OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Aug 22, 2014 at 7:43 PM
    #1841
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    I had my dealer look at the excessive play in my CV about a month ago while other work was being done. I got the standard "it's normal". They even took me back to the garage and showed me an FJ with 8000 miles on it and it had the same play with the CV/axle.
  2. Aug 22, 2014 at 9:43 PM
    #1842
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Nope. Full stock cept the spindle. The cv axles where not that far off stock after the lift, up until I replaced the coilovers.
  3. Aug 23, 2014 at 7:30 AM
    #1843
    Hillclimber
    Hillclimber Well-Known Member
    Justin
    NW Iowa
    2012 Baja
    I don't have any vibration or noise coming from it either, I just happened to notice how loose it was and started checking the forum. Next time I go to the dealer I'm going to crawl under everything on the lot to compare, if they are all all loose I'm not worrying about it. Nothing is leaking.
  4. Aug 23, 2014 at 8:33 AM
    #1844
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    They all will be loose guaranteed. Its just the design of the little needle bearing. If you don't have the vibes nothing to worry about. If you do the bushing will fix it plain and simple.
  5. Aug 24, 2014 at 3:31 PM
    #1845
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    Just FYI. The bushing helps tighten up the play a little, but doesn't tighten up to no movement. There is still play with the ECGS bushing. I haven't had any issues though.
  6. Sep 5, 2014 at 1:10 PM
    #1846
    cleung
    cleung Well-Known Member
    Saskatchewan Canada
    07 TRD offroad DCSB
    Bilstein 5100, 265/75/16 tires, Extang solid fold
    another happy customer. I had the exact symptoms, ordered the bushing (arrived in Canada in one day) had it installed today and vibrations are gone.
  7. Sep 8, 2014 at 3:34 PM
    #1847
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I have 2014 with 33,200 miles. I started complaining via email with my dealership service manager at 12,000 miles - continuing the same email thread with him month after month. Today they offered to replace the front differential and left cv axle at no expense to me. That haven't agreed to insert the ECGS bushing yet at the time of the swap, but I've ordered it and if necessary I'll install the bushing when I get home after I get the truck back. At least I'll have a new axle and differential to install it in - free.
    Better than nothing I guess.
  8. Sep 10, 2014 at 7:05 PM
    #1848
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    UPDATE - my dealer is installing my provided ECGS bushing in a new differential with a new from left CV axle in the morning!!! Dropped truck off tonight.
    I should buy a lottery ticket.
  9. Sep 10, 2014 at 8:41 PM
    #1849
    nd4spdbh
    SoCal
    make sure they install it right.... its 1/4 in longer and if seated all the way like original bearing it will be hitting the diff itself.
  10. Sep 11, 2014 at 4:59 PM
    #1850
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Just picked up truck and drove home. It is a Stunning Improvement!!!
  11. Sep 11, 2014 at 5:19 PM
    #1851
    nd4spdbh
    SoCal
    another happy customer. ECGS has their shit together, and this bushing does the trick
  12. Sep 12, 2014 at 9:11 AM
    #1852
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    spread the word mayb others can get this fixed properly as well my 2012 got a new diff at 22000k and its vibrateing again
  13. Sep 13, 2014 at 9:03 PM
    #1853
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Is your truck lifted?
  14. Sep 13, 2014 at 9:45 PM
    #1854
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Yes. 2.5"
  15. Sep 15, 2014 at 7:30 AM
    #1855
    HB Taco
    Curt
    I may have missed some of this this thread but I think your only the 2nd person to have the dealer install the ECGS bushing. They didn't give you crap about being lifted? unless they sold it to you that way. I like that dealer. I wish it wasn't so far away.
  16. Sep 15, 2014 at 12:28 PM
    #1856
    Count Coconut
    Count Coconut Active Member
    Len
    Toronto
    2006 TRD Sport
    Softopper Bilstien 5100 (4) Custom add a leaf pack Custom suspension rubbers (front and rear) Custom bed racks Custom roof rack Custom air breathers (5) Water proofed exterior electrical connectors Custom rock sliders Custom bed rail mounts for Hi Jack extreme, shovel, axe Wild Country Roof Top Tent ECGS front differential bushing Custom Overland 4'x8' trailer Onboard video system Modified exhaust (back end only)
    I spoke with ECGS directly and they told me their no one buyer is Toyota dealers. Said that any are installing one of their bushings with every Toyota Factory lift kit. (This conversation happened only 3 months ago) Hope you can find one of these dealers! because mine sure as crap was not one!!!
  17. Sep 15, 2014 at 1:17 PM
    #1857
    nd4spdbh
    SoCal
    toyota has a factory lift kit?!?!
  18. Sep 15, 2014 at 4:09 PM
    #1858
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Probably just the toytec kit. Not "Toyota".
  19. Sep 15, 2014 at 4:56 PM
    #1859
    DSMissed
    DSMissed Well-Known Member
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    3" lift with adjustable shocks and AAL, TPS disabled, anytime locker mod, MOOG greasable ball joints and adjustment pins, URD M3 s/c, Pioneer nav headunit, xplod 1000w amp, 10" infinity sub, tinted windows, lightly tinted tails, color matched front grill with blacked out emblem. Do battle scars count as mods?? =D
    Looks like I'm ordering this bushing tonight. Been dealing with the vibrations for 50k miles now.
    Anyone have the removal /install tools they would be willing to pass on? I'd send them to the next person in need after. Pm me
  20. Sep 16, 2014 at 3:54 AM
    #1860
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I can send you mine. PM me your address
