OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Feb 23, 2014 at 12:22 PM
    #1641
    13TRDsport
    13TRDsport Well-Known Member
    NE PA
    13 Access cab TRD Sport
    Aero Turbine 2525XL, K&N air filter, TRD Shift knob. Bilstein 5100's w\Eibach springs.
    It made the vibration less noticeable but still present. When I checked the play in the cv before and after it did not make much of a difference at all. Everyone says that the bushing took up a lot of play. The wheel bearing is fine. it only does it once and a while between 35-45mph. Also, when i drive for a while like 5 miles or so, it goes away completely. could it need a fluid change? it was pretty black when I installed the bushing
  2. Feb 23, 2014 at 2:14 PM
    #1642
    BigHeadTaco
    BigHeadTaco GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    You could be low on diff fluid
  3. Feb 23, 2014 at 6:03 PM
    #1643
    alpinebob
    alpinebob Well-Known Member
    bob
    alpine ca
    2008 Tacoma 4x4
    SoCal's post should go to Toyota Engineering with a request for comment...
    alpine bob
  4. Feb 24, 2014 at 8:15 AM
    #1644
    SoCal Hillbilly
    SoCal Hillbilly Well-Known Member
    Eric
    San Diego
    2013 DCSB
    I dont know if that should be considered normal at 7k. I know its a different truck but my Bronco had 170k and it never looked that bad. I wonder if there is a relation ship between it being new and the vibes I was getting. Oh well guess I'll just have to service it more often.
    Some how I think I would be ignored.
    Oh and if someone out there needs the puller they can use mine. Dont think I'll be needing it anymore.
  5. Feb 24, 2014 at 2:38 PM
    #1645
    BamaToy1997
    Bill
    Navarre, FL
    Just completed doing my second bushing install of the ECGS bushing kit at my shop. This job is SUPER easy. I was quite happy with the parts, as well as the tool, and the ease of communication with the people at ECGS. Every email was responded to within 30 minutes or less. Kudos to those at ECGS for making these things!
  6. Feb 24, 2014 at 5:33 PM
    #1646
    Elicarpenter2234
    Elicarpenter2234 Member
    Eli
    Brooklyn ct
    05 Tacoma TRD OR
    3" billy's lift, billet grill,LED Gauge cluster, black housing headlights
    i lifted my truck this past weekend with the bilstein 5100's set at 2.5 with the 1.5 AAL. as soon as i was done i drove it around and noticed the vibration in the front. i was very eager to find out the cause of this so this morning at work i put it on the lift put in 4wd and let the truck drive in mid air you can actually see the axle wobble like crazy. my driver side has the most play and the passenger side is just starting. i plan on calling the dealership in the morning to see what they can do about it. it is under toyota's gold warranty that i purchased when i bought the truck due to they were only going to give me a 30 day 3000 mile warranty because its an 05 trd tacoma with 60k. is there anyway i should go about having it fixed like not tell them about the suspension lift and having them figuring it out and argue with them after they find out and try to tell me that they are not going to warranty it? i do believe suspension warranty should be voided since i altered it but the drivetrain was not. any thoughts?
  7. Feb 24, 2014 at 5:37 PM
    #1647
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Fix it yourself with the ECGS Bearing. Even if the dealership replaces the diff. The new one will likely face the same fate as Toyota has not addressed the design flaw in them.
  8. Feb 24, 2014 at 5:38 PM
    #1648
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    Ain't gonna happen. Your options are 1. remove the lift. 2. ECGS bushing 3. front locker
  9. Feb 24, 2014 at 7:53 PM
    #1649
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Yeah, I had mine set to .85 and had to have a diff drop kit for them to warranty it. At 1.75, they said they wouldn't cover it. This was a couple years before the bushing. Then a year plus later, I had to replace the bearing again. Next time will be the bushing now that it's available. So don't waste your time with another bearing or new front diff since you'll have to deal with it eventually.
  10. Feb 25, 2014 at 7:52 AM
    #1650
    NorthernTaco
    NorthernTaco Member
    Quebec Canada
    SR5 4x4
    Hello All,
    I have been following this thread closely over the last 18 months. I did end up purchasing and installing the ECGS bushing with great success and satisfaction clearing up the issue on my 2011 Tacoma.
    Unfortunately/fortunately :cool: (hahaha) I have been converted to the FJ world, and just recently traded in my Tacoma for a 2014 FJ and I am enjoying it :).
    I have searched the FJ forums and have not found much in the way of the same issue as the Tacoma for noise when lifted yet I am aware that they share the same front diff and many other simularities in the suspension.
    Anyone have any experience or knowledge on having to install the bushing on an FJ, any noise or complaints of the same issue as the Tacoma?
    I would appreciate any feed back on the subject. My 3 inch lift has already been purchased and is ready for installation, just wondering about doing the bushing at the same time.
    BTW LR UCA do fit directly from a Tacoma to an FJ just need to change the balljoints!
    Cheers
  11. Feb 25, 2014 at 8:18 AM
    #1651
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    I'd be curious to know if the new 2015 redesign will have a different front diff. And in my opinion, Toyota is well aware of this issue and every issue with the Tacoma's. They probably have their own team that travel around checking out dealers issues and reported problems. The problem is that if they acknowledge an issue, they have to resolve it.
  12. Feb 25, 2014 at 10:49 AM
    #1652
    DonL
    DonL Well-Known Member
    Don
    Prescott, AZ
    Tacoma TRD
    Monster Exhaust, Shell, 5100's all around, Airlift airbags, Hankook Atm, K&M air filter
    I noticed in another thread that Toyota is coming out with a new model of Tacoma with a 2" lift. I wonder if they redesigned the front differential for 2015?
  13. Feb 25, 2014 at 4:11 PM
    #1653
    13TRDsport
    NE PA
    So the noise im hearing even after the bushing is on and off at 35-45 mph. Im stumped! Anyone have any suggestions
  14. Feb 25, 2014 at 6:30 PM
    #1654
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    What re-design? We've already seen 2015 trucks and they're exactly the same.
  15. Feb 25, 2014 at 6:36 PM
    #1655
    Yotabilly
    The Bluegrass
    Makes me wonder what's different about the front diff if anything. The PRO has a two inch lift. Toyota has to know about the driver's side needle bearing issue. So, what makes them think there's not gonna be issues with stock trucks (PROs)?
  16. Feb 25, 2014 at 6:40 PM
    #1656
    BOOSTEDTRD
    BOOSTEDTRD Active Member
    Aaron
    Overland Park, KS
    '11 TX Access Cab
    3 Hella Rally 4000 on modded Westin light bar, Bilstein 5100s front 1.75" front, Toytec 1/4" spacers, ECGS bushing.
    It's the same as the current Baja version. I don't know what they have changed to "fix" the problem. I've asked friends that work for Toyota motor sales and they couldn't find anything.
  17. Feb 25, 2014 at 6:47 PM
    #1657
    bjboucher
    Brad
    San Antonio, Texas
    What boosted said, they already have a truck with a lift in front. I highly doubt they changed anything in the differential for those trucks.
  18. Feb 25, 2014 at 7:02 PM
    #1658
    Yotabilly
    The Bluegrass
    I wonder what gives? Is 2" the magic number?
  19. Feb 25, 2014 at 7:55 PM
    #1659
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    No, non lifted trucks are experiencing this as well. Shitty design of the bearing is to blame.
  20. Feb 26, 2014 at 5:54 AM
    #1660
    13TRDsport
    NE PA
    if its the bearing then why is mine still making noise? Goes away in 4wd. Would dirty fluid make a difference. I have 12000 miles and the fluid was black when i installed bushing from ecgs
