OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Jan 16, 2012 at 10:49 PM
    #121
    ratrod
    ratrod Well-Known Member
    Los Angeles
    2006 Toyota Tacoma Dbl Cab TRD SR5 4x4
    Bilstein 5100s @ 1.75 with 1.5 AAL, Satoshi Grill Mod with 2 Hella 500s behind the grill, LED dome and map lights, custom made (by me) 10" subwoofer box behind the dbl cab seat, DVD/iPod/Bluetooth/GPS/TV/USB/Stereo, Yakima rack, Shell, tinted front windows to match the factory backs. Backup cam in the tailgate handle mod.
  2. Jan 16, 2012 at 11:44 PM
    #122
    dmcnealy22
    dmcnealy22 Well-Known Member
    Indiana
    07 4x4 bsp
    Front 5100's @ .85
    I am getting an email when the bearing comes available for sale from ecgs so I will let ya'll know if I hear any news soon
  3. Jan 17, 2012 at 10:14 AM
    #123
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    Got the truck back today with the new diff. I noticed they didn't replace the driver side axle. Truck drives great (for now) and hopefully it lasts as my CV angles are perfectly level.
    Ended up paying $890 as Toyota split the cost and service advisor gave me a discount. Part comes with unlimited miles warranty for 4yrs (I think that's what I heard), so if it happens again, it's going back.
  4. Jan 17, 2012 at 12:06 PM
    #124
    tacomtn
    tacomtn Well-Known Member
    TRD OR,OME,Deaver AAL
    I did the 4 hi test again and the noise does in fact stop. This means wheel bearings and NOT the diff bearings? Someone please explain why this would point to the wheel bearings...
  5. Jan 17, 2012 at 12:07 PM
    #125
    tacopromatt
    Austin, TX
    Other way around. If the noise stops in 4Hi, it's the diff bearing.
  6. Jan 17, 2012 at 1:48 PM
    #126
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    Just a quick note on your bearing problem. If it was your wheel bearing, the noise would be more constant and tend to fade out around corners as you take the load off the bearing. Your issue most definitely sounds like the front diff bearing. The sound you tend to hear from the diff is more rythmic and doesn't happen with every wheel revolution and of course, completely goes away when you reach the problem speed and switch to 4hi. Welcome to the club.
  7. Jan 17, 2012 at 3:30 PM
    #127
    tacomtn
    Ok thanks for the clarification. So why does the noise stop when in 4hi ? What's the mechanics behind that? When engaged in 4hi I would think the noise would be louder not stop. Confused
    Options:
    1. Replace diff with ARB. Does this ensure bearings won't wear out prematurely again? Are ARBs designed to accommodate the steeper angles placed on the axles from lifted trucks? Costs about $2k all said and done, right?
    2. Replace diff and remove lift
    3. Replace factory diff bearings with the new ECGS bearings. These are experimental and may or may not last. Have to factor in cost and time/labor to install bearings, send core back, downtime w/o an operable truck. Maybe better to go ARB.
  8. Jan 17, 2012 at 4:10 PM
    #128
    dmcnealy22
    Indiana
    07 4x4 bsp
    Front 5100's @ .85
    the arb uses a bushing instead of a needle bearing .... thats kinda the concept that chase from ecgs is trying to mimic .... with the bushing being significantly longer to help support the cv better with a tighter tolerance.
  9. Jan 17, 2012 at 5:09 PM
    #129
    tacomtn
    Is yours lifted or stock?
  10. Jan 17, 2012 at 5:11 PM
    #130
    tacomtn
    So the RCD lift is like a drop bracket and allows the axles to be level? But it requires notching/cutting the frame's crossmember, yes? I'm not a fan of cutting into frame parts, especially on a new truck. Plus its about $2150. Yikes again.
  11. Jan 17, 2012 at 8:09 PM
    #131
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    Correct. I ended up lowering mine down to just Eibachs instead. If I kept vehicles longer that RCD kit would probably be on right now. If I had to do it over again I would have bought it I think though. But once you've dropped a grand alone on billet UCA's, $500 on shocks and springs, another $200 on the Icon AAL it's starts to add up and the headache it's caused I'd rather have went RCD. No diff vibes in the RCD club. It's only $1850 shipped from downsouth BTW. I'm just speaking for myself though. The guy with only Eibach springs and $1000 UCA's :(
  12. Jan 17, 2012 at 8:23 PM
    #132
    tacomtn
    I like that the RCD keeps the axle angled straight but the minimum lift is 4". Too high for serious wheeling IMHO. Plus the cost again.
    Why did you take off the RCD? You had a diff problem even with the RCD and level axles?
  13. Jan 17, 2012 at 8:35 PM
    #133
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    I spent $1800 on my parts as it is and my end result is 1.5" lift in the front only (because I lowered it back down to relieve this vibration). In most cases the the RCD is not a very wallet friendly option. But with as much as I spent I could have got it and avoided being part of this thread in the first place. Thats all I'm saying.
  14. Jan 17, 2012 at 9:14 PM
    #134
    tacomtn
    But didn't you already have an RCD lift on before the diff vibe problem?
  15. Jan 17, 2012 at 9:23 PM
    #135
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    Nope. Just posted a random picture of someone's RCD setup from the forum. Just feel like I should have went that route in the first place. PM me if you have any other questions. I don't want to clutter this thread anymore so than we have already.
  16. Jan 18, 2012 at 6:56 AM
    #136
    pintokiller79
    pintokiller79 Member
    Kyle
    Dallas, GA
    TRD Sport 4x4 6speed
    Box Stock right now
    I get the same vibration from my truck, 06 AC with billy's set at 2.5. Has anyone actually had the bearing fail, or is it just harmonics?? I can deal with it if it is just noise. My KM'2's almost mask the sound anyways.
  17. Jan 18, 2012 at 6:59 AM
    #137
    Koby
    Vancouver
    06 access trd
    I think when you put your truck into 4hi it simply locks everything up inside the diff so nothing can slop around. That would be the simple way of explaining why the vibe disappears. I could be a little off though. I'm certainly not a mechanic.
  18. Jan 18, 2012 at 8:01 AM
    #138
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Warranty on Toyota parts is 1 year unlimited mileage. I'd be amazed if it was 4 years, but maybe that's a dealership specific warranty? I also hope your axle didn't have any scoring, otherwise the vibe will be coming back. Been there, done that.
  19. Jan 18, 2012 at 2:09 PM
    #139
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    2"+ of lift installed yesterday and unsurprisingly I have the diff vibe, although it's not all that bad yet. I am definitely eager to hear the report on the ECGS bushing. Since I'll be tearing everything apart to replace the needle bearing, I may as well replace the CV axle and wheel bearings while I'm in there. Rockauto seems to have great prices on both, but what are the preferred brands? Timken or Beck/Arnley for the bearing? Cardone or EMPI for the CV axle?
  20. Jan 18, 2012 at 3:16 PM
    #140
    dmcnealy22
    Indiana
    07 4x4 bsp
    Front 5100's @ .85
    I know timken makes alot of oe bearings so id probably go with them but beck arnley stuff is pretty good as well....We sell alot of cardone at advance...most of it is reman stuff tho ... not familiar with the EMPI
