OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Mar 18, 2014 at 9:26 PM
    #1741
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    Honestly, the play in my cv seemed the same, but I think that extra support keeps the cv from going crazy and giving us vibes
  2. Mar 19, 2014 at 6:37 AM
    #1742
    hilux30
    hilux30 Well-Known Member
    PEI
    '15 4Dr SB 6MT
    OTT tune 3 degree cam gear OME/Dobinson
    Just did the bushing at 145K with a new CV too, no mo vibes!.... My old school mechanic (alignment) believes that the slop (post bushing install) is too much and my seal will leak soon, I'm trying to tell him that it's 'normal'
    But it is somewhat embarrassing considering what he sees on other 'similar' set-ups, their CVs are pretty solid... :mad:
  3. Apr 1, 2014 at 7:52 AM
    #1743
    blufie
    blufie Member
    Oklahoma
    06 Quad Cab Sport 4X4
    Stereo, Running Lights, Toneau cover
    Would be willing to borrow/rent/buy a puller from anyone who doesn't need theirs, or pass it along to the next guy when I'm done -your choice. PM please and thanks!
    +1 for same issue and I am doing the wheel and needle bearings in one shot. I was surprised how much slop was there and also had a pretty "clicky" feeling when I spun the drivers side shaft by hand - felt like the spider gears were clicking into each other?!? Anyone else comment on if their driver side felt like that when turning by hand? My fluid was golden (replaced about 20K ago). It got so darn noisy people couldn't hear my hands free conversations ;-).
    Also - would be willing to borrow/rent/buy a puller from anyone who doesn't need theirs, or pass it along to the next guy when I'm done -your choice. PM please and thanks!
  4. Apr 1, 2014 at 7:03 PM
    #1744
    Skyrebel88
    Skyrebel88 Member
    Danbury ,ct
    2012 dbcd sr5
    884 with 5100 Billy's, overload leaf removed and aal added= stock uca's =ok=2 inch lift. I want to go higher though.
    Anyone who has this tool sitting idle that could rent, loan or sell the needle bearing extraction tool to me please let me know. Thank you. I just bought my lift.
  5. Apr 4, 2014 at 6:21 PM
    #1745
    blufie
    blufie Member
    Oklahoma
    Finally!! I replaced both wheel bearings and also did the needle bearing replacement
    With the nitro gear bushing.
    And NO MORE NOISE!!
    It's a pretty easy fix with a bearing and race driver, and of course the cool tool from east coast gear.
    Id like to keep the tool in case I need it, but I'd be willing to loan it with deposit. Pm me if interested.
  6. Apr 7, 2014 at 8:38 PM
    #1746
    skycruiser
    skycruiser Member
    Central Fl
    08 4x4 Tacoma
    I'm n need if anyone can help.
  7. Apr 12, 2014 at 3:00 PM
    #1747
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Finally installed the bushing. So far so good.
  8. Apr 13, 2014 at 5:47 AM
    #1748
    skycruiser
    skycruiser Member
    Central Fl
    08 4x4 Tacoma
    I had the growling noise, I thought it was the right wheel bearing problem. I ordered a new whole assembly replaced it and still have the same noise. I'm thinking it is the bearing now waiting for bushings and tool to do this replacement.
  9. Apr 13, 2014 at 9:30 AM
    #1749
    Taco'09
    Taco'09 Well-Known Member
    Hey guys. I haven't posted in a while but if you are wondering if Toyota has fixed this on new trucks the answer is no. I just purchased a '14 TRD Off Road and the bearing is loose so I will have a go at it later. Worse, the dealer I got i from had a lot of new Tacos on the lot and I spot checked 4 others (they thought I was crazy laying on the ground). They were all loose and one drooped particularly bad so it is likely going to need fixed sooner than later.
  10. Apr 13, 2014 at 5:20 PM
    #1750
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    I almost forgot what a vibe free ride was like. Till they come back, anyway. I have a tool FOR LOAN, paypal me the cost of a small Flat Rate box, you pay return shipping in same box. Will edit with exact cost tomorrow.
  11. Apr 13, 2014 at 6:35 PM
    #1751
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    $5.80 for the small flat rate box, tool fits perfectly inside too.
  12. Apr 14, 2014 at 2:13 AM
    #1752
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Thank you.
  13. Apr 18, 2014 at 6:44 PM
    #1753
    prclements
    prclements Active Member
    Columbus, GA
    07 TRD Off-Road DC 4x4 SR5 Tow
    Running boards, bed mat
    I have a 2007 4x4 offroad. At around 100,000 miles I started noticing the same grinding sound with vibration in the pedal as described by others in this thread. Over the next 30k miles the symptoms continued to grow. I was fairly certain that my issue was not related to the differential because the sound did not change when I engaged four wheel drive even though I had signs of differential issues as indicated by a leaky seal and some amount of sludge found during a recent fluid change.
    I couldn't positively identify that I had a hub bearing problem because I had no tire wobble or could not reproduce the grinding sound when I free-rotated the tire. The driver side sounded ever so slightly worse than the passenger side but nothing very major.
    I bought a preassembled hub/bearing from TW member "nj636" and replaced the driver side. Luckily this completely fixed my problem. Feels like I'm driving a new truck now.
  14. Apr 25, 2014 at 4:20 PM
    #1754
    BurnsMoto
    BurnsMoto Member
    Stephen
    Redwood City, CA
    2013 Tacoma DCLB Limited 4x4
    My truck is still under warranty and I have the vibration. There's lots of play in my CV axle. I just ordered the bushing. Next week I'm going to bring my truck into the dealer to fix the needle bearing under warranty and hand them the ecgs bushing to use instead. I'll let you know how it goes.
  15. Apr 25, 2014 at 4:31 PM
    #1755
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Be prepared for a fight. I've only heard of a couple exceptions of dealers replacing just the bearing -- typically they replace the whole diff and aren't willing to take the bearing out. Back when I tried to do this at my dealership they insisted that there was no way of taking the bearing out without cracking the diff open. Which we all know by now is BS.
  16. Apr 25, 2014 at 4:32 PM
    #1756
    BenWA
    Boston burbs
    I have a puller tool for those in need. PM.
  17. Apr 25, 2014 at 9:41 PM
    #1757
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Good luck with that....I wouldn't hold my breath if I were you...
  18. Apr 26, 2014 at 7:18 AM
    #1758
    ShawnC05
    ShawnC05 Member
    05 SR5
    Ok so I just bought a 2005 quad cab Sr5, no lifts, bells or whistles. It vibrates at highway speeds, off and on. The dealership scheduled a front end alignment and tire balancing on Monday. I just found this thread, and since I'm no kind of mechanic, can somebody give me a quick rundown of what else I should ask the mechanic to look for?
  19. Apr 26, 2014 at 8:05 AM
    #1759
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    1000 miles and vibes are back. And again, I have a puller tool for loan. PM me.
  20. Apr 26, 2014 at 9:01 AM
    #1760
    08TRDOFFROAD
    Dan
    Check to see if the vibe goes away when you engage 4wd. If it does, this is your issue. If it doesn't, something else is causing it.
