OFFICIAL - 3rd GEN 275/70r17 Tire Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Haikin, Oct 6, 2015.
  1. Apr 4, 2017 at 5:06 PM
    #501
    Taco Luvr
    Taco Luvr Well-Known Member
    2016 TRD 4X4 OR
    King Ext, TC UCA, 1.5 AAL, VTX Rogue SL, BFG KO2 285/75R16
    I have had 275/70R17's on my 2016 TRD Off-Road for about 15,000 miles with an Old Man Emu setup using 885 coils.
    After alignment with the OME setup, I had zero rubbing. None at all–not off road, on the street, forward, reverse, none.
    I had a King mid-travel setup installed yesterday with 119-EXT coilovers and Total Chaos UCA's. My ride height seems to be exact, if not a little higher than it was with the OME setup.
    After alignment, I have some bad rubbing at certain turn radiuses. I would not take the truck off road like it is for fear of blowing a tire.
    Is anyone else running a King setup with 275's that wouldn't mind sending me your alignment numbers?
    I am taking it back in the shop on Friday to try and get this resolved.
    Thanks!
  2. Apr 4, 2017 at 5:23 PM
    #502
    JTM1
    JTM1 Well-Known Member
    Justin
    West Houston
    99 PreRunner, 08 TRD OR DC, 16 TRD OR DC, 18 F150 FX4 5.0L
    99-Fabtech Lift, Fox coil overs, OME Dakar leaf pack, LCE Header and Pro Flow Exhaust, TRD Supercharger, 275/70-17 BFG AT KO 08-Bilstein 5100s, OME 885 Coils, Wheeler's 2"AAL, All-Pro Skid Plates, Shrockworks Sliders, 265/75-16 BFG AT KO2 16-Daystar Strut Spacer, SSO Slimline Hybrid Winch Bumper, All-Pro Skid Plates, Shrockworks Sliders
    You want to try that again? Even the most sever change, going from load range "C" to load range "E" is only 10lbs. Most people are deciding between 265 E and the 275 E and its only a 2lb delta.
    Tire Size, Load Index & Speed Rating Overall Diameter Tire Weight
    LT265/70R16/E 121 S 30.6 50.4
    LT275/70R16/D 119 S 31.1 50.8
    LT265/75R16/E 123 R 31.6 53.6
    LT285/75R16/E 126 R 32.8 58.7
    LT265/70R17/C 112 S 31.6 45.7
    LT265/70R17/C 112 S 31.6 45.5
    LT265/70R17/E 121 S 31.6 53.4
    LT275/70R17/E 121 R 32.2 55.2
    LT285/70R17/E 121 R 32.7 58.1
    34x10.50R17/D 120 R 33.5 54.9
    35x12.50R17/E 121 R 34.5 66.5
    37x12.50R17/D 124 R 36.5 69.5
    Greg2017 likes this.
  3. Apr 4, 2017 at 6:26 PM
    #503
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    I am not a suspension guru at all but do you think that the ucas could be causing the rubbing? I remember hearing before that if you don't have enough lift for them (2.5 in or more) that aftermarket ucas can effect your caster making you rub.
  4. Apr 4, 2017 at 6:43 PM
    #504
    Tacoroach
    Tacoroach Well-Known Member
    Vancouver, BC
    2017 DCLB
    What tire is it? Brand?
    Take for a example all time favorite BFG KO2. P265/70/17 weighs 45.7lb and LT275/70/17 weighs 55.4 lb.
    As far as I know the 275 size comes only in LT which is 10 ply tire.
    smitty99 likes this.
  5. Apr 4, 2017 at 6:44 PM
    #505
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    You trim or no?
  6. Apr 4, 2017 at 7:36 PM
    #506
    Taco Luvr
    2016 TRD 4X4 OR
    The UCA's would allow for more adjustment, thus allowing closer to stock alignment with more lift. There is no minimum amount of lift needed to achieve proper alignment. I do believe I have too much positive caster though.
  7. Apr 4, 2017 at 8:06 PM
    #507
    JTM1
    Justin
    West Houston
    That chart was for the BFG KOBro and your favorite P265/70/17 that weighs 45.7 lbs is a load range C tire, the same size in load range E weighs 53.4lbs. So again, 10lbs isn't 13-15lbs.
    J-VET likes this.
  8. Apr 4, 2017 at 9:26 PM
    #508
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    it didnt even kill my mpg really, nothing too noticable
  9. Apr 4, 2017 at 11:09 PM
    #509
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    Nope It's not enough of an issue. Barely ever occurs.
    RZ Rob
  10. Apr 5, 2017 at 4:47 AM
    #510
    ievko82
    WV
    Thank you for the info. I may have misread or perhaps the person that posted it was incorrect. Good luck on correcting it. I just got my 887s on 3 days ago and I'm about to order my 275s to put on ray10s. I'm hoping that I won't run into a bunch of rubbing.
  11. Apr 5, 2017 at 4:58 AM
    #511
    Taco Luvr
    2016 TRD 4X4 OR
    I don't think what you read what necessarily incorrect info. You will definitely have more positive caster after installing aftermarket UCAs like Total Chaos, but I believe it takes a tech with a certain know-how to get that positive caster lower so less rubbing occurs.
    To preserve ride quality, I am not wanting to pre-load my coils by adding a bunch of ride height. The out-of-box increase in ride height with the Kings should be enough to clear a 275/70r17.
    Hopefully I can find someone to get it right. Trimming (cmc) just seems like the "easy" (lazy) option.
  12. Apr 5, 2017 at 5:14 AM
    #512
    ievko82
    WV
    Once again good luck. Alignment places seem so hit and miss when it comes to the ppl doing the alignments.
    Taco Luvr[QUOTED] likes this.
  13. Apr 5, 2017 at 6:54 AM
    #513
    RZRob
    Robert
    Anaheim Hills
    The King guys only know what they read. There's no ride height increase with Kings. They've forgotten that this is a Gen 3. With a Gen 2, there's a 1" increase. The instructions only consider Gen 2.
    RZ Rob
  14. Apr 5, 2017 at 6:56 AM
    #514
    smitty99
    Scottsdale
    Bilstein actually has their shit together as far as intel on the 3rd gen. A bit surprising that high end suspension manufacturers like King haven't caught on. Well I guess they don't need to...
    61ragtop and RZRob[QUOTED] like this.
  15. Apr 5, 2017 at 7:35 AM
    #515
    Taco Luvr
    2016 TRD 4X4 OR
    Nice.
    Well I'm not trying to gain a ton of ride height (obviously, I'm only running 275's), and I like my truck to be aligned properly, so maybe a CMC is what I will have to do. The OME setup just put the truck too high in the front for my liking. I will preload these Kings to get about 1.5" in the front.
  16. Apr 14, 2017 at 7:07 AM
    #516
    stjarvis
    stjarvis Well-Known Member
    2016 Tacoma TRD Off Road DCSB
    Anyone know if 275/70r17 on Konig Countersteer Type X -10 4.1 bs will rub on the stock OR suspension?
  17. Apr 14, 2017 at 9:50 AM
    #517
    ievko82
    WV
    I think you may run into rubbing with that bs at stock height. If I remember correctly ppl with 265s on a 4.3 bs just slightly rub at stock height.
  18. Apr 22, 2017 at 11:22 AM
    #518
    ievko82
    WV
    Bump for more 275 pics
  19. Apr 22, 2017 at 11:26 AM
    #519
    stjarvis
    I ended up ordering Konig Six Shooters and Khumo AT51's (cause they're a load C). I'll post picks up in a week or so when it's all here and installed.
  20. Apr 22, 2017 at 11:30 AM
    #520
    ievko82
    WV
    Looking forward to seeing the khumos on one of these trucks. Are you running any lift?
