Official 4th gen announcement
Discussion in '4th Gen. Tacomas (2024+)' started by Shellshock, May 18, 2023.
  1. May 18, 2023 at 5:39 PM
    Shellshock
    Shellshock [OP] King Shit of Turd Island
    Iowa
    https://pressroom.toyota.com/2024-toyota-tacoma-is-the-ultimate-adventure-machine/
    https://youtu.be/o-z7fMnu5RE
    Power train:
    • Base 2.4-liter turbo (SR only), 228 hp/243 lb-ft and eight-speed auto
    • i-Force 2.4-liter turbo, 270 hp/310 lb-ft and six-speed manual
    • i-Force 2.4-liter turbo, 278 hp/317 lb-ft and eight-speed auto
    • i-Force Max 2.4-liter turbo hybrid, 326 hp/465 lb-ft and eight-speed auto
    dimensions:
    • maximum ground clearance of 9.5 inches, maximum running ground clearance of 11 inches
    • maximum 33.8-degree approach, 23.5-degree breakover, and 25.7-degree departure angles.
    • wheelbase roughly 4 inches longer than before
    • Length unchanged
    • Up to 4” wider
    Trims:
    • SR (XtraCab, Double Cab) - Base engine standard, available with the i-Force/six-speed manual combination, leaf springs, twin-tube shocks, 17-inch wheels
    • SR5 (XtraCab, Double Cab) - i-Force engine, multilink rear on Double Cab, leaf springs on XtraCab, twin-tube shocks, 17-inch wheels
    • TRD PreRunner (XtraCab) - i-Force engine, 4x2 with electronically activated rear rocking differential, leaf-springs, front lift, twin-tube shocks, 17-inch wheels
    • TRD Sport (Double Cab) - i-Force engine, (i-Force Max or iForce/manual transmission optional), red TRD sport tuned twin-tube shocks, TRD Sport 18-inch wheels
    • TRD Off-Road (Double Cab) - i-Force engine (i-Force Max or i-Force/manual transmission optional), Bilstein monotube remote reservoir shocks, multi-terrain select, electronically activated rear locking differential, optional front stabilizer bar disconnect and 33-inch tires, composite skidplates, 17- or 18-inch black TRD wheels
    • Limited (Double Cab) - i-Force engine (i-Force Max with full-time 4x4 optional), adaptive variable suspension, 18-inch chrome clad wheels, power running boards and tailgate
    • TRD Pro (Double Cab) - i-Force Max standard, 2.5-inch Fox internal-bypass manual modal Quick Switch 3 shocks, red "TRD" forged aluminum upper control arms, IsoDynamic Performance seat, electronically activated rear locking differential, front stabilizer bar disconnect, aluminum front skidplate, Rigid LED foglamps, ARB steel rear bumper with red recovery hooks, 33-inch Goodyear Territory R/T tires, 18-inch black TRD Pro wheels
    • Trail hunter (Double cab) - Old Man Emu (aka OME) position sensitive, 2.5-inch forged monotube shocks (with rear external piggyback-style remote reservoirs), a bed utility bar with removable MOLLE panels, 33-inch Goodyear Territory R/T tires, Rigid LED foglamps, a steel rear bumper, rear recovery points, rock rails, high-strength steel skidplates, and more.
  2. May 18, 2023 at 5:45 PM
    TheeNorthStar
    TheeNorthStar ok, dis taco
    2021 TRD OFF ROAD MGM DBL CAB AT 4WD
  3. May 18, 2023 at 5:48 PM
    smallfrye
    smallfrye Well-Known Member
    Stock
    Not sure how I feel about the front end styling, I think the looks of the 3rd gen front end looks better. The interior looks better and the hybrid powertrain has my interest.
    CementMixr and bbartol like this.
  4. May 18, 2023 at 6:07 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    The pro and hunter look fine. The plastic front spoiler on the rest looks terrible.
    But the gun rack in the prerunner is way cool. :infantry:
    MGM 22 likes this.
  5. May 18, 2023 at 6:11 PM
    MaxTaco6
    MaxTaco6 Well-Known Member
    Vancouver, BC
    2022 TRD OR Lunar rock
    The air damper is absolutely killing it. Even on the Trd off road now, whether you like it or not, you need to pay for it then get rid of it.
    SeaDweller3T and MGM 22 like this.
  6. May 18, 2023 at 6:12 PM
    Shellshock
    Iowa
  7. May 18, 2023 at 6:14 PM
    DeuceDeuceBravo
    DeuceDeuceBravo Well-Known Member
    New England
    I think overall they did a great job. Improved basically everything without doing anything too radical.
    More new features than I expected, actually.
    Disconnecting sway bars?? Yes, please!
    Ventilated seats? Finally!!
    https://youtu.be/RiZqmTfrokU
    Lord Helmet and Dopplerplus like this.
  8. May 18, 2023 at 6:16 PM
    twtaco$
    twtaco$ Well-Known Member
    I’m only interested in the hybrid MPG guess that’ll be out soon.
  9. May 18, 2023 at 6:25 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  10. May 18, 2023 at 6:27 PM
    a400ryan
    a400ryan Well-Known Member
    Garson Manitoba Canada
    2015 SR5 DCLB
    Yes for the hybrid and rear suspension
    No for non gated transmission shifter
  11. May 18, 2023 at 6:31 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    I'm liking what I see in the limited. full time 4wd, heated steering wheel, heated and cooled seats, a tow/haul mode with a brake controller.
    Are those the BP-51 shocks on the trailhunter?
    Superdave1.0 likes this.
  12. May 18, 2023 at 6:33 PM
    DeuceDeuceBravo
    New England
    This is the biggest improvement
  13. May 18, 2023 at 6:34 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I guess the reveal on the 19th is early?
  14. May 18, 2023 at 6:35 PM
    Tony382
    Tony382 Well-Known Member
    2022 Tacoma TRD Sport
    the chin strap now looks like a snow plow. As it is with every new generation vehicle, the styling always ends up growing on you and aesthetics evolve as the generation ages. If this is the baseline for this generation, I'm excited to see where it's at 3 to 4 years from now. I'm not totally blown away by it, but like the 3rd gen....I wasn't too stoked about it either but it grew on me and now I love it. Looks like a lot of room to fit at least some 33's.
    CementMixr and shakerhood like this.
  15. May 18, 2023 at 6:36 PM
    Shellshock
    Iowa
    Yeah that’s a huge improvement from 265 @ 4600
    it’ll definitely be interesting once some of the driving videos start coming out
  16. May 18, 2023 at 6:42 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I love it!
  17. May 18, 2023 at 6:47 PM
    2GRFKS
    2GRFKS 2nd gen Tacoma is the worst gen
    Only thing better about 3rd Gen is location of the parking brake IMO
  18. May 18, 2023 at 6:55 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    I’m afraid I agree with you. I’ll miss a real parking break. But the press release says it will allow low speed cruise control. I’ll take that trade off.
  19. May 18, 2023 at 7:00 PM
    MGM 22
    MGM 22 Well-Known Member
    23 MGM Pro
    The pro and trail hunter look good , the air dam would go immediately if I got any other model. Personally I like the front end of the 3rd gen better but that's just me. Anxious to see how the new engines do with time and the MPG.
  20. May 18, 2023 at 7:01 PM
    happyvirus
    happyvirus Well-Known Member
    So no 6MT with the iforce max? In other words, no pro with 6MT?
