OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Nov 17, 2014 at 6:23 PM
    #1961
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    It's amazing they are replacing the entire diff.
    wait, nevermind.. it's a dealership :facepalm:
  2. Nov 20, 2014 at 7:46 AM
    #1962
    tacoglock19
    tacoglock19 Well-Known Member
    Jawja
    2019 Nissan Frontier SV V6 4x4
    Stock as shit!
    I can answer this, it is a resounding NO. I run RP as my fluid for everything and I do not have the bushing. My vibration/growling is terrible. My ECGS bushing will be here tomorrow. Can't wait to put it in and get rid of this shit. I love my Tacoma but I hate the vibration....
  3. Nov 20, 2014 at 7:51 AM
    #1963
    tacoholic05
    tacoholic05 Well-Known Member
    05' 4x4
    its settled....only way to eliminate vibe is ECGS bushing
  4. Nov 20, 2014 at 8:03 AM
    #1964
    tacoglock19
    Jawja
    Stock as shit!
    I will come back and agree with you on Monday after mine is installed. :)
    EDIT: Also, I think it is a damn shame that Toyota doesn't acknowledge this problem. Oh well, they are too busy improperly designing brakes and gas pedals to worry about a problem like this right?
  5. Nov 21, 2014 at 6:02 AM
    #1965
    ECGS
    ECGS Well-Known Member
    Chase
    RALEIGH
    DO NOT RUN ROYAL PURPLE IN YOUR DIFFERENTIALS!!!!!!!!!!!!!!
    Amsoil ok
    Mobil one semi ok
    Red line ok
    OK being I have not noticed adverse effect from their use but also see no benefit.
    Regular Dyno oil better and cheaper then above products for differentials.
    Water, contaminants, and heat kill differentials. Changing your fluid often will aid in diff life far more then the product selected.
    Running a regular dyno oil and changing it every 50k or every time the diff gets submerged is the best thing for you differentials and it does not cost a fortune. Recomend:
    Lucas 85w140 temps above 0 degrees
    lucas 80w90 temps consistently below 0
    If you do not agree about Royal Purple go drive your vehicle for 15 minutes and then drain the oil and feel it in your hand. It will be extremely thin and feel like slick water. It is detrimental to the gear as it provides no cushioning and will not cling to bearings and gears like dyno will. I personally believe that Royal Purple is the worst gear lube product on the market.
    Chase@ECGS
  6. Nov 21, 2014 at 8:42 AM
    #1966
    tacoglock19
    Jawja
    Stock as shit!
    Thanks for the info. I'll change it all this weekend when I get the bearing done.
    Also, I got the ECGS bushing today. I'm impressed with the quality of everything in the kit. Well done and thank you for creating a solution to our problem.
  7. Nov 22, 2014 at 6:00 AM
    #1967
    alpinebob
    alpinebob Well-Known Member
    bob
    alpine ca
    2008 Tacoma 4x4
    Any thoughts on the best,(or good) E P lubes for 08 Taco Diffs?
    About 5 K Mi ago I changed to a synthetic 90-140 and added LS additive as recommended by the auto parts store all was well until now I get "shuddering" when I drive slowly and turn the wheels ,as in parking) ?
    Taco has 110K Miles.
    Thanks All,
    bob
  8. Nov 22, 2014 at 6:10 AM
    #1968
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Read post #1979 from ECGS ^^^^^^^^ its probably 3 posts back..GL
  9. Nov 22, 2014 at 6:21 AM
    #1969
    alpinebob
    bob
    alpine ca
    2008 Tacoma 4x4
    Installed the ECGS bushing last week, vibs gone ! Only problem I had was driving in the new bushing without (at first) having a driver long enough to apply enough force to get the last 1/4 inch driven in. I tried a length of 1.25 PVC but it absorbed too much energy to do it, I then replaced it with steel pipe with a flat washer welded on the "business" end and a socket inside as a centering guide and a few smart blows with a 2# hammer finished the job. I noticed in the ECGS video the use of a driver but it did not seem to be emphasized that it takes some pretty good hits with a well fitted guide tool.
    Am I the only one who had this "glitch" ?
    bob
  10. Nov 22, 2014 at 7:02 AM
    #1970
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Hey Bob, I assume your DC is a long bed (LB) based on your description of the shuddering. If you do have a LB, then you do have a LSD. Our LSDs are picky both with oil type and additive brand. Many people have had problems with synthetic in them, so stick with a non-synthetic. And I've tried many different LSD additives that didn't work (either from day 1 or after 1k miles). The only one I guarantee will work properly is the Equa-Torque:
  11. Nov 22, 2014 at 6:38 PM
    #1971
    tacoglock19
    Jawja
    Stock as shit!
    I got the ECGS bearing installed today and decided to go with Valvoline 85w140 (only oil in that weight available to me other than Royal Purple). I still have the vibration at the exact same speeds but it is not near as bad as it was. There must be something else bad. Who knows? I wish I was one of the people that had their issue cured 100%. Oh well. I will try to list the install/removal tools in the for sale section soon. If anyone is interested in those I will sell them for $75.00 with free shipping to the lower 48.
  12. Nov 24, 2014 at 6:55 AM
    #1972
    alpinebob
    bob
    alpine ca
    2008 Tacoma 4x4
    Thanks 05Moose, actually i have the short bed four door model Taco.
    I will get equa-torque and give it a try.
    bob
  13. Nov 24, 2014 at 7:08 AM
    #1973
    tacoholic05
    05' 4x4
    Chase, so now you have me dumping the RP this week and putting another brand in. Question though: my book states 80w90 but you are saying only use it when temps are below 0. Is that just for Lucas or all brands?
  14. Nov 24, 2014 at 9:45 AM
    #1974
    05Moose
    Jim
    Then check to see if you have a LSD sticker on your rear diff (see link in my sig). Not sure there were any SR5 packages on the short beds that had the LSD (unlike on the DC LB). It's just that the problem you described was exactly what you'd experience with the LSD.
  15. Nov 25, 2014 at 7:35 PM
    #1975
    nj636
    Kev
    Jersey
    I have always used Lucas brand gear oils with no problems
  16. Nov 26, 2014 at 4:40 AM
    #1976
    303tacoma
    Rebecca
    I received my bushing yesterday i hope it gets rid of the diff. vibe
  17. Nov 26, 2014 at 6:09 AM
    #1977
    alpinebob
    bob
    alpine ca
    2008 Tacoma 4x4
    Thanks, 05moose, will check and advise today.
    bob
  18. Nov 26, 2014 at 9:08 AM
    #1978
    alpinebob
    bob
    alpine ca
    2008 Tacoma 4x4
    06moose, took your clue and checked my 08sr5, it does have the L S D sticker on the rear diff.
    Thanks, alpinebob
  19. Nov 26, 2014 at 9:20 AM
    #1979
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Did you replace the CV axle too or just the bearing? If not, could be that the CV axle shaft was worn/scored where it inserts into the diff.
    Also, check your wheel bearings.
  20. Nov 28, 2014 at 4:17 PM
    #1980
    tacoglock19
    Jawja
    Stock as shit!
    It was the rear u-joint on the drive shaft. I replaced them both (front and rear) this morning since I had to drop it anyway. Easy as pie. Truck is like brand new. I threw more money at it than I should have but the ECGS bearing did help tremendously. One of the bushings on the back joint had no needle bearings left in it. It never occurred to me to check them until I got under it to grease them. I moved the drive shaft back and forth about 1/4 of an inch and knew immediately what had to be done. Oh well. $40.00 and 2 hours of my time this morning and I am running smooth again.
