OFFICIAL - 3rd GEN 275/70r17 Tire Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Haikin, Oct 6, 2015.
  1. Feb 21, 2021 at 9:23 AM
    #1161
    Chris1431
    Chris1431 Active Member
    2016 White SR5
    TRD pro grille
    True. Were you just rubbing on mud flaps? Or were you rubbing on UCAs?
  2. Feb 21, 2021 at 12:18 PM
    #1162
    wh11
    wh11 Well-Known Member
    2020 Cement OR
    Getting 275/70/17 C load Wildpeaks installed tomorrow with some SCS Ray10s. Currently on 265/70/17 E load KO2s and the TRD pro wheels. Wanted a bit more offset, bigger tire, and a C rating but didn't want to go all the way to 285 and have to cut/regear. Excited to get some firsthand exprience with the Wildpeaks so I can compare them to the KO2s.
    JRH_Tacoma likes this.
  3. Feb 21, 2021 at 12:31 PM
    #1163
    Chris1431
    2016 White SR5
    TRD pro grille
    Do you have any pics with the 265 KO2s?
  4. Feb 21, 2021 at 12:49 PM
    #1164
    Lht123
    Lht123 Active Member
    PNW
    2019 OR DCLB Cav Blue
    275/70 17s went on at the same time as new UCAs, so my rubbing was on wheel wells every time I turned... I was able to remedy with a heat gun, but that almost certainly wouldn't have been the case without the new UCAs.
  5. Feb 21, 2021 at 4:18 PM
    #1165
    Chris1431
    2016 White SR5
    TRD pro grille
    Hey fellas, another (maybe dumb) question is can I mount rims with a 108 mm centre bore or do I have to stick to the Tacoma stock 106.1?
  6. Feb 21, 2021 at 6:39 PM
    #1166
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    They will probably bolt up fine assuming the lug pattern is correct, but vibration may be a problem if the wheels are hub centric. If they are lug centric, I'm not sure how reliable that will be with the Toyota hubs. Hopefully someone with more hub/wheel knowledge will offer some info.
  7. Feb 21, 2021 at 7:17 PM
    #1167
    Chris1431
    2016 White SR5
    TRD pro grille
    Right, makes sense. I'm just trying to pair up some rims and tires properly, and it looks like you're able to get 275s on 7" rims without any rubbing, but it's hard to find 17x7s with the 6x139 bolt pattern that isn't the TRD pro wheel. Otherwise I wonder if I could go to an 8 inch rim with 265s.
  8. Feb 21, 2021 at 7:18 PM
    #1168
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Gotta stick with stock
  9. Feb 21, 2021 at 7:20 PM
    #1169
    Chris1431
    2016 White SR5
    TRD pro grille
    Yeah I figured. Hard to find aftermarket rims that are 17x7" right now. At least in Canada. Might have to settle with the TRD pros. They do look nice.
  10. Feb 22, 2021 at 6:47 PM
    #1170
    Jgutierrez
    Jgutierrez New Member
    2020 trd Tacoma
    You guys think that 275/70/17 will fit on just a level kit in a 3rd gen Tacoma?
  11. Feb 22, 2021 at 6:48 PM
    #1171
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Yes, as long as your choose the right wheels, that don’t poke out too far.
  12. Feb 22, 2021 at 7:25 PM
    #1172
    Jgutierrez
    2020 trd Tacoma
    I wanna go with the 17” trd rims and ko2s
  13. Feb 22, 2021 at 11:27 PM
    #1173
    Stocklocker
    17TRDORDCSBAT
    17” rims come in many widths. The safest bet is the 7” wide TRD 4Runner “sema” rims. Other, wider rims might need some further study to see if they will cause rubbing. The SEMA rims work with the 275/70/17 tire in most cases.
    Check out this thread:
    https://www.tacomaworld.com/threads/17-trd-pro-rims-and-bfg-at-tko2s.426902/
  14. Feb 23, 2021 at 5:20 PM
    #1174
    SEVtaco
    SEVtaco Well-Known Member
    Orange County
    2021 Tacoma TRD OR
    king2.5s/33s/Deaver/SCS wheels
    can you post some pics after install and possibly inform if you are rubbing, offset? Looking to get Ray 10s at -10 offset or F5 at a 0 offset With a 275 tire trying to avoid a CMC, going to install a 2.5-3 inch dobinson mrr lift soon to fit the tires. Thanks
  15. Feb 25, 2021 at 10:38 AM
    #1175
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    They will fit without any modification as long as its 7.5 or 7in rim
  16. Feb 25, 2021 at 11:40 AM
    #1176
    Chris1431
    2016 White SR5
    TRD pro grille
    Without any modification? That's a 32.2 inch tire, even on stock rims that will rub bad without anything lifted in the front.
  17. Feb 25, 2021 at 12:14 PM
    #1177
    ryanvar42
    None
    Yeah if you level it like stated.
  18. Feb 25, 2021 at 12:15 PM
    #1178
    GrundleJuice
    Michigan
    2016 TRD Bro
    I checked 275/70/17 at full stuff when I was changing struts and I had clearance when on the bump stop. With bumps compressed, maybe it rubs somewhere, but it won't be "bad". That was on 4runner sema wheel with camburg UCA, but no wheel well interference as far as I could tell.
  19. Feb 25, 2021 at 1:43 PM
    #1179
    Stocklocker
    17TRDORDCSBAT
    I have 275/70/17 BFG Ko2 on 4Runner Sema wheels and no rub anywhere, even at full stuff. It’s the “unicorn tire” only on a 7” rim with minimal offset like the Semas.
  20. Feb 25, 2021 at 2:10 PM
    #1180
    Chris1431
    2016 White SR5
    TRD pro grille
    I see. I thought you meant no modification as in no level kit
