OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Jul 29, 2014 at 7:52 PM
    #1801
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Vibration only when braking?
    Have you looked at the brakes? Are the rotors warped? How do the pads look? The wear pattern can tell you a lot of what is going on.
    Do you feel anything in the steering wheel when you feel the "rumble" while braking?
    Keep us posted.
  2. Jul 29, 2014 at 7:57 PM
    #1802
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    This^
    I'm sure you know the ABS feeling but if you are low on fluid or brake pad issues they can turn on randomly.
  3. Jul 29, 2014 at 9:00 PM
    #1803
    Aloe
    Aloe Well-Known Member
    05 SWB TRD Sport access cab 4x4
    URD Short throw Fisher Plow
    carrier bearing 1.5 years ago. New brakes & suspension last fall. New lf wheel bearing assembly from nj686. Installed late June...I knew it was going for ~10months. NYS inspection 1/2/14 I was told about play in the hub & it was ok to pass big needed to be replaced soon.
    The noise/vibration is a muted & short lived version of driving with a very worn wheel bearing.
    Lf bearing replaced @96k under warranty. Then again 195k (nj686's hub assembly).
    Rf bearing replaced @146k by dealership @$700.
    New Michelin ltx's in July last year. Rotated in march
    I really don't know what it is
  4. Jul 29, 2014 at 9:04 PM
    #1804
    Aloe
    Oh no vibration in steering wheel. Pads & rotor looked good on drivers side last month. Rotors do. Not feel warped...
  5. Jul 29, 2014 at 9:09 PM
    #1805
    DefyInertia
    DefyInertia Saratogian
    Nate
    NorCal
    '05 DCLB 4x4 SR5#8 (white)
    Toytec Ultimate: ~3" up front via coil overs, LR UCAs, and SB delete; 2+ out back with AAL and new shocks. Leer cap, padded sleeping platform in bed
    Selling the bearing removal tool. $45 shipped to lower 48. Will ship elsewhere as well.
  6. Jul 30, 2014 at 9:41 AM
    #1806
    nj636
    Kev
    Jersey
    when you say new brakes, is that pads and rotors? were the rotors cut?
    did you check the RF wheel bearing this time around? You've got 50k on it now.
    where does this noise sound like it's coming from and when did it start happening?
    pulsating/vibrating through the brake pedal indicates something going on with the brake system or wheel bearing.
    hoping we can help you diagnose this problem.
  7. Jul 30, 2014 at 3:03 PM
    #1807
    Aloe
    brand new pads & rotors! its very similar to a worn wheel bearing...except, I dont hear it unless i apply the brakes bw 25-35 mph. the rf may be going too...i was hoping id get closer to 90k
    other than that annoying noise, I dont know what to do or look for visually.
    the only other thing I can think is that the new LF hub/bearing assembly is bad....the noise was quiet but present after the install.....while it has increased a bit over the last month, I dont hear/ feel it getting any worse.
    btw, the pedal doesnt pulse....but you can feel the noise in the pedal as you brake....i have a lot more driving to do the next month so ill keep an eye on it
  8. Jul 30, 2014 at 7:31 PM
    #1808
    Count Coconut
    Count Coconut Active Member
    Len
    Toronto
    2006 TRD Sport
    Softopper Bilstien 5100 (4) Custom add a leaf pack Custom suspension rubbers (front and rear) Custom bed racks Custom roof rack Custom air breathers (5) Water proofed exterior electrical connectors Custom rock sliders Custom bed rail mounts for Hi Jack extreme, shovel, axe Wild Country Roof Top Tent ECGS front differential bushing Custom Overland 4'x8' trailer Onboard video system Modified exhaust (back end only)
    Bought the busing from ECGS and new c/v shaft from Cardone. Installed and vibration is all gone!!! Thanks to this thread! MAN that was annoying!
  9. Jul 31, 2014 at 4:22 PM
    #1809
    thekidcatcher
    thekidcatcher Well-Known Member
    Corpus Christi, TX
    05 TRD offroad SR5
    Legs- --Helo rims --KM3 285/75/R16 --Bilstein 5100 in front with OME 886 --Dakar with extra leaf --Total Chaos UCA's --5165's Bilstein in the rear Electronics- --Warn M8000 w/ Warn wirless remote --Cobra 29LTD CB, --12in sub with alpine amp , --Dual Battery, --Warn Air compressor --URD MAF sensor, --touchscreen cd player hooked up to front and rear cameras Armor- --All-Pro offroad front/rear/rocksliders --AP skid plate, diff armor Cajones- --JBA headers, midpipe, exhaust --Safari Snorkel --4.56s ECGS Misc- highlift jack --UWS toolbox --u bolt flip kit --Tepui Kukenam Custom- --in dash inverter --on-board shower system --dvd anytime mod --custom bed rack and tiregate.
    Lucky!! lol, congrats.
  10. Aug 1, 2014 at 6:38 PM
    #1810
    fishead
    fishead Member
    I have all the symptoms described in here except my noise doesn't stop in 4h. Anyone else have a bad needle bearing that's noise didnt go away in 4h? I changed my passenger wheel bearing today with no luck, driver side feels tight.
  11. Aug 1, 2014 at 6:42 PM
    #1811
    nj636
    Kev
    Jersey
    Both wheel bearings felt tight on my truck until I rebuilt the front end and found that the passenger side was burnt.
    The needle bearing in question is in the driver side, was your passenger side wheel bearing bad?
  12. Aug 1, 2014 at 10:32 PM
    #1812
    fishead
    fishead Member
    I left out a lot of details.
    I thought it was the right wheel bearing, err hoped it was... I replaced the right wheel bearing because some of the noise let up when going around sweeping right turns which unload the right side, in left turns the noise was louder. Plus, 4h did not make the vibs stop.
    However, a few weeks ago I put on ome 883 coils for about 1.5" up front and the noise is now louder than before so probably the needle bearing.. I was mainly curious if anyone else had luck with ecgs bushing when 4h didn't stop the noise/vibs, or if I might have bigger issues?
  13. Aug 2, 2014 at 6:50 AM
    #1813
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    ^ Noise going away on the sweeping right turn is also consistent with the needle bearing. And I recall at least one person, maybe two, where it didn't go away in 4Hi but the bushing solved their problems.
  14. Aug 4, 2014 at 7:46 PM
    #1814
    Lost Bushman
    Lost Bushman Member
    Arizona
    2015 TRD Offroad
    Hey guys, is it possible to have this issue with NO LIFT? '05 Tacoma, just went from 265/70-16's to 265/75-16's, but no lift on truck. Noticed the thumping and vibration almost immediately after getting the new tires.
  15. Aug 5, 2014 at 6:17 AM
    #1815
    Count Coconut
    Len
    Toronto
    2006 TRD Sport
    Absolutely. Most tacoma's have the worn needle bearing / cv shaft, but it is not really noticeable until you do something like a front lift. That is why it's so common to see the problem discussed on leveling / lifting forums.
  16. Aug 5, 2014 at 8:06 AM
    #1816
    Lost Bushman
    Lost Bushman Member
    Arizona
    2015 TRD Offroad
    Ok, so is it safe to assume that the bushing from East Coast Gear will remedy the problem? Is it necessary to replace the CV shaft as well?
    Here's video of my front end, filmed yesterday, you can hear the clicking at about 20 seconds in. Is this my problem?
    http://youtu.be/7fGGl9H8HCg
  17. Aug 5, 2014 at 9:19 AM
    #1817
    DonL
    DonL Well-Known Member
    Don
    Prescott, AZ
    Tacoma TRD
    Monster Exhaust, Shell, 5100's all around, Airlift airbags, Hankook Atm, K&M air filter
    Does the sound go away when you shift to 4wheel hi and come back when shifting back into 2wheel hi? If yes, you have it. When I had the "problem" it was a vibration not a clicking sound as you have. As to the CV shift you can check it when you get it out for scoring on the input part of the shaft where it engages the needle bearings.
  18. Aug 5, 2014 at 11:34 AM
    #1818
    Lost Bushman
    Lost Bushman Member
    Arizona
    2015 TRD Offroad
    Yes, it seems to go away when I engage 4H. I also have a noticeable vibration in the wheel that corresponds with the clicking sound in the video. Actually, you can't even hear the clicking in the cab. I only noticed it AFTER I watched the footage from the camera.
  19. Aug 5, 2014 at 11:36 AM
    #1819
    Lost Bushman
    Lost Bushman Member
    Arizona
    2015 TRD Offroad
    Well, I'm buying if anyone has that removal tool they want to sell. OR give me some measurements so I can build one myself for a 1/6th the price.
  20. Aug 5, 2014 at 2:54 PM
    #1820
    JasonMcvic
    JasonMcvic Well-Known Member
    looking to borrow the removal tool.
    Anyone in the vancouver, bc area have one i can borrow/rent for the afternoon?
    Jason.
