there. The one thing that does make sense is a clogged breather. Pressure builds inside of that diff with no where to go, it's gotta relieve itself somewhere, and it picked that seal.
  14. Jan 9, 2013 at 7:07 AM
    #894
    Skadumz
    Lehigh Valley, PA
    Thanks for the thoughts. I checked the breather lines and saw no visible kinks. But how do you tell the breather cap deal on top is not clogged, or how do you remove the cap?
  15. Jan 9, 2013 at 10:16 AM
    #895
    Taco'09
    Just for you I went out and removed mine. It consists of a 14mm long crimped metal cap affair on top with a 5mm long plastic collar beneath the cap and a 20mm long black plastic tube piece below that which inserts into the hose. Inside it is a micro screen. It just twists/pulls off the end of the hose.
    If you blow into it there should be air coming out the metal cap, not a whole bunch, but a little at least. Don't try to blow air backwards down the hose into the differential without first removing the 10mm fill plug on the left side of the differential or you may end up with two more leaks...
    Good luck.
  16. Jan 14, 2013 at 7:48 AM
    #896
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    Any update on the 1st gen bearing?
  17. Jan 15, 2013 at 11:42 AM
    #897
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    does anyone have the tool for sale or rent?
    will pay shipping.
    I notice my vibration at complete stops at idle.
    Also is the axle CV seal the one closest to the Differential, where it slides in? if that makes sense. I think i have a leak right there, and hoping that will fix it.
  18. Jan 15, 2013 at 12:03 PM
    #898
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    IF you have a vibration at complete stop, at idle, it's not your CV that is the problem.
    Yes there is an axle seal at the diff where the axle inserts.
  19. Jan 15, 2013 at 12:40 PM
    #899
    lilgerber
    Aaron
    Fresno, CA
    I'm still thinking I should add the bushing, I just don't want to dish out the extra $60 when I know someone on owns it and not in use, and can share it. Please PM or reply if you can share your tool for a weekend.
  20. Jan 24, 2013 at 8:42 PM
    #900
    blmfirert
    blmfirert Member
    Gary
    Hood River,Oregon
    07 Tacoma V-6 Level Kit front only
    Front level kit
    Does anyone know who can put this bearing from east cost gear supply ,in for me, that is in Oregon. Sounds like there are several doing it themselves but not me. I don't have the place to do it.
