Official 5-Lug Picture Thread
Discussion in '5 Lug' started by Yota Newb, Oct 26, 2010.
  1. May 3, 2018 at 4:48 AM
    #2781
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    The housings are stock but the headlights were 170 Most I've ever payed for headlights lol
  2. May 3, 2018 at 9:09 AM
    #2782
    Nick42517
    Nick42517 Member
    15 4runner Limited 09 Tacoma Access
    Stock
    Are you talking bulbs or the entire headlight assembly?
  3. May 3, 2018 at 8:03 PM
    #2783
    Cville 5luger
    Cville 5luger Member
    Cole
    2013 graphite DCSB SR5 prerunner
    265/75 r16's
    Has anyone ever done a 3” body lift and not messed with suspension for our 5 luggers? Thinking about a performance accessories 3” and 31/10.5r15s. But please tell me if this is a bad idea E401B54E-9B75-44CE-8F3F-E7F3ED9A6886.jpg
  4. May 3, 2018 at 8:10 PM
    #2784
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    3” body lifts arnt recomend for a number of reasons, mainly if you plan on every taking your truck off road
  5. May 4, 2018 at 5:59 AM
    #2785
    Cville 5luger
    Cole
    265/75 r16's
    won't i still have better travel with only a body lift instead of compressing it more with strut spacers?
  6. May 4, 2018 at 6:14 AM
    #2786
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    No your suspension will remain exactly the same all you get to do it put bigger tires
  7. May 4, 2018 at 6:58 AM
    #2787
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    With the spacers we use it only really stiffens the suspension than remove travel. Also with a spacer/aal you gain more load capability. One thing to consider with a body lift is you have to extend some thing like your gas filler and steering column. For 31s I would suggest a spacer way more than a body lift.
    Here's my travel with a 3" spacer and 235/75/r15 (the rear has a shackle flip and an aal )
    Also spacer/aal lifts are wayyyyy cheaper lol
  8. May 4, 2018 at 7:08 AM
    #2788
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Body lifts while being a easy way to get a 3” lift isn’t really practical if you plan to ever off-road. It keeps all your suspension exactly the same but puts the body way higher changing your center of gravity as well as there is now more added leverage from the body on to the spacers which can cause them to break or twist doing hard off-roading. You also don’t achieve any added ground Clearance because you left the frame on the ground andjyst lifted the body. Lastly you will look dump because when you look at your truck from the side with a 3” body lift there will be a huge gap between the body and frame
    You will also have to extend break lines, bumpers brackets, fuel neck, steering column, drop your radiator and im sure there is more
    Now if you wanted to do something like a 1” body lift with suspension lift just to help clear the tires more then thats ok. A 1” body lift is about max you want to go
  9. May 8, 2018 at 6:59 AM
    #2789
    SleazyPetey
    SleazyPetey Popeyes > KFC
    Pete
    Northern Virginia, USA
    2013 Regular Cab
  10. May 8, 2018 at 8:17 AM
    #2790
    SleazyPetey
    Pete
    2013 Regular Cab
    nice wheels ;)
    HackD and JackWiseTaco[QUOTED] like this.
  11. May 16, 2018 at 6:51 PM
    #2791
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Enjoying the bro lean life in socal.
  12. May 16, 2018 at 6:54 PM
    #2792
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Poor dog, doesnt have a bed to ride around in lol
    MadTaco461[QUOTED] likes this.
  13. May 16, 2018 at 6:55 PM
    #2793
    kellen619
    kellen619 Member
    kellen
    2000 Tacoma 2wd base 5 lug
  14. May 16, 2018 at 6:58 PM
    #2794
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Needs to be lower
  15. May 16, 2018 at 7:10 PM
    #2795
    MadTaco461
    CA
    Kinda stock
    She gets the passenger seat when I take her out.
  16. May 19, 2018 at 10:04 AM
    #2796
    Cville 5luger
    Cole
    265/75 r16's
    Here is my before and after tires. I just got a set of Goodyear wrangler trail runner AT in 235/75r15. looking so much better than stock. BE05FDCE-4E52-49E5-99C6-5B931D13F61F.jpgCE12EF28-01F3-456E-BD70-4D3385DF7D67.jpg
    5lugturtle, KS WRAITH and Sperrunner like this.
  17. May 19, 2018 at 10:05 AM
    #2797
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Looks good
  18. May 19, 2018 at 3:01 PM
    #2798
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Some new pics
    5lugturtle, KS WRAITH and 5 Lug Fury like this.
  19. May 20, 2018 at 3:17 PM
    #2799
    Silversurfah808
    Silversurfah808 Active Member
    Run'emhaad
    Oahu
    2001 Tacoma 5lug xtracab
    FTK7014 - spindle lift kit/AAL
    image.jpgNewMember. Aloha!
    From the LowLife to the HIghLife, I love my new 2001 taco! Just using my truck for work & fishing. Starts up first crank!
    223k
    2wd 5 lug
    2.4L Engine
    leafspring under axle.
    Fabtech:SpindleLift/AAL
    New headlights, Grill, & hood
    17" Lexus wheels 215/45r17
    New shoes coming soon
  20. May 20, 2018 at 3:26 PM
    #2800
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Welcome to Tw!!
