Official 5-Lug Picture Thread
Discussion in '5 Lug' started by Yota Newb, Oct 26, 2010.
  1. Jun 5, 2016 at 9:08 PM
    #2261
    Navelfunk
    Navelfunk Well-Known Member
    Phyllis
    WA
    '03 DC SR5 V6 4x4
    Cap, incorrect rims & tires, stereo...
    Got some new tires from Les Schwab. My Coopers got round-out from shit install at Allen Tire. After 5 years, my truck finally drives straight. Much better, now...
  2. Jun 6, 2016 at 3:54 AM
    #2262
    B ill y
    B ill y Well-Known Member
    Billy
    Sarasota County, Florida
    2018 4Runner Trd OR, 1997 FZJ80,1985 FJ60
    Well when it's still wet you could put aluminum foil on it and smooth it out . They put foil on dinomat, and if you put it on the wet and let it dry it would be a radiant barrier. And reflect the heat back out side. It is ac duct sealant so as for insulation . I would say yes. Wear a latex glove and smear it flatter or use a cheap brush. Just make Shure you check the window before you let it dry and you don't fuckup and make window glued . Roll it up and down . This is that stuff from lowes I put in ceiling for insulation. It's foil,bubble,foil,bubble,foil. It's in the insulation isle. And it's like 20-30 bucks. Cut the heat in half. It's 3 layers thick. Like 3/4". The stuff is 1/4" thick.
    Kevin King, HackD and Rolis12 like this.
  3. Jun 6, 2016 at 4:22 AM
    #2263
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Are you manual or automatic?
  4. Jun 6, 2016 at 4:40 AM
    #2264
    B ill y
    Billy
    Manual. With that annoying NO peel out . Feature. Called vsv With the stock switch you get 1 peel out when it's in gauged (turned on) . Then it goes back to automatic ofteR your peel out. So you have to turn off .then turn it back on to get a second peel out. If it's a rainy slippery road or iced it's ok it's to stop you from fucking up. But it also takes the fun out of randomly peeling out. NO PEEL OUT AT ALL UNLESS YOU INGAUGE (turn on) I was thinking that . that push button mod shut it off but if it shuts off the brakes as well not interested.
  5. Jun 6, 2016 at 4:41 AM
    #2265
    5 Lug Fury
    Kenny
    Knoxville, TN
    It makes sense because your clutching so much right now :D
  6. Jun 6, 2016 at 7:09 AM
    #2266
    B ill y
    Billy
    Lame .. Lol.
  7. Jun 6, 2016 at 7:26 AM
    #2267
    5 Lug Fury
    Kenny
    Knoxville, TN
    :fistbump:
    So your wayyyyyyyyy closer to getting hit by that storm than me lol
  8. Jun 6, 2016 at 8:52 AM
    #2268
    Rolis12
    Rolis12 Well-Known Member
    Rolis12
    San Diego
    2015 5lug access auto
    Goodyear Wrangler TrailMark 31's. F.B's 2.75" spacer, TRD rear shocks, stub antenna, ripped out charcoal filter added AFE dry, Chrome grille, upgraded to SR5 sun visors, variable wipers, backup camera, HID DDM 35w 5000kv, ebay fogs w/yellow LEDs.
    Thats a nice clean install Billy and thanks for the tips they helped tremendously!
    My install went smooth but it looks like an elementary school art project. i got that "thud"sound now when you tap the door so I'm happy! Next will be a sub either the kenwood sw11 or sound ordnance B-8PTD.
    B ill y[QUOTED] likes this.
  9. Jun 6, 2016 at 2:43 PM
    #2269
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    That looks like the material used in automotive shades that are used to cover up the front window. I actually have a few of those kicking around from work as packaging samples from a quaker state promotional from more than a few years back now.. looks like a good re-purposing opportunity for me, if so.
    5 Lug Fury likes this.
  10. Jun 6, 2016 at 2:51 PM
    #2270
    5 Lug Fury
    Kenny
    Knoxville, TN
    Might be a little too thick
    HackD[QUOTED] likes this.
  11. Jun 6, 2016 at 2:57 PM
    #2271
    HackD
    William
    I'll find out soon enough, i suppose. I also need to go down the route of stripping out the interior for miscellaneous upgrades soon.
    I have at least three to play with - and i do need to put some sort of dampening into the ceiling due to wind-noise from the Prinsu rack. If these samples are part of a low-money solution, it'll be a bonus.
  12. Jun 6, 2016 at 3:01 PM
    #2272
    Clearwater Bill
    Billy
    Largo Florida
    Tire size? Stock suspension or ??
  13. Jun 6, 2016 at 3:15 PM
    #2273
    Navelfunk
    Phyllis
    WA
    '03 DC SR5 V6 4x4
    Same as the Coopers, 235/75/R15 on stock suspension. The Coopers were installed without tire alignment, causing all kind of steering funk making me look like a drunk driver... Kept getting steering alignments, balance & rotations at Toyota, but never got zeroed in. Guys at Les Schwab installed tires correctly and did a steering and wheel alignment afterward.:D
    Clearwater Bill likes this.
  14. Jun 6, 2016 at 5:07 PM
    #2274
    SleazyPetey
    SleazyPetey Popeyes > KFC
    Pete
    Northern Virginia, USA
    2013 Regular Cab
  15. Jun 6, 2016 at 10:10 PM
    #2275
    Vang Toua Moua
    Vang Toua Moua Well-Known Member
    Vang Bang
    Visalia, CA
    05 Silver Tacoma 2.7, Access cab, 5 lug
    Custom front bumper and rock sliders, glasspack muffler, shorten exhuast, abs killswitch, roof light bar, rear e locker.
    Went and found this bad little trail after I left work, by accident. I was looking easy dirt trails, but found this. My taco is not the average 5 lugger tho. I have 33s, 3" lift, armor, and the e locker axle.
    I don't think I could've done this without the e locker. I felt my tires slip a couple times, but luckily the e locker was engaged the whole time. I could barely do loose incline when my 5 lugger wasn't as built. It's day and night now.
    5lugturtle, HackD, Navelfunk and 3 others like this.
  16. Jun 7, 2016 at 4:57 AM
    #2276
    B ill y
    Billy
    It is kinda just like the windshield cover. And I used it as windshield cover just have to cut to fit. But every time I roll it up it shrinks a little. I laid it outside of window traced with sharpie then cut it perfect fit.
  17. Jun 7, 2016 at 4:59 AM
    #2277
    B ill y
    Billy
    There is a video on YouTube on removing ceiling . It gives enough info to not fuck up anything.
  18. Jun 7, 2016 at 5:15 AM
    #2278
    Iamraiderpower
    Iamraiderpower Well-Known Member
    This little 5lugger is getting offroaded more than half of the 4x4 mall crawlers on this website, strong work dude!
  19. Jun 7, 2016 at 9:39 AM
    #2279
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    Thank you. Lol. It's what I love and that's where my 5 lugger is headed on being swapped.
  20. Jun 7, 2016 at 1:52 PM
    #2280
    HackD
    William
    These photos are considerably better quality than those that i saw on farcebook.
    Still not sure where you are going with the rack, but we've already talked about that :)
    Your's as shown, is more pre-runner, than the TRD version.. at least as far as the average owner is concerned, for use of their truck.
    What have you done suspension-wise, so far, to the truck?
