OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Feb 12, 2014 at 5:31 AM
    #1601
    13TRDsport
    13TRDsport Well-Known Member
    NE PA
    13 Access cab TRD Sport
    Aero Turbine 2525XL, K&N air filter, TRD Shift knob. Bilstein 5100's w\Eibach springs.
    I finally installed my ecgs bushing and I was a bit concerned because the axel still had quite a bit of slop in it. I saw on their video that it took the play down to 8 thousandths but this is def more than that. It did take a bit of play out but not much. The vibe at around 35-40 is virtually gone though, which is a good thing. I guess it is more the needles in the bearing that cause the noise\vibration. Is this normal?
  2. Feb 12, 2014 at 5:56 AM
    #1602
    wtmorgan1
    wtmorgan1 Well-Known Member
    So did you re-use your original CV shaft?
  3. Feb 12, 2014 at 9:40 AM
    #1603
    Mudphish
    Mudphish Member
    Andre
    Martha's Vineyard
    13 TRD OR Tacoma
    Sure did it showed virtually no evidence of ever being compromised what so ever.
  4. Feb 12, 2014 at 9:50 AM
    #1604
    13TRDsport
    NE PA
    same here. No scoring
  5. Feb 13, 2014 at 6:31 AM
    #1605
    13TRDsport
    NE PA
    noise is still there not real happy. spent money on the puller and the bushing......
  6. Feb 13, 2014 at 9:27 AM
    #1606
    BigHeadTaco
    BigHeadTaco GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    Noise?
  7. Feb 13, 2014 at 12:14 PM
    #1607
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    My bushing only reduced my diff vibes by half. But my CV shaft is more stable now. It is what it is.
    ARB locker with new gears are what I need now. :)
  8. Feb 13, 2014 at 12:34 PM
    #1608
    BOOSTEDTRD
    BOOSTEDTRD Active Member
    Aaron
    Overland Park, KS
    '11 TX Access Cab
    3 Hella Rally 4000 on modded Westin light bar, Bilstein 5100s front 1.75" front, Toytec 1/4" spacers, ECGS bushing.
    I agree, the bushing greatly reduced the vibration, but it's still there a little. I'd say 90% better. As long as it doesn't get worse. It probably varies with the amount of lift.
  9. Feb 13, 2014 at 1:42 PM
    #1609
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    I have thought about lowering my front just a little to see if it makes a difference.
  10. Feb 13, 2014 at 2:19 PM
    #1610
    BOOSTEDTRD
    Aaron
    Overland Park, KS
    '11 TX Access Cab
    I also wonder how many people that have installed the bushing use a diff drop. I had installed a ready lift spacer kit last year and it came with the diff drop spacers. I immediately noticed the vibration and tried removing the diff drop spacers, but the sound was the same. I removed the kit and returned it that week. I'm not using a diff drop now with my 5100's at 1.75" and 1/4" top plate.
  11. Feb 14, 2014 at 4:28 AM
    #1611
    13TRDsport
    NE PA
    the vibration. you can hear it a bit. It is improved since the bushing. But....in the video they show it reduced the play a lot and I really didn't see that. it is better don't get me wrong but Im just meticulous
  12. Feb 14, 2014 at 6:19 AM
    #1612
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Interesting. The bushing totally eliminated my vibes and noise.
  13. Feb 14, 2014 at 6:27 AM
    #1613
    13TRDsport
    NE PA
    yeah it didn't take up as much slack as the video...not even close....hmm:mad: kinda feel like i wasted 120 bucks....not to pleased.
  14. Feb 14, 2014 at 6:29 AM
    #1614
    13TRDsport
    NE PA
    ARB locker would be awesome.
  15. Feb 14, 2014 at 9:59 AM
    #1615
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Anyone in the SLC, Utah area that has done this before and has the puller tool and might be willing to help me out with the larger sockets and an extra set of hands to replace the bearing on my truck in the near future?
  16. Feb 14, 2014 at 10:22 AM
    #1616
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    I have an arb locker up front, and it cured all my vibes, was going to do the bushing but dont need to anymore.
  17. Feb 14, 2014 at 10:28 AM
    #1617
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    You have 35" tires right? Did you change gearing?
  18. Feb 14, 2014 at 10:30 AM
    #1618
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Yep im on 35's, going to 36's after these wear out. Im regeared to 4.88.
  19. Feb 15, 2014 at 7:17 AM
    #1619
    13TRDsport
    NE PA
    I think a lot of it is because the internals are cast and not machined, causing some slop. which is why when you change the carrier and stuff to the ARB it cures it.
  20. Feb 16, 2014 at 10:38 AM
    #1620
    GeneralPublic
    GeneralPublic New Member
    Andrew
    Salt Lake City, UT
    2010 TRD Offroad
    Stock with a lift
    Update: The ECGS bushing is in. I'm Pleased to say the my "rumble strip" vibration is gone completely! With about 33k on the lift, the CV axle was undamaged and reused. My front diff gear oil had never been changed before and was very dark, the magnet was covered in goo. Good luck all!
