OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Aug 5, 2014 at 3:38 PM
    #1821
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Outer diameter is 1.6 in. Inner is 1.4 if I find the time I'll post pics of the tool I made.
  2. Aug 5, 2014 at 4:05 PM
    #1822
    Lost Bushman
    Lost Bushman Member
    Arizona
    2015 TRD Offroad
    Stone Soup Metalworks sliders
    Sweet.
  3. Aug 6, 2014 at 6:06 AM
    #1823
    Count Coconut
    Count Coconut Active Member
    Len
    Toronto
    2006 TRD Sport
    Softopper Bilstien 5100 (4) Custom add a leaf pack Custom suspension rubbers (front and rear) Custom bed racks Custom roof rack Custom air breathers (5) Water proofed exterior electrical connectors Custom rock sliders Custom bed rail mounts for Hi Jack extreme, shovel, axe Wild Country Roof Top Tent ECGS front differential bushing Custom Overland 4'x8' trailer Onboard video system Modified exhaust (back end only)
    You will have to replace the CV shaft when you do the bushing. The genius engineer at Toyota that replaced the 1rst generation bushing with a needle bearing didn't account for the lack of room, so there is no inner race on this needle bearing. It rides directly on the cv shaft. If you replace just the bushing it will help, but the wear is on both parts. $100 shipping included if you buy the Cardone cv shaft from e-bay. Great deal! (better if you didn't need it though!) Buy a new differential output seal too while your at it. Cheaper to buy with the ecgs bushing then at the dealer.
  4. Aug 6, 2014 at 2:32 PM
    #1824
    thekidcatcher
    thekidcatcher Well-Known Member
    Corpus Christi, TX
    05 TRD offroad SR5
    Legs- --Helo rims --KM3 285/75/R16 --Bilstein 5100 in front with OME 886 --Dakar with extra leaf --Total Chaos UCA's --5165's Bilstein in the rear Electronics- --Warn M8000 w/ Warn wirless remote --Cobra 29LTD CB, --12in sub with alpine amp , --Dual Battery, --Warn Air compressor --URD MAF sensor, --touchscreen cd player hooked up to front and rear cameras Armor- --All-Pro offroad front/rear/rocksliders --AP skid plate, diff armor Cajones- --JBA headers, midpipe, exhaust --Safari Snorkel --4.56s ECGS Misc- highlift jack --UWS toolbox --u bolt flip kit --Tepui Kukenam Custom- --in dash inverter --on-board shower system --dvd anytime mod --custom bed rack and tiregate.
    It was the damn bearing. lol
  5. Aug 11, 2014 at 5:45 AM
    #1825
    topknot
    topknot Member
    MO
    2010 TRD OR SR5
    Found them on Ebay. Is it part number 66-5134, or 66-5235 that is needed?
    2010 Tacoma TRD OR
    Thanks.
  6. Aug 11, 2014 at 8:11 AM
    #1826
    nd4spdbh
    SoCal
    Hey all here is my removal tool i made.
    Simply a nice sized lag bolt. I took a piece of flat stock 3/4in wide metal and drilled a hole in it, then with a file squared it off and elongated the square so that the piece could be angled to fit through the bearing. I also had to bevel the back edge so it would fit in flat. The extra washer behind the plate and head of the bolt is just there for extra support. Then simply a big piece of aluminum to span the outer case of the diff.
    Installation of the tool is easy, just angle the main piece slide in and pull on the bolt to seat everything, put piece of aluminum on and start tightening the nut... pulled the bearing out very easy and no damage. Best part of doing it this way, is you are not sticking a piece in the diff hoping it wont fall in.... the piece can never fall in as they are all captured by the end of the bolt.
  7. Aug 11, 2014 at 12:41 PM
    #1827
    Lost Bushman
    Lost Bushman Member
    Arizona
    2015 TRD Offroad
    WIN. Thanks!:bananadance::bananadance::bananadance::bananadance::bananadance::bananadance:
  8. Aug 13, 2014 at 1:41 PM
    #1828
    Turbobuick
    Turbobuick New Member
    Sc
    2006 double cab tacoma 4x4
    3inch lift, rear leaf spring helper, rear sway bar. Trans temp gauge
    Same issue front diff. At 76k miles. Front wheel bearings were replaced at 60k. I really hope everyone has complained to toyota about this 1-800-331-4331 as of 8/13/14 they have no record that there is a problem with the Tacoma's front diff. or wheel bearings. However, George from south east toyota enlightened me that the rear diff has issues as well. I received the run around from Dave Edwards Toyota in Spartanburg SC and was hung up on twice "while being transferred" never was able to speak with that service tech. This is my first and last toyota.
  9. Aug 13, 2014 at 1:58 PM
    #1829
    TacoLlama
    TacoLlama Well-Known Member
    R.I.
    2019 SR5 DCSB
    I am pretty sure as long as I can swing a wrench a dealer will never touch my truck unless they pry it from my cold dead hands.
    That being said.Once I did the ECGS bushing and sorted my driveline angles out a bit better the truck drives great and the cv play at the diff is gone.I did slightly modify the suspension.Not my first time doing that so I did expect some consequences.
  10. Aug 13, 2014 at 4:58 PM
    #1830
    Turbobuick
    Sc
    What steps did you take to make the drive line angles better? Also is that necessary on one with just a 3 inch lift.
  11. Aug 13, 2014 at 6:13 PM
    #1831
    nd4spdbh
    SoCal
    Its not a bad design... just not a design that is meant to be changed (IE by lifting)
  12. Aug 14, 2014 at 5:31 AM
    #1832
    Turbobuick
    Sc
    I work with a fellow that has a bone stock 2010 taco same issues no lift. Driver side wheel bearing and front diff issue. He's like myself no off roading just back and forth to work.
  13. Aug 14, 2014 at 5:51 AM
    #1833
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    Update on my ECGS bushing, After 30,000 on the bushing, I changed the oil and it was clear as when i put it in. Still quiet as can be.
  14. Aug 15, 2014 at 7:37 AM
    #1834
    Count Coconut
    Len
    Toronto
    2006 TRD Sport
    Thanks for that update! I was wondering if anyone had a ton of KM's on it. Mine has only 560 km's.... so far so good. Hope to report back after 100,000.
  15. Aug 20, 2014 at 6:19 PM
    #1835
    Hillclimber
    Hillclimber Well-Known Member
    Justin
    NW Iowa
    2012 Baja
    I just did the 30,000 mile front, rear and transfer case gear lube change and noticed my drivers side cv joint is very loose. Up and down and in and out. Mine is stock with 32000 miles and haven't even had it off road yet. That's bullshit. Calling the dealership in the morning to have it "fixed" until I'm able to get that other bushing. I love this truck but some things are just straight up shit.
  16. Aug 21, 2014 at 7:22 AM
    #1836
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    11 DC TRD OR 4x4 Pyrite Mica
    Great! Keep us posted. I've been waiting to see WHEN a Baja truck would have this problem since they are lifted by the factory, and because of that no way they can deny the issue. I assumed there is nothing different with the front Diff. but I want to know for sure.
  17. Aug 22, 2014 at 1:29 PM
    #1837
    Hillclimber
    Justin
    NW Iowa
    2012 Baja
    Well here's the update, the dealer looked at my truck today and said that was the normal amount of play. He said since the left side shaft is so much shorter than the right side it needs the extra play to compensate for wheel travel. I think not. Now I don't know if I should keep on them about this or just buy the aftermarket bushing on my own. It would be nice to actually be able to use your warranty. I didn't get the result I wanted on the drive line vibration TSB either.
  18. Aug 22, 2014 at 1:46 PM
    #1838
    nd4spdbh
    SoCal
    Dealer ain't going to do shit... Buy the 60 dolla bushing and be done with it.
  19. Aug 22, 2014 at 7:20 PM
    #1839
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    See I have this same thing. Cv axle seem loose a all hell. But......I have not had any vibration issues or wear on the cv axle. ( I tore a boot offroading). No fluid leaks either.
    I have been up and down this thread for a good year and a half and I am still waiting for this vibe so I can jump to the replacement. I actually acquired an ecgs bushing from an offroad buddy that lost his truck to a fire. Still no vibes/issues no bushing change. I've had the truck lifted for about 3 years.
  20. Aug 22, 2014 at 7:43 PM
    #1840
    nd4spdbh
    SoCal
    i have a suspicion. Do you have aftermarket UCA's
    I think that with a lift, aftermarket UCA's dont require the LCA to be at its extreme ends of adjustment which makes it to where the track width of the truck is just a smidge wider causing the pressures on the cv to change JUST enough that vibes dont happen.
