OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Jun 20, 2013 at 6:11 PM
    #1101
    eforward
    eforward New Member
    Bozeman, MT
    11 SR5 Longbed
    OME 885 1/4 top plate & 5100, toy tec aal & TSB, ARB up front w/winch
    Any further word on longevity of the bushing from those who have it installed?
  2. Jun 21, 2013 at 5:12 PM
    #1102
    tr1957
    tr1957 Well-Known Member
    Alabama
    2011 regular cab 4x4
    Do you mind giving the sizes of the parts ,washers ,etc for your home made puller?
    did you have to grind the washers?
    thanks
  3. Jun 22, 2013 at 8:17 AM
    #1103
    Haws
    Haws Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    I just needed a good reason to pull the trigger on this. Will be ordering the ARB and gears for the front next week from ECGS. I just wish I could gear the rear at the same time, but Ill need to wait to get my core charge for the front back so I can pay for the rear. 4:88's here I come
  4. Jun 22, 2013 at 8:19 AM
    #1104
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I have had it installed for at least 40k miles. So far so good.
  5. Jun 22, 2013 at 1:39 PM
    #1105
    Azntrutek
    Azntrutek Well-Known Member
    ATL
    08 TRDsport -Towpackage
    2".5 lift, HID head lamp and HID lights, color match tonneau cover and running board.
    (1) 6" long 5/8 bolt & (2) nuts.
    (2) 1.5" wahser 1/8 thick .. Thicker better
    (1) 1/2" thick steel plate
    I used angle grinder to grinder off 1/16" 2 parallel side
    of the wahser.
  6. Jun 22, 2013 at 7:13 PM
    #1106
    tr1957
    Alabama
    Thanks ,I will give it a try .
  7. Jun 22, 2013 at 7:23 PM
    #1107
    tr1957
    Alabama
    Anyone know the best aftermarket CV axle replacement ? I pulled mine today and it has some slight needle bearing marks on one side . I plan on ordering the bushing monday .I guess the axle needs replacing also .Any feedback on which cv axle to get ? Are the ones from the auto parts stores any good?
  8. Jun 22, 2013 at 8:08 PM
    #1108
    Azntrutek
    ATL
    I replaced mine with AutoZone Remanufacture duralast CV axle with lifetime replacement warranty .... Cost me like $90 wih core... 12k miles no problem.
  9. Jun 22, 2013 at 8:18 PM
    #1109
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Personally i would not recommend oreily. The one i had to order in was so tight in one joint that i could not bend it at all and the inner CV joint had so much slop that i could feel it click back and forth when rotated. NOT good. This may have just been that particular one but that was my experience. I ended up getting a reman one from napa and have had zero troubles at 12k on it.
  10. Jun 22, 2013 at 9:15 PM
    #1110
    drupp
    drupp Well-Known Member
    Pennsylvania
    '06 Access Cab TRD Off-Road
    NAPA remanufactured here too.
  11. Jun 23, 2013 at 6:55 AM
    #1111
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    x2 on the Autozone. I've put 20k miles on it so far.
    And thanks for sharing the pic of the needle marks on the axle. Haven't seen too many other people have those marks like I did. Still odd that they would gouge like that (has to happen in 4wd).
  12. Jun 23, 2013 at 11:47 AM
    #1112
    tr1957
    Alabama
    Do I need to keep anything from the old CV axle,seals ,etc before turning it in for a core?
  13. Jun 23, 2013 at 11:56 AM
    #1113
    tr1957
    Alabama
    How did you get the cv shaft in the differential?
  14. Jun 23, 2013 at 1:34 PM
    #1114
    EEKANOUSE
    EEKANOUSE Well-Known Member
    will
    PA
    2010 standard cab 4x4
    3" lift, Goodyear 265/75 duratrac, wet okole seat covers, are cap, safari springs rear.
    The arb kit already has a bushing for the front diff you don't need the ecgs one when you put their locker in.
  15. Jun 23, 2013 at 1:44 PM
    #1115
    tr1957
    Alabama
    The bushing is cheap compared to the locker.
  16. Jun 23, 2013 at 5:20 PM
    #1116
    05Moose
    Jim
    Pushed it in by hand. When the splines are lined up, it goes in easily. Getting the old one out though was a PITA. IIRC, you only have to transfer the metal shield over from one axle to the other. It'll be obvious when you have them side by side.
  17. Jun 23, 2013 at 5:30 PM
    #1117
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    nice
    i had a friend who had one i borrowed that
    i need to buy him some beer:D
    cvj axles......
    oe axles rebuilt
    might need the dust shield.....
    if you get a cvj axle they have all new
    i put nut back on lined up splines. faced the the c clip opening facing down and gave it 2 good taps with a lump hammer
    and to get old out of cv i used a cold chisels and a lump hammer a few taps and out she went.....
    good luck
  18. Jun 23, 2013 at 6:10 PM
    #1118
    Taco'09
    Taco'09 Well-Known Member
    ^^ Ditto on the additional pic.
    As previously posted here, my right side had developed the same needle scoring at very low miles on a stock truck. This would be on the stub shaft that comes out of the passenger side of the front diff, not the CV shaft. The right side uses the same needle bearing. To me, when I saw this scoring on my truck, I kept thinking that the bearing running surface is being hammered by the needles in some fashion.
  19. Jun 23, 2013 at 6:19 PM
    #1119
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    did you check the worn mark against the adjacent surface with a Micrometer?
    I bet its still ok.
  20. Jun 23, 2013 at 7:11 PM
    #1120
    05Moose
    Jim
    They're gouged in and can be felt by hand. It's no longer a round, smooth surface. I think what you're seeing is the "band" where the shaft rides in the bearing. Zoom in on the pic and you'll see lines on the shaft (length-wise). You can see them better on mine below. See the vertical scratches in the pic?
