OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Jul 16, 2013 at 10:06 PM
    #1181
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    ^ This
  2. Jul 16, 2013 at 10:24 PM
    #1182
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Thanks
  3. Jul 17, 2013 at 9:30 AM
    #1183
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    Ordered the 1st gen bearing from ECGS. What did you guys use to install the new bearing into the diff? I don't have a race driver set.
  4. Jul 17, 2013 at 12:40 PM
    #1184
    tr1957
    tr1957 Well-Known Member
    Alabama
    2011 regular cab 4x4
    Autozone will loan you a driver , you get your deposit back when you return the tool.
  5. Jul 17, 2013 at 12:47 PM
    #1185
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i picked one up from hf for like $30
    worked great
    but you can just use a socket or something too
  6. Jul 17, 2013 at 12:48 PM
    #1186
    brutalguyracing
    F.U> GUYZ
    broken mods
  7. Jul 17, 2013 at 5:36 PM
    #1187
    Inverno4
    Baltimore, MD
    2020 DC Off-Road MT
    Thanks. I didn't know autozone had racer drivers as one of their rentals. Going there tomorrow.
  8. Jul 17, 2013 at 8:06 PM
    #1188
    tr1957
    Alabama
    yes ,I rented one from them ,60 bucks but you get it back when you return the set.
  9. Jul 21, 2013 at 1:13 PM
    #1189
    tr1957
    Alabama
    Problem fixed ,
    I used a GoPro camera strapped to different locations and went for a drive.
    The case on the camera was the waterproof sealed case , the case worked well by blocking wind noise to the microphone and the vibration would still get transmitted through the case .I attached it using zip ties to the rear axle housing near the diff and then to each front wheel steering knuckle on the bar from the top ball joint. I then listened to the recording and when listening to the passenger side front knuckle I could hear the noise . I checked the wheel bearing before and it was smooth and did not have any play . I changed out the wheel bearing /hub with the one I changed recently on the drivers side and hum/vibration gone. I changed a lot of parts before changing this one ...Oh well I am happy that problem is gone.
  10. Jul 21, 2013 at 6:26 PM
    #1190
    Taco'09
    Taco'09 Well-Known Member
    ^^^ Hey tr1957, wow, good job. I like you already.
    So it was the old familiar Tacoma front wheel bearing problem huh?
    Will you please recap for us your mileage and if you are running stock or modded wheels?
  11. Jul 21, 2013 at 6:28 PM
    #1191
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    1 3/8"
    :p
  12. Jul 21, 2013 at 6:58 PM
    #1192
    tr1957
    Alabama
    26k miles ,stock everything. I purchased this truck with front end damage and had it repaired by my brother who owns a body shop.The truck was hit mostly on the driver side front end which is why I thought the problem was on the the drivers side. My brother said it sounded like a wheel bearing which was damaged due to the wreck .after reading the info here about needle bearings/bushings and such I kinda got off track as to the problem.Hopefully the front diff bushing was preventative maintenance.The drive shaft also through me off because it had a dent and wobbled .The drive shaft shop said toyota does not machine the drive shaft and yoke and just balances it with weights.
  13. Jul 21, 2013 at 7:32 PM
    #1193
    Taco'09
    ^^^ Well, now you are vested in it and are going to have to keep it for a long time. Don't feel to bad about having done those other things. The front diff. is a POS and you would likely be in there doing the bushing before long anyway. Looking at your parts replacement list I don't see any unnecessary fixes given its history IMHO. And think of the attention you have given it. :)
  14. Jul 23, 2013 at 7:50 AM
    #1194
    Inverno4
    Baltimore, MD
    2020 DC Off-Road MT
    ***I have a 1st Gen*** ECGS now has the bearing for the 1st gens too. I purchased and installed it this past weekend. No more vibration. Thanks ECGS.
  15. Jul 24, 2013 at 8:27 AM
    #1195
    alpinebob
    alpinebob Well-Known Member
    bob
    alpine ca
    2008 Tacoma 4x4
    Hi all, I traded my 95 Taco with 290K Mi, running great for an 08 4 Dr. to have room for my rapidly growing grand kid. I bought the 08 last year with about 80K Mi. on it all was well until about 88 K Mi. now I have the "growl" . Toyota dealer I.D. ed the problem as drive shaft and estimated $1,500 to replace it. I replaced the center carrier and "U" joint myself with no improvement, all joints really appear and feel good and are well lubed.
    After reading this forum I am convinced that there is a basic design/fabrication fault and that Toyota must know about it? Does any one here know ???
    Thanks, bob
  16. Jul 26, 2013 at 7:59 AM
    #1196
    tr1957
    Alabama
    Ok, now on to the next problem... I hear a rattling noise like a chain sound for lack of a better description when I let up on the gas at around 55 mph. coming from the drive shaft or rear diff or maybe the transfer case sometimes. I noticed it with the rear off the ground and running the back wheels but thought it may have been due to no load on the wheels . Anybody know what this might be?
  17. Jul 26, 2013 at 8:05 AM
    #1197
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Exhaust shield?
  18. Jul 26, 2013 at 8:34 AM
    #1198
    Taco'09
    There is a current thread going here on TW about possible transfer case chain rattles and vibrations. There is also one on Toyota Nation that dates back a couple of years about the same. The issue surrounds whether or not the transfer case chain actually turns, albeit slowly, when in 2WD. Might want to take a look these.
  19. Jul 26, 2013 at 9:02 AM
    #1199
    tr1957
    Alabama
    Thanks, I will check it out , I don't think it is the exhaust shield but will check this weekend.
  20. Aug 8, 2013 at 7:30 AM
    #1200
    tr1957
    Alabama
    discovered another issue ,won't go into 4 wheel lo.
    The light flashes and beeps but nothing happens.
    any ideas?
