OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Oct 21, 2014 at 6:32 AM
    #1901
    tacoholic05
    tacoholic05 Well-Known Member
    05' 4x4
    a pry bar should work just fine, you have to spin it a little at a time to find the sweet spot and it will pop right out. People using slide hammers and cables are not rotating the cv and fighting the "c" clip in the wrong position. it's must easier during the install because you can see and align the clip so the opening is facing downward.
  2. Oct 21, 2014 at 11:52 AM
    #1902
    je3169
    je3169 Well-Known Member
    Cincinnati OH
    2014 Access Cab TRD Sport
    2" Front, 2" Back, Opti-Coat Pro, Toyo Running Boards, Kenwood DNX891HD
    Thanks guys :thumbsup:
  3. Oct 21, 2014 at 1:02 PM
    #1903
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    and dont keep constant pressure on it while spinning, push it in, rotate 1/6th of a turn and try again. if you keep constant pressure the clip can never drop down allowing easy removal.
  4. Oct 21, 2014 at 1:03 PM
    #1904
    tacoholic05
    05' 4x4
  5. Oct 21, 2014 at 5:20 PM
    #1905
    troublemaker
    troublemaker Well-Known Member
    Mikr
    Ontario
    V6 Manual
    My 2014 had this issue right after I put my 3" lift on it. I haven't noticed the noise for a while. The truck only has 15000km on it. Now granted the mud grapplers make a ton of noise but I can't feel it in the floor board.
    Should this be something to be concerned about with the noise going away?
  6. Oct 22, 2014 at 5:57 AM
    #1906
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    What'd you guys use to install the differential oil seal? The big ring one that goes on outside by axle?
  7. Oct 22, 2014 at 6:05 AM
    #1907
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
  8. Oct 22, 2014 at 7:05 AM
    #1908
    Pete0247
    Pete0247 Well-Known Member
    Kentucky
    2007 BSP DCSB TRD Off Road
    5000K headlights, 3000K fogs, fog mod, 2014 LED tail lights with LED reverse lights, interior LED dome/map, and license plate lights, Pioneer radio, WeatherTech window visors, 20% tint, bed door locks, Mobil 1 synthetic fluids throughout
    Sub for later
  9. Oct 23, 2014 at 6:44 AM
    #1909
    MTopp
    05 SR5 4x4
    Thank you very much!
    If I'm replacing my CV axle also, do I need to do more than only remove the two bolts from LCA?
  10. Oct 23, 2014 at 7:09 AM
    #1910
    tacoholic05
    05' 4x4
    no, with the brake line bracket, sway bar, and two lower ball joint bolts, you should be able to lift up and knock the cv axle out and then swing the whole assembly to the rear of the wheel well and have plenty of room to work. after the frame was on jacks, i found it much easier to jack up the assembly so there's less binding.
  11. Oct 23, 2014 at 7:46 AM
    #1911
    MTopp
    05 SR5 4x4
    Okay, but the CV axle will just come out of the spindle side, or do I have to try and get it out using a pry bar?
  12. Oct 23, 2014 at 7:52 AM
    #1912
    tacoholic05
    05' 4x4
    thread the axle nut to the end and I used a block of wood to protect it. hit it till it's free from the spindle and lift the whole assembly out & up. a second person is a big help with this step. there is a good youtube video with a guy doing it on his FJ - same basic principle with our trucks.
  13. Oct 23, 2014 at 8:41 AM
    #1913
    nd4spdbh
    SoCal
    also throw the bushing in the freezer for a while.... like when you start working on the truck pop it in the freezer and pull it out just before you are ready to put it in... then a coupla taps and she will go right in.
  14. Oct 24, 2014 at 8:09 AM
    #1914
    Lou Slink
    Lou Slink I like daags...
    Catskill, NY
    2013 TRD OR DCSB
    OME 886's, Total Chaos UCA's, Dakar's, BFG KO2's on Method Race Mesh Wheels, Bunch of All-Pro Goodies, Warn Zeon 10S Winch
    I just ordered the replacement bushing from ECGS and I'm qondering how long I can expect it to last. Just a little worried since it's replacing the needle bearing with just a bushing. Won't this wear out rather quickly? ('13 TRD OR DCSB by the way)
  15. Oct 24, 2014 at 9:28 AM
    #1915
    PUBCRAWL
    PUBCRAWL MIGHTY TACO
    Ontario, Canada
    Tacoma TRD DCLB
    ECGS states it's a lifetime bushing on their install video.
  16. Oct 24, 2014 at 9:30 AM
    #1916
    tacoholic05
    05' 4x4
    it should out last the life of the vehicle, if not, it's only $60. I will prolly have to replace higher priced items before the bushing fails.
  17. Oct 24, 2014 at 9:33 AM
    #1917
    SLOBRA
    SLOBRA LET IT EAT®
    Albuquerque, NM
    2012 DCSB 4x4 TRD O/R
    For what it's worth this guy had 15,000 on his in December 2012:
    http://www.tacomaworld.com/forum/2n...nstall-fix-diff-bearing-vibe.html#post6130994
  18. Oct 24, 2014 at 9:34 AM
    #1918
    Lou Slink
    Catskill, NY
    2013 TRD OR DCSB
    Good point. Thanks, gents!
  19. Oct 24, 2014 at 9:35 AM
    #1919
    Lou Slink
    Catskill, NY
    2013 TRD OR DCSB
  20. Oct 24, 2014 at 7:42 PM
    #1920
    Toyotamudbogs
    Toyotamudbogs Well-Known Member
    Devin
    White Springs , FL
    06 Tacoma 4x4, 4 door sr5
    Tintedwindows,Rockforfosgate amp 2 10" sub , fire dept radio,Rock sliders, Body Armer front Bumper, CB, 3'' EZ leveling kit, fog light mod, beep on lock mod, front duallys rigid led lights, rigid led flasher kit
    Real quick guys I have the ECGS bushing . and I'm trying to pull it out with the tool I made out of all thread .
    The bushing that we are pullen out . the bearings or spline gear that is just behind the bushing that we are changen out is it suppose to move around some . If hall can get back with me that be great. This is my DD so I need it back tonight .
