OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Nov 3, 2014 at 5:11 AM
    #1941
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    somewhere in this thread there's a diagram or spec on how far to install the seal. You don't bottom it out.
  2. Nov 3, 2014 at 11:25 AM
    #1942
    je3169
    je3169 Well-Known Member
    Cincinnati OH
    2014 Access Cab TRD Sport
    2" Front, 2" Back, Opti-Coat Pro, Toyo Running Boards, Kenwood DNX891HD
    ok thanks I will start searching
    Thanks John
  3. Nov 3, 2014 at 1:34 PM
    #1943
    je3169
    Cincinnati OH
    ok just heard back from Chase if anyone has this question the seal goes flush with the housing (so I pushed it in to far) back under the truck I go.
  4. Nov 3, 2014 at 5:24 PM
    #1944
    GTABurnout
    GTABurnout Well-Known Member
    Tucson AZ
    2012 Tundra Crewmax Rock Warrior TRD SC
    Icons, TRD Supercharger, TRD Exhaust, TRD Intake
    If this is common at 30mph I think my issue is some thing else. I get vibs bad around 50-70. Never as slow as 30.
  5. Nov 4, 2014 at 7:38 PM
    #1945
    hogkiller
    hogkiller Active Member
    Joe
    Belle, Mo.
    07 SR5 Long Bed
    I picked up an 07' (stock no lift) and put some 265 75 16 BFG's on it. I noticed a little steering wheel shake so i climbed under and tadah! my drivers side CV shaft has alot of play at the diff. so I am gonna order the bushing and tool from ECGS. I also am considering replacing the CV shaft while I'm in there. Here is my question this my daily driver ( 60 miles per day ) is it gonna hurt anything if I put a couple of hundred miles on it before this gets fixed? the truck has 122,000 miles on it.
  6. Nov 5, 2014 at 4:57 AM
    #1946
    DonL
    DonL Well-Known Member
    Don
    Prescott, AZ
    Tacoma TRD
    Monster Exhaust, Shell, 5100's all around, Airlift airbags, Hankook Atm, K&M air filter
    No,if you're going to replace the CV shaft. Driving may scar the bearing surface on the input shaft. You'll have to check when you tare it down. I had to change mine with only a couple hundred miles after my 2" lift and the vibration started.
  7. Nov 5, 2014 at 12:53 PM
    #1947
    Twatwaffles
    Twatwaffles Well-Known Member
    I know this is an older post, but the CV's are the same length. Not only that, a CV shouldn't have 'play' between the shaft and a bearing to compensate for wheel travel. That dealer is full of shit.
  8. Nov 7, 2014 at 9:28 AM
    #1948
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    I have had the bearing for a few months but haven't had the time to put it in. I can say cold does make the vibration worse. Hopefully putting it in tomorrow :D
  9. Nov 7, 2014 at 10:32 AM
    #1949
    PUBCRAWL
    PUBCRAWL MIGHTY TACO
    Ontario, Canada
    Tacoma TRD DCLB
    Exactly the same situation with me.
    Cold day today and it seems a lot worse.
    It will be another couple of weeks before I can install the bushing in my truck.
  10. Nov 8, 2014 at 10:24 AM
    #1950
    je3169
    Cincinnati OH
    Guys i replaced the drivers side bearing in the front dif and am putting it back together i am at the point that i am installing the new seal and there is a spring (like a pen spring but round ) where does that go??i think it goes on the inside of the new seal can someone conferm this for mw.
    Thanks John
  11. Nov 8, 2014 at 10:28 AM
    #1951
    NPulver
    NPulver Active Member
    Black Hills
    10' DC Tacoma TRD
    ProComp 3 inch Lift, 255/85/16
    Yes. It goes on the inside of the seal.
  12. Nov 8, 2014 at 10:28 AM
    #1952
    ZenkaiTaco
    ZenkaiTaco Well-Known Member
    Utah
    11 DCSB TRD OR
    Yes it's for the seal. The inside lip.
  13. Nov 8, 2014 at 10:31 AM
    #1953
    je3169
    Cincinnati OH
    Awesome, that's what I was thinking, thanks for the confirm on that!
    Also thanks for the pic
  14. Nov 10, 2014 at 7:42 AM
    #1954
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    Had a garage do the install last week. They charged 1.8 hrs which included a tire rotation which I think is not bad at all. So far vibe is 100% gone.:kona:
  15. Nov 14, 2014 at 5:56 AM
    #1955
    NPulver
    Black Hills
    10' DC Tacoma TRD
    Had an appointment the with dealership yesterday about the growling/vibrations coming from my tacoma (2010 TRD with 39k miles). They were able to duplicate the problem and opened a case with Toyota corporate about it. Toyota corp came back with a response of "Its a common characteristic of the truck, and hes not the only one."
    Toyota corp advised no repairs as its "normal". I argued/talked to the service guy and technician (super nice guys) and was advised to change out my diff fluid to 75w140. They said chances are it wont help anything, but atleast it'll show toyota corp that im trying recommendations to solve the issue. Was advised that if its still growling/vibrating in a month or so, to come back (after the diff fluid change).
    Guys were super nice about it, thinking the next time i bring it in, they will push to get something done. My main concern was my warranty is up in 2 months and would hate for my diff to go bad in 3 months and be my problem. (hence why they advised i come back in a month if its not solved)
    Told the tech about the ECGS bushing, though that was cool. He was also saying the tundras have the same issue (he has one with the issue) and was curious if they made the bushing for those.
    Sorry for the long story, figured i would throw it out there though.
  16. Nov 14, 2014 at 6:30 AM
    #1956
    tacoholic05
    tacoholic05 Well-Known Member
    05' 4x4
    I put Royal Purple in the diff after changing the bushing. Works good but I have no reference to whether RP would help without the ECGS bushing.
  17. Nov 15, 2014 at 10:45 AM
    #1957
    americanrancher
    americanrancher Active Member
    Ben
    Oregon
    07 Tacoma 4X4 5100's BFG KO's
    5100's, 265 BFG KO's, not lifted, daily driver
    You are going to waste your money and time just so you can get more of a run around from Toyota. AND you won't solve the problem! So solve the problem once and for all and put the ECGS in and be done with it. BTW the Tundra dif is the same as the Tacoma with the same problem, and can be solved with an ECGS as well surprise. Toyota wanted me to put a whole new dif in my truck but was going to give me a discount of $1000 on the $3000 job, very nice of them don't you think? I had an independent shop put the ECGS in for me and changed a wheel bearing and was done for less than $500. Working great for 30,000 miles since. Toyota is nuts about this issue and is inconsistent, they have allowed dealers to put the ECGS in to solve the problem. Check out previous posts.
  18. Nov 15, 2014 at 11:46 AM
    #1958
    americanrancher
    Ben
    Oregon
    Mine failed without a lift. Just a matter of time and use. If you have the problem AND you WILL, just put the ECGS in and move on.
  19. Nov 15, 2014 at 11:52 AM
    #1959
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    10,000 Miles now on my ECGS bushing - No Noise or Roaring
  20. Nov 17, 2014 at 8:03 AM
    #1960
    ECGS
    ECGS Well-Known Member
    Chase
    RALEIGH
    Yes we make the Tundra bushing also http://eastcoastgearsupply.com/i-18979362-toyota-9-reverse-clamshell-bushing.html The problem is actually more common in the Tundras then the Tacomas. The Tundras develop the growl problem much early and with no lift. Toyota has a TSB for it http://eastcoastgearsupply.com/attachment/112249-TSB 0121-08 T9R Front diff growl.pdf but most dealers will not fix it. We just did a local one. He went to 3 dealers all wanted to charge in excess of 3k . We Fixed for less than $200. It was a bone stock Tundra 70k mileage.
