OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Nov 26, 2013 at 6:24 PM
    #1321
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    Thanks for posting the axle nut torque. It's not on that sheet. Although I just found it in my notes.
  2. Nov 26, 2013 at 6:31 PM
    #1322
    bkg
    bkg Active Member
    Currently have 73k. Possible that it could be both, but given I just had it aligned and my guy (whom I trust) didn't mention anything, and my symptoms are virtually identical, I think I'm on the right track.... I hope.
  3. Nov 27, 2013 at 5:07 PM
    #1323
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Both bearings went bad on my access cab with no warning, no growling noise present. They were literally smoked :eek:
  4. Nov 27, 2013 at 5:50 PM
    #1324
    Taco'09
    Taco'09 Well-Known Member
    ^^ This is why I recommend doing both front bearings at the same time. I know a lot of guy will disagree with me its just that I have bad luck and seem to always be doing these types of jobs twice. My experience has been that if one front wheel bearing is bad the other is not far behind.
    Good luck.
  5. Nov 27, 2013 at 6:31 PM
    #1325
    bkg
    bkg Active Member
    Well... I stand corrected... turns out that I do hate a bad wheel bearing. Ordered up bearings fork NJ636 and figure I'll kill two birds with one stone... and hopefully never have to take the front end apart for a good number of years.
  6. Dec 2, 2013 at 3:09 PM
    #1326
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    So I'm not in a position to do this repair myself, but I found a mechanic who said he was willing to try. My question is whether I should buy the "removal tool" for him, or would he have something similar in the shop to do the job? Also, how much should I expect to have to explain to him about what I want done? As a last question, should I buy a new set of CV axles just in case these are too torn up?
    2006 4.0L TRD Access Cab 4x4 with 1" Spacers and 110k miles. (no idea when the spacers were installed, or what brand, since I just bought it a few months ago)
  7. Dec 2, 2013 at 4:18 PM
    #1327
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    If he has an email, send him the UTube vid of the install. Ask him if he has a bearing puller, most likely he will, but if not, you'll be prepared. Yes, just buy a new CV axle, better to have and not need than to need and not have. If he is an experienced mechanic, he shouldn't need much of an explanation of what needs to be done. So, buy 1. New CV Axle 2. New diff seal 3. New bushing 4. 3 qts of 75w 90 gear oil, and if needed, the ECGS removal tool.
  8. Dec 3, 2013 at 9:35 AM
    #1328
    americanrancher
    americanrancher Active Member
    Ben
    Oregon
    07 Tacoma 4X4 5100's BFG KO's
    5100's, 265 BFG KO's, not lifted, daily driver
    Hey Bro;
    Just went through the same situation myself. I spoke with 2 shops, one had made their own tool and the other wanted me to buy it. I used the shop that wanted me to buy it, they did the work very quickly, about 1.5 hours partly thanks to the tool. The shop was so pleased with how it went that they bought the tool from me. I also printed out the instructions for the shop, I was not sure he would look at the YouTube video and I wanted something he could use while the truck was up on the lift. I bought the CV axle just in case, but did not need it and returned it for full refund from NAPA. Dealer wanted $2500 for replacing the whole front dif:eek:, I paid $250 with the ECGS bushing and the independent shop labor to fix it!:D
    More later on my dealings with Toyota USA about this defect.
  9. Dec 3, 2013 at 10:56 AM
    #1329
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    ^^^ Good luck. I was discussing this with the service guy and he said Toyota hasn't moved on it, no TSB, nada.
  10. Dec 3, 2013 at 11:45 AM
    #1330
    DonL
    DonL Well-Known Member
    Don
    Prescott, AZ
    Tacoma TRD
    Monster Exhaust, Shell, 5100's all around, Airlift airbags, Hankook Atm, K&M air filter
    I have the problem as well. 2008 Tacoma Off Road, 15000 miles on the OD, 1000 miles after the 5100 install at 1.75. This is my 4th Toyota truck ('89, '97, '08) and this one is the only one that has had problems that the dealer wouldn't stand behind. The '89 had bad head gaskets at 92K and Toyota paid the whole $1,182 for the repair that was done by a non-Toyota mechanic. I've got the bushing and the tools ordered, downloaded all the photos and instructions and will to do the work myself. Hopefully, I won't need a new CV axle. Screw the Toyota dealer!!!!!! Don
  11. Dec 3, 2013 at 3:45 PM
    #1331
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    subb'd because My lift is going on next week and I will prob need to have my guy do this shortly thereafter.....:eek:
    edit........holy shit......on my way to work at 6am this morning I got a "growling" noise in my front left end it sounds like. Gawt damn that's some timing.:eek: Gonna go try out 4H and see if it stops. It seems to stop when I turn right too even just a little. Hopefully I can tell right away when I put it in 4H and it goes away.
  12. Dec 5, 2013 at 8:58 PM
    #1332
    Marcitron88
    Marcitron88 Active Member
    The Great White North
    2013 MGM DCLB
    Ok so my local dealer installed the ecgs bushing and I still get the exact same vibes! They actually got worse once they installed the bushing. I fought with them and they rechecked the bushing and said they pulled it out and then reseated it and that it seated better the second time...vibration still there and goes away in 4hi. They are now saying that I need a new front diff. Could the vibration be produced by something else in the diff or could they have messed up the installation twice? Im going to a 4x4 shop tomorrow to get a second opinion...this is driving me crazy! :confused:
  13. Dec 5, 2013 at 9:19 PM
    #1333
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Definitely get a second opinion.
    Did they check bearings? Balanced driveshafts?
  14. Dec 5, 2013 at 9:37 PM
    #1334
    Marcitron88
    2013 MGM DCLB
    I dont believe so but thats the last time I go to Mayfield Toyota...is there anything that could produce the same exact vibrations that go away in 4hi? I think I might strap the go pro under the truck on weekend to see if it can pick up anything. IgnorantlyAlberta...is there any 4x4 shop in Edmonton that you reccomend?
  15. Dec 6, 2013 at 5:54 AM
    #1335
    alpinebob
    alpinebob Well-Known Member
    bob
    alpine ca
    2008 Tacoma 4x4
    Called Toyota in Los Angeles and was told that there IS a TSB ???
    My bad I lst the scrap of paper wit the TSB number but will check further.
    alpinebob
  16. Dec 6, 2013 at 11:49 AM
    #1336
    americanrancher
    Ben
    Oregon
    I spoke with Toy in CA also, they claim only a TSB for the Tundra. We all know it is the same part but they claim it isn't (crazy). Toyota offered me $1000.00 of assistance in putting in a BRAND NEW dif that cost $2500! I did the ECGS bushing replacement instead and the vibe went away. BUT I have something new a rattle not sure yet what it is yet. I did not replace my CV shaft it looked OK no scoring however sliding the new bushing on it there was play, not as much as with the Toy needle bearing but there. Perhaps we need to replace the shaft in all cases? I am about to write a letter to Toy re this problem and the way they are dealing with it, I will post it on the site as well. It's time for Toyota to get real about this problem.
  17. Dec 6, 2013 at 4:31 PM
    #1337
    ImplicitlyAlberta
    David
    edmonton
    Mayfield is trash. Check with sherwood park toyota. 4wheel on argyll is where most of us have been heading lately. They deal mostly with toyotas and are really knowledgeable.
    Also check out the edmonton toyota thread. A bunch of good guys, shops to go to and help around the corner.
  18. Dec 7, 2013 at 3:14 PM
    #1338
    DonL
    Don
    Prescott, AZ
    Tacoma TRD
    Replaced the needle bearing with bushing and new seal from ECGS. Very slight scaring on the axle shaft bearing surface (after only 19 K total on the truck) so I'll replace it with a CVJ re manufactured CV Axle. I don't want to take a chance. Chase's instructions for the take down and install were great. Had a little trouble getting the removal tool in the carrier so I ground the inside edge off the small plate slightly (rounded it off) and then it slipped right in. Have to call Monday for the Axle.....Don
  19. Dec 7, 2013 at 4:29 PM
    #1339
    SAM1
    SAM1 Member
    08 TRD Off Road
    I've got a sloppy front diff so the ECGS bushing is getting added next week. However, I'm not sure the strange sound in my front end is from the diff. I strapped a GoPro to the front bumper, hoping maybe one of you can help diagnose the sound (assuming you can access the video). You can really hear it at about 36 secs and 1:15 secs.
    Thanks for any help.
  20. Dec 8, 2013 at 5:13 AM
    #1340
    Wesmorgan
    Wesmorgan Member
    Got the ECGS bushings in. Took about 5 hours with 2 trips to parts store, some cussing, bleeding, head scratching and beer drinking. I had to grind down the removal tool a hair also so it would drop in old bushings. Very smooth now. Well worth cost and effort.
