OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Jun 24, 2013 at 2:23 PM
    #1121
    tr1957
    tr1957 Well-Known Member
    Alabama
    2011 regular cab 4x4
    Does anyone have a bearing puller for sale?
  2. Jun 24, 2013 at 5:23 PM
    #1122
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    I have one
  3. Jun 24, 2013 at 6:00 PM
    #1123
    tr1957
    Alabama
    what are you asking for it?
  4. Jun 24, 2013 at 6:15 PM
    #1124
    tr1957
    Alabama
    Did you push the bolt in the bearing with the nut and washer attached?
    angle it in?
    I went to home depot and got everything except could not find a 1.5 inch washer that would it the 5/8 bolt.The smallest washer that fit the bolt was
    1.75
  5. Jun 25, 2013 at 7:32 AM
    #1125
    Taco Guy11
    Joe
    Western Maryland
    What's the normal selling price of a used one. I wasn't going to sell but it's doing me no good
  6. Jun 25, 2013 at 8:32 AM
    #1126
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    100 million dollars!
  7. Jun 25, 2013 at 8:52 AM
    #1127
    Azntrutek
    Azntrutek Well-Known Member
    ATL
    08 TRDsport -Towpackage
    2".5 lift, HID head lamp and HID lights, color match tonneau cover and running board.
    I just went ( MY FAULT...SORRY ....it was 1.75" washer) to homedepot and pich these up
    Just to show them to you.
  8. Jun 25, 2013 at 8:59 AM
    #1128
    Azntrutek
    ATL
    Then you neither supper glued or weld the washer and the nut together
    Like showing ...then grinding off 1/16 of an inch 2 parallel side of the washer .
  9. Jun 25, 2013 at 9:12 AM
    #1129
    Azntrutek
    ATL
    This is how it look like without the steel plate. Turn washer sideway (grinded off side) when you insert the washer in to the diff thru the needle bearing. Remember to put clean shop rag in to the diff ( In case you drop the washer inside the differential) prior inert the washer .
  10. Jun 25, 2013 at 9:19 AM
    #1130
    tr1957
    Alabama
    I will look again .. maybe the home depot here did not have them.
    I don't have a welder or side grinder ,will try a bench grinder,should work and super glue. if that does not work for me I will make an offer on the one for sale.
    Thanks
  11. Jun 25, 2013 at 9:29 AM
    #1131
    Azntrutek
    ATL
    i'm currently live in atlanta Georgia and had all the tools.... if you willing drive down to Atlanta on my day off. i am more then willing happy to help you.
  12. Jun 25, 2013 at 9:50 AM
    #1132
    tr1957
    Alabama
    That is very generous of you , I think I can get it though.
    I do appreciate the offer .
    Would you consider sending the ground washers and welded nut to me?
  13. Jun 25, 2013 at 9:57 AM
    #1133
    Azntrutek
    ATL
    OK...PM me your address i will mail it to you.
  14. Jun 25, 2013 at 10:06 AM
    #1134
    tr1957
    Alabama
    Sent ,
    Thank You
  15. Jun 25, 2013 at 2:38 PM
    #1135
    tr1957
    Alabama
    Has anyone just replaced the bushing and used the CV axle with indentation marks from the needle bearings?
  16. Jun 25, 2013 at 4:09 PM
    #1136
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Send a PM to Chase and ask him if it will be a problem with the bushing. If yours are like mine, they're indentations and don't have a raised edge. Still, I'd ask him before deciding to not change it.
  17. Jun 25, 2013 at 4:36 PM
    #1137
    tr1957
    Alabama
    Did you reuse your cv axle?
    I can feel the indentations with my fingernail.
    The pictures you posted looks worse than mine.
  18. Jun 25, 2013 at 4:59 PM
    #1138
    05Moose
    Jim
    No, I did not reuse mine. But I also installed a new needle bearing because it was before Chase made the bushings.
  19. Jun 25, 2013 at 6:23 PM
    #1139
    tr1957
    Alabama
    Did the rebuilt CV axles from autozone have new bearing surfaces?
  20. Jun 25, 2013 at 6:27 PM
    #1140
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    cvj axles ftmfw and you can order them with high angle boots.... or at least the inner
