OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Feb 5, 2013 at 1:00 PM
    #941
    thegreatwall23
    thegreatwall23 Well-Known Member
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Armor Shrockworks front bumber Shrockworks Rock Sliders Brute Force Rear Bumper XRC8 with synthetic rope Relentless Full Skid Pack Suspension Icons 2.5 extended travel all around with King 14" 700# Springs Icon Tubular UCA's All Pro Standard Leaf Pack 3 degree axle shims Wheelers front bumpstop U bolt flip kit Timbren rear bumpstop Mods rear diff breather fog light anytime ABS Disable TPMS disable Door Chime disable Seat Belt Chime Disable Cab Mount Chop Pinch Weld Mod BHLM Other 4.56 Nitro gears FX-R Retrofit HID's with Halos PIAA fogs and driving lights Wet Okole seat covers Weather-Tech floormats Access LiteRider bed cover AMP bed extender Viair 450P-A Rocky Clutch SD mounts Pop-n-lock tailgate lock Aux rear lights Rear sliding window security bar B.A.M.F Light Bar Ultragauge 48" Hi Lift Jack with Bed Rail Mount Bushwacker Fender Flares ECGS PTFE Bushing SS Brake Lines Brembo Blanks Hawk HPS In cab winch control (12voltguy) Tint
    So, a little update... I jumped the gun on this statement. I drove it and didn't hear the noise, but it definitely was still there! The next couple of days after this, I noticed it. Not sure why I didn't hear it that day, but it was raining and section of interstate I was on was under construction. I took the wheel bearing out and same issue some others reported. The hub where the wheel bearings contact had a bad spot in it. Replaced it and no noise since! From reading around, this is very common on these trucks. Hopefully this will help someone in the future.
  2. Feb 5, 2013 at 1:14 PM
    #942
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    Which works out either way cause it calls to change the diffs and the t case at 30k I just rolled past 25k this morning
  3. Feb 5, 2013 at 1:15 PM
    #943
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    I did the same as you, same problem. I did the bushing first because the cv was very sloppy. still had the vibe but I had a sneaking suspicion from the start that it was the hubs. took the hubs off and they were shot, could feel the grinding while turning by hand. fresh hubs & it drives so dreamy now ha :woot:
  4. Feb 5, 2013 at 1:16 PM
    #944
    nj636
    Kev
    Jersey
    grab an extra quart and do the t-case :cool:
  5. Feb 5, 2013 at 2:21 PM
    #945
    Taco Guy11
    Joe
    Western Maryland
    You use the same oil in the t case that you use in the diffs?
  6. Feb 5, 2013 at 2:55 PM
    #946
    nj636
    Kev
    Jersey
    Lucas 75w90 front & rear diff's t-case & trans for me (manual)
  7. Feb 5, 2013 at 3:53 PM
    #947
    Taco Guy11
    Joe
    Western Maryland
    The guy at the Toyota garage told me 75/85 when I asked him on the phone last week?
  8. Feb 8, 2013 at 7:16 AM
    #948
    Taco Guy11
    Joe
    Western Maryland
    Just got the call from the shop they got my ecgs bushing in and they drained my diff and refilled it I went with 75:90 Mobil 1 diff fluid. They said the old stuff was pretty dirty
  9. Feb 8, 2013 at 11:31 AM
    #949
    Taco Guy11
    Joe
    Western Maryland
    So I'm surprised I didn't get screwed he changed the bushing and axle seal out and drained and changed out my differential fluid and charged me $80 for labor since I had all the parts.
  10. Feb 8, 2013 at 10:16 PM
    #950
    alpinebob
    alpinebob Well-Known Member
    bob
    alpine ca
    2008 Tacoma 4x4
    The more I read the more confused I am. It almost seems like Toyo does not really know what causes these "phantom" growls !
    My 2008 4wd, 6speed automatic began sounding a fairly high pitch "hum" in 2 wd at 47 mph. I had just installed Michelin LTX a couple of weeks earlier and thought maybe the tires were the problem so I had them rotated, no effect noted. The hum is loudest at 47 to 55 mph then it quiets but starts again at about 65 and quiets at 72 or so. I have tried 4wd at 45-50 mph the back to 2wd hum is constant, also shifted into neutral and even shut engine down , hum persists as long as speed is 45-50.
    Toyota says it is the "drive shaft" and will replace it for $1400 ! after reading the forum notes I will not spend any $ until I am very sure of the problem.
    Any help will be appreciated, mechanical or legal !!!
    Thanks, alpinebob
  11. Feb 9, 2013 at 4:50 AM
    #951
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    So when you put it in 4WD the vibe was gone? If so, you likely need to replace the needle bearing in the front diff. Using the ECGS bushing to replace the needle bearing seems to work well. I have about 25k miles on my ECGS bushing.
  12. Feb 9, 2013 at 6:26 AM
    #952
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    To be honest, your description does not sound like the front diff bearing. The vibe is more felt than heard until it gets really bad. And when it starts out, you won't be able to feel it upwards of 60 mph.
  13. Feb 9, 2013 at 7:37 AM
    #953
    Taco Guy11
    Joe
    Western Maryland
    Did your guys needle bearings look bad when you removed then mine shows basically no wear?
  14. Feb 9, 2013 at 11:19 AM
    #954
    EEKANOUSE
    EEKANOUSE Well-Known Member
    will
    PA
    2010 standard cab 4x4
    3" lift, Goodyear 265/75 duratrac, wet okole seat covers, are cap, safari springs rear.
    The needle bearings were fine the noise is caused by too much slop where the shaft inputs the bushing tightens up this tolerance thus removing the dreaded noise
  15. Feb 9, 2013 at 11:22 AM
    #955
    EEKANOUSE
    will
    PA
    Mine was doing same thing needle bearing just do it and save receipts if Toyota ever fesses up to their blunder
  16. Feb 9, 2013 at 11:23 AM
    #956
    EEKANOUSE
    will
    PA
    Above is reply to alpine bob
  17. Feb 9, 2013 at 11:32 AM
    #957
    ms4x4outlaws
    ms4x4outlaws Well-Known Member
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    Do you mean the wheel bearing??? Please let me know. I just changed the wheel bearing and I didn't get to inspect the inside hub where the bearing presses in.
  18. Feb 9, 2013 at 12:15 PM
    #958
    nj636
    Kev
    Jersey
    yes bearing that is pressed into the hub. Where did you find just the bearing itself?
  19. Feb 9, 2013 at 12:37 PM
    #959
    ms4x4outlaws
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    Ok I was thinking the hub is where the rim bolts to. An the bearing presses into the hub. I was making sure that y'all weren't have problems with the hub it's self.
  20. Feb 9, 2013 at 5:40 PM
    #960
    ms4x4outlaws
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    Sorry if I sounded confusing. No I didn't find just the bearing.
