OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Jan 13, 2012 at 6:50 AM
    #101
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Dude, just read up a few posts! Your first 3 posts on TW and you didn't even read the thread!
  2. Jan 13, 2012 at 11:33 AM
    #102
    TwoTacos
    TwoTacos Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport
    3" Leveling Kit with AAL, 5160/6112 Billsteins, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
    UPDATE,
    So I go to pick up my truck today from Toyota. The technician did take it for a road test and did hear the evident "resonanting humming" noise comming from the front driver side. I told them to switch in in and out of 4WD to see the difference when I dropped it off this moring. Unfortunetely they forgot to try this and blame the noise on my tires (Mickey Thompson ATZ's), fricken morons!! They claim they inspected the entire axle and differential and say it's in perfect shape, wow!, amazing!, I guess they can see through steel. I fought with the service manager for awhile until I got bored and walked out. BTW, the F^@%er's tried to charge me $90 for something that should be coverred by warranty anyways, I did not pay. To make me feel warm and fuzzy inside they told me to come back again soon and gave me an entry form to win a camry, which of course I didn't win.:mad:
    I too am waiting for a permanent fix for this, hopefully it comes soon.
  3. Jan 15, 2012 at 1:37 PM
    #103
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    Nothing you haven't already heard. I had a new front diff installed 4 months ago and the growling is back between 60-70 kph. It is nowhere near as bad as the last diff but I imagine it will eventually get there. I think I can manage one more diff on warranty but this time I'll make sure to replace the shaft as well, just to be safe. I think I'll head over to the ecgs website and have a look.
  4. Jan 15, 2012 at 1:40 PM
    #104
    Koby
    Vancouver
    06 access trd
    TwoTacos, I just noticed you are from Winnipeg. I use to take my Tacoma all the way down to the boys in Steinbach to have all my work done. I did not trust or like a single Toyota dealer in the city. Maybe try them out.
  5. Jan 16, 2012 at 6:01 AM
    #105
    TwoTacos
    Winnipeg, MB.
    2011 TRD DCLB Sport
    Thanks, I might have to do that if they keep screwing me around in the city. Did Steinbach cover your front diff even with the lift in it? If so I'll have to give them a call. Thanks.
  6. Jan 16, 2012 at 8:50 AM
    #106
    Koby
    Vancouver
    06 access trd
    I didn't put my lift in until I moved to Vancouver. The guys down there provide good service and are eager for business from the city so I'm sure they will more than likely help you out. One of the service guys, at least when I was there, was a Tacoma nut. He used to come with me for test drives to help diagnose different issues. Just let them know how unhappy you are with the city dealers and they will be even more inclined to help. Good luck.
  7. Jan 16, 2012 at 9:40 AM
    #107
    tim allan
    tim allan Well-Known Member
    Wv
    2017 double cab trd offroad
    just waiting to hear back from chase for when he gets the bushing in, then we will test it out on my truck
  8. Jan 16, 2012 at 9:41 AM
    #108
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    Keep us posted. How long you going to run it before you make it available (to verify everything is good over time)?
  9. Jan 16, 2012 at 1:02 PM
    #109
    tacomtn
    tacomtn Well-Known Member
    TRD OR,OME,Deaver AAL
    Toy mech diagnosis: Bad diff carrier bearings, both sides. He had it up on the hoist and let me listen with a stethoscope to the diff bearings and wheel bearings. A slight grinding can be heard on both diff bearings, nothing on the wheel bearings. Only slight noise since they're wasn't a load on the drivetrain.
    So, they're not covering it since it has a lift, just as I was afraid of. It looks like others here have had the diff replaced only to have the issue return.
    Question: The ARB is the solution then? How does it work actually to resolve this problem? Better bearings, better angles, or What?
  10. Jan 16, 2012 at 2:08 PM
    #110
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    Here's my experience.
    Part 1: Two years ago, at 35k miles (right before bumper warranty is up) I took truck in with this issue. I had just bought the truck with a revtek lift and 33" tires. The noise was obvious (to me) but not to the tech. They gave me the runaround saying it was the BFG/AT tires. Whatever... I file a "claim" with Toyota directly but they also give me the runaround saying it has a lift and big tires. Ok...
    Part 2: Last week, I take it in for an oil change, and mention this issue again as it has gotten a bit louder (now at 55k miles). I've since lowered the truck 1" all around with 5100's and AAL (got rid of spacers and blocks), went to 32" tires and installed diff drop and wheel spacers (not that the spacers would matter).
    Dealer say they can hear the noise (miracle!) but I'm out of drivetrain warranty by 2 months. I tell them the issue is documented and to see what they can do with Toyota. Got the call this morning that Toyota would cover 1/2 of the $2200 cost of new front diff.
    I was waiting for this and gave them the green light. This gives me a year warranty on the parts and keeps me from wasting a weekend doing it myself and potentially running into other issues.
    Glad it's finally getting fixed, but $1100 hurts when it could be fixed for $100 in parts... bit the bullet on this one.
    I'll keep yall updated if the issue comes back. Worse case I'll lower to .85" on the 5100's and remove AAL or overload...
  11. Jan 16, 2012 at 3:08 PM
    #111
    tacomtn
    Did you purchase it from the dealer new with the lift installed? If so, it should have been fully covered since you bought it from the dealer lifted already.
  12. Jan 16, 2012 at 3:09 PM
    #112
    tacomtn
    This thread should be STICKY so all the discussions are centralized. Moderator?
  13. Jan 16, 2012 at 3:17 PM
    #113
    IslandBoy86
    IslandBoy86 Well-Known Member
    Las Vegas, NV
  14. Jan 16, 2012 at 3:18 PM
    #114
    tacomtn
    So, with an ARB locker installed, does this totally eliminate the problem? If so, this is a good fix to allow us to run a lift AND have the benefit of a front locker.
    Chase?
  15. Jan 16, 2012 at 3:37 PM
    #115
    tacopromatt
    Austin, TX
    I purchased it used from a sister dealer (Chevy) and it was purchased new from an entirely different Toyota dealership brand in town. No way to know if it had a lift on it when it was purchased new. I even have the original window sticker and no mention of it, although dealers tend to like the RevTek lifts...
  16. Jan 16, 2012 at 5:01 PM
    #116
    tim allan
    Wv
    the arb has a new carrier which has a bushing instead of the needle bearing, thus tightening the clearences on the cv shaft not allowing alot of play
  17. Jan 16, 2012 at 6:35 PM
    #117
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Ok so I may be a new member to front end vibe/noise club but I am not sure. It seems like many of you have lifted your truck but mine is stock, in fact I drove it off the lot three weeks ago with only 10 mile on the od. I heard this noise the day I picked it up but I thought it was from the tire and that it might go away after I put some miles on. It sounds like what you all describe but I can't pinpoint where it is coming from, to me it sounds like the front passenger side or under the center console. Also I think I tend to hear it when it is warm (of course it is winter so how warm is it actually getting) or warmer but honestly I don't know. I now have 1700+ miles and last week I got so fed up that I went back to the dealer, of course before I read through this thread, but their service manager was not able to hear the noise and told me that I was probably hearing the fresh air pump for the exhaust system (?) that on the 2012's is located above the right front wheel well. After the SM told me that I decided to test that theory and I ran the truck up to 40 mph put it into neutral and shut the truck off and heard the noise plain as day so obviously it not the pump but is a bearing or something like that. I called the SM back and told him about my test but he said I should wait until I bring it in for my first service or the noise gets louder so he can hear it. Also its not the brakes because it doesn't go away when I hit the pedal. I haven't been able to do the 2wd to 4wd test yet but will do that tomorrow. My question to all of you is do you think it could be something that just needs to break in or do you think it is the same as what you all are experiencing? Has anyone else ever heard this with so few miles? Any help or insight would be appreciated.
  18. Jan 16, 2012 at 8:39 PM
    #118
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    To greenrustic, it is a large possibility thet you are hearing the bearing noise this early in your trucks life. The only way to tell is by doing the diagnostic checks that others have done. Get your truck going to where the noise is the loudest. It is ok to engage 4hi as long as you are driving under 55mph. If you engage the 4hi and the noise goes away instantly, then unfortunately it is the front diff bearing. If it remains while in 4hi, you may have a another issue such as a wheel bearing. If you want to try and pinpoint this yourself before taking it to the dealer, do these checks, and you can get the front end on jack stands, with a medium length flat head screwdriver you can place the end of it where the bearings are, spin the wheels ,and listen for excessive noise. Hope you get your issue resolved.
  19. Jan 16, 2012 at 10:22 PM
    #119
    tacomtn
    Why would the noise stop when engaged though? The axle spins regardless of being in 4wd or 2wd. Is it because the wheel bearing becomes loaded when in 4wd? I'm just trying to understand better what's involved here. Thanks
  20. Jan 16, 2012 at 10:32 PM
    #120
    tacomtn
    Man this going to be an expensive fix! But the choices are this or fix and remove the lift
