OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Feb 26, 2014 at 7:48 AM
    #1661
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Could be. Did you top your fluid back off after you were done changing the bearing? I would change it and see if it does anything. Even using synthetic, you're talking less than $20, can't hurt.
  2. Feb 26, 2014 at 8:28 AM
    #1662
    Taco'09
    Taco'09 Well-Known Member
    This has been reported before by a couple of others. I'm wondering if there is not a second underlying problem? Fix one thing and the other comes to the forefront.
    As far at the bushing itself, the only things I can think of that might be related would be driving it in a bit too far so as to contact the spider gears, and getting an odd ball that has too much clearance. With the truck sitting on the ground in a relaxed position, wheels straight, grab the CV tulip at the diff and see how much relative up and down movement it has. There should be some for sure, but is it real sloppy?
    Otherwise you may have to chase the famous Taco vibes and noises problems. From your previous post it sounds like a cyclic noise and that is often typical of a bearing. What does the magnet on the diff drain plug look like? Anything other than gray goo? Also, I would not automatically rule out wheel bearings just because of low mileage. And, check your backing plates to see if they may be contacting the front discs, although this is commonly more of a scraping noise.
  3. Feb 26, 2014 at 10:35 AM
    #1663
    Taco'09
    Fortunately for you the service dept. there is now rumored to be one of the better around here, if there is even such a thing. I remain skeptical.
    My money is on them saying they have never heard of it, or some other denial, or blame it on you. Maybe if all goes really well you get a new diff and then wait for it to go bad too. Keep us posted.
    Frankly, I think that this would be one of the first mods I would do on any 2nd Gen. 4WD, stock or lifted, brand new or with some mileage. Mine went south on a low mileage stock truck.
  4. Feb 26, 2014 at 10:54 AM
    #1664
    13TRDsport
    13TRDsport Well-Known Member
    NE PA
    13 Access cab TRD Sport
    Aero Turbine 2525XL, K&N air filter, TRD Shift knob. Bilstein 5100's w\Eibach springs.
    Thanks for the reply, The bushing is flush with the carrier and not to far in. Im changing the fluid today.
  5. Feb 26, 2014 at 1:14 PM
    #1665
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    I don't know if changing the fluid completely will help, but after 30k on my odometer, my front diff fluid was just slightly gray, not black. My transfer case was still nice and golden. The rear diff was black as sin.
  6. Feb 27, 2014 at 3:43 PM
    #1666
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Based on the facts that I have:
    1. Vibration between 30-40mph, that i can feel in the gas pedal.
    2. Goes away with 4x4(actually seems to go away for a while when back in 2wd but it comes after awhile)
    I'd say this is my issue..
  7. Feb 28, 2014 at 9:01 AM
    #1667
    13TRDsport
    NE PA
    im going to try the fluid change and top off tonight. I can't figure this out for the life of me. Im very frustrated:mad:
  8. Feb 28, 2014 at 9:05 AM
    #1668
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    how did the cv shaft look when you removed it?
    did you check the wheel bearings?
  9. Feb 28, 2014 at 10:58 AM
    #1669
    13TRDsport
    NE PA
    The cv had very light wear marks but no scoring or grooves. The truck has just 12000 miles on it and if it goes away in 4wd I don't see how it would be the wheel bearing. :confused:
  10. Feb 28, 2014 at 1:55 PM
    #1670
    wildguitarman3
    wildguitarman3 New Member
    02 4x4 2.7l
    Thanks for all the helpful info. I'm having this problem on my 02.
    Is it dangerous or causing major problems if I continue to drive my truck with the faulty bearing? My vibration is pretty minor at the moment, sometimes it's really noticeable other times it disappears.
    Thanks for your input.
  11. Mar 1, 2014 at 7:37 AM
    #1671
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Never heard of a catastrophic failure occurring due to the bearing. I've driven my truck for 60k+ miles with the vibe without any issue.
  12. Mar 1, 2014 at 7:48 AM
    #1672
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Needle bearing? No.
    Wheel bearing? Yes.
    On a trip in the mountains once I ended up with a shudder on the way up a sketchy road. Got to the top and removed a speed sensor to find metal shavings. Only thing I could do was head back down for the highway. I squirted some oil in through the sensor hole and headed back down. I made it about 10 min from town when the tire locked up on the highway. I was able to pull off safely and get it towed.
    Funny thing is 2 years later in the same area the damn bearing went again. Lol had a spare this time around though.
  13. Mar 1, 2014 at 1:22 PM
    #1673
    08TRDOFFROAD
    Dan
    Beings as this whole thread is about the faulty needle bearing in the front diff, why would anyone think I was referring to anything other than that....
  14. Mar 1, 2014 at 2:46 PM
    #1674
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    My thoughts exactly, Daniel.
  15. Mar 1, 2014 at 5:58 PM
    #1675
    ImplicitlyAlberta
    David
    edmonton
    Sorry I've been subd to this thread for a bit now. Most of the discussions would start at the needle bearing and some would turn out to be issues with the wheel bearing.
    Didn't mean to confuse you guys.
    Not sorry though.:p
  16. Mar 2, 2014 at 4:41 PM
    #1676
    jedi1798
    jedi1798 Member
    Alaska
    '11 Tacoma
    The shop said my front diff is "worn out". If I replace the needle bearing with ECBS's fix, will that make my diff no longer "worn out"?
    Sorry if that question is obvious, I am not a mechanic by any means.
  17. Mar 2, 2014 at 4:48 PM
    #1677
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    ^^^Probably not worn out. lol (not lolling at you just what you were told) How many miles does your truck have? Why did you take it in? because of a vibration? Does 4wd work? I'm betting it's just the needle bearing and possibly a cv shaft.
  18. Mar 2, 2014 at 4:53 PM
    #1678
    jedi1798
    jedi1798 Member
    Alaska
    '11 Tacoma
    ^^^75000 miles. I have the "rumble strip" vibration. Driver side CV has a little play on the diff side. 4WD works.
  19. Mar 2, 2014 at 4:59 PM
    #1679
    Yotabilly
    The Bluegrass
    ^^^EGCS bearing and tool and possibly a shaft. No way would I replace the diff.
  20. Mar 2, 2014 at 5:15 PM
    #1680
    jedi1798
    jedi1798 Member
    Alaska
    '11 Tacoma
    Cool. Thanks Yotabilly. I am going to get it and see if I can fix it myself.
