OFFICIAL - 3rd GEN 275/70r17 Tire Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Haikin, Oct 6, 2015.
  1. Feb 20, 2021 at 8:35 AM
    #1141
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Well, If you already think it is sluggish it will definitely be worse to you. I always felt the motor was fine but like I said I don’t drive fast I have a car for that. I also do not tow so I don’t notice it either. Also, like mentioned you could do a reflash a.k.a. tune Which everyone says seems to make a huge difference
  2. Feb 20, 2021 at 8:44 AM
    #1142
    JHannibal
    JHannibal Well-Known Member
    2014 DCSB 4X4
    I wouldn't say it's sluggish now but I'm just curious how other's experience has been. I do have the 4.0 so I think it would be less noticeable, and tuning really isn't an option for the 2nd gen.
    ryanvar42[QUOTED] likes this.
  3. Feb 20, 2021 at 8:49 AM
    #1143
    JRH_Tacoma
    JRH_Tacoma Well-Known Member
    Charlotte, NC
    2017 BBP Tacoma TRD Sport 4x4
    I went from 265/70/17 Falken Wildpeaks that were 46.5 lbs to the 275/70/17 Wildpeaks that are 57 lbs. Also at the same time I went from 23 lb wheels to 30 lbs wheels. So a 17 lb increase all around. I definitely felt sluggishness which is to be expected with that kind of weight gain. However I just got OVTune a few days ago and it’s made a huge difference in the way the truck drives. The sluggishness is totally gone, amazingly.
    275/70/17 is a great size as a middle ground for larger tires. Beefier look that doesn’t require a CMC. However most of the options in this size that have aggressive tread are very heavy at 55+ lbs.
  4. Feb 20, 2021 at 8:52 AM
    #1144
    JHannibal
    2014 DCSB 4X4
    I appreciate the response, for the setup I want it would also be a 17lb increase all around but I think having the 4.0 engine wouldn't make it so bad, but on the other hand I don't have access to an OVtune. When you talk about sluggish can you provide an example?
    thanks
  5. Feb 20, 2021 at 8:59 AM
    #1145
    JRH_Tacoma
    Charlotte, NC
    just real slow off the line, and lots of gear hunting. It could be a 3rd Gen thing though, hard to know what your experience would be on a 2nd Gen.
  6. Feb 20, 2021 at 9:02 AM
    #1146
    JHannibal
    2014 DCSB 4X4
    Yeah it's hard to say since the gear hunting is not a problem with 2nd gens. I am possibly thinking of going 255/75/17 which I think would make the tire lighter and help with the sluggishness, hard to say for sure. I wish I could test out a few tires on the truck and see how I like the look and ride.
  7. Feb 20, 2021 at 9:09 AM
    #1147
    JRH_Tacoma
    Charlotte, NC
    I debated 255/80/17 which were a few lbs lighter but decided to go with the wider tire look. I’m guessing the Methods you’re looking at are 30 lbs. is that heavier than your current wheels?
  8. Feb 20, 2021 at 9:12 AM
    #1148
    JHannibal
    2014 DCSB 4X4
    Yeah, they are heavier by 8lbs. Currently have the stock Off-road 2nd gen wheels which are 22 pounds.
  9. Feb 20, 2021 at 9:16 AM
    #1149
    JRH_Tacoma
    Charlotte, NC
    Yeah the wheel weight increase will have an impact too, as I found out.
  10. Feb 20, 2021 at 9:19 AM
    #1150
    JHannibal
    2014 DCSB 4X4
    Yeah I could imagine but I'm just really wanting to feel it first hand on my truck and decide. I won't be adding steel bumpers or a tent or anything so I don't think it will be too bad. Probably will just go this route and after a week won't really feel like it's that sluggish since I'll be used to it.
  11. Feb 20, 2021 at 9:35 AM
    #1151
    JRH_Tacoma
    Charlotte, NC
    I think that’s the right way to look at it. After all, we’re driving trucks and they will drive like trucks! I think you’ll be happy with the size. And the Wildpeaks are great tires - liked them a lot in both sizes I’ve had.
  12. Feb 20, 2021 at 9:46 AM
    #1152
    JHannibal
    2014 DCSB 4X4
    I agree, I was looking at K02's and wildpeaks but I just am more interested in the wildpeaks after reading reviews and comments on them. Really like the look at the performance seems great plus I think they are lighter.
  13. Feb 20, 2021 at 9:49 AM
    #1153
    JRH_Tacoma
    Charlotte, NC
    Wildpeaks in 275/70/17 are actually slightly heavier than KO2s, by about 1.5 lbs.
  14. Feb 20, 2021 at 9:52 AM
    #1154
    JRH_Tacoma
    Charlotte, NC
    Despite the higher weight I chose the Wildpeaks since I had them in the 265 size and loved them, so was more comfortable with that switch.
    JHannibal[QUOTED] likes this.
  15. Feb 20, 2021 at 3:07 PM
    #1155
    Silvertexastaco
    Silvertexastaco Silver Texas Taco
    Silver 2017 Access Cab
    No need to mess with gears, however...because you are increasing rim and tires sizes, gas milage will take a small hit...and also, you might get some rubbing on fender wall and mud flaps if you have them.
  16. Feb 20, 2021 at 3:29 PM
    #1156
    Chris1431
    Chris1431 Active Member
    2016 White SR5
    TRD pro grille
    Hey fellas, I'm looking at putting a 2" OME lift on my 2016 SR5 and wondering if I could squeeze 275/70/r17 on without any rubbing. It's a work truck so I'm not doing crazy offroading or anything so if there's any way I could squeeze in 275s maybe with certain offset/backspacing and/or 16 inch rim, though ideally 17. If it would rub mud flaps at like full turn/full compression, that fine I can do that cutting down the line when/if I do trails. Let me know what you think or any other suggestions
  17. Feb 20, 2021 at 3:41 PM
    #1157
    JHannibal
    2014 DCSB 4X4
    I took all mud flaps off the only thing I still haven’t done is CMC which I would prefer not to do. 2.5” to 3” of lift so I’m sure I’ll be good. How big is the hit to MPG’s?
  18. Feb 20, 2021 at 5:15 PM
    #1158
    Lht123
    Lht123 Active Member
    PNW
    2019 OR DCLB Cav Blue
    Rub varies from truck to truck; I have a 2" OME lift and rubbed a bit at 275/70R17 even after swapping out UCAs on 4runner SEMAs w/ 4mm offset.
  19. Feb 20, 2021 at 7:54 PM
    #1159
    Silvertexastaco
    You may see a 2- 4 mile decrease.
  20. Feb 20, 2021 at 11:38 PM
    #1160
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I did a 2-2.5" lift with reasonable tires for the truck. MPG change is small, <1mpg so far over the last 2 months
