Official 5-Lug Picture Thread
Discussion in '5 Lug' started by Yota Newb, Oct 26, 2010.
  1. Jun 7, 2020 at 1:02 PM
    #3161
    Goober1997
    Goober1997 Well-Known Member
    Colin
    2002 2.4l 5Spd Tacoma Base
    ah no worries, they look killer!
    Das it mang and katsuG[QUOTED] like this.
  2. Jun 7, 2020 at 1:04 PM
    #3162
    Thuguon2.7
    Thuguon2.7 Cheeehuuu
    J
    SoCal.
    ‘15 1GRFESR5AC
    Lookin cherry braddah! Simple dimple
    PalarX[QUOTED] and Das it mang like this.
  3. Jun 7, 2020 at 2:54 PM
    #3163
    AllTerrainMonster
    AllTerrainMonster Well-Known Member
    South Korea
    2006 2.7L Base 2WD
    Cleaned it up a little bit
    5 Lug Fury, KS WRAITH and Das it mang like this.
  4. Jun 7, 2020 at 4:27 PM
    #3164
    AllTerrainMonster
    South Korea
    2006 2.7L Base 2WD
    If those end up fitting, post the measurements please!
  5. Jun 9, 2020 at 2:09 AM
    #3165
    PalarX
    PalarX New Member
    2007 2.7L 5 lug
    Thanks. I threw on 245/75/16 MT tires on my 300ZX wheels. Just placed an order on the Fatbob's lift kit with the rear shocks.
  6. Jun 9, 2020 at 4:38 AM
    #3166
    Thuguon2.7
    J
    SoCal.
    ‘15 1GRFESR5AC
    Champion :thumbsup:
  7. Jun 12, 2020 at 7:22 PM
    #3167
    Kyle2007
    Kyle2007 Active Member
    Kyle
    2007 Tacoma 2.7
    Insert sad face
    245/75r17! Only had to remove 17% of the vehicle
  8. Jun 13, 2020 at 6:49 AM
    #3168
    TheBigKahuna
    TheBigKahuna Well-Known Member
    What rims are they?
  9. Jun 13, 2020 at 11:23 AM
    #3169
    Kyle2007
    Kyle
    2007 Tacoma 2.7
    Insert sad face
    Well I've heard two different stories about them #1 the place I bought them from said they came from Japan (OEM toyota) - they did unload them from a container filled to the brim with with Japanese stuff :p including a few excavators
    #2 the gentleman who installed my automatic locks told me he thought they were off of a Mazda
  10. Jun 15, 2020 at 4:15 PM
    #3170
    joemauma
    joemauma Well-Known Member
    Oregon
    Double Cab
  11. Jun 15, 2020 at 11:26 PM
    #3171
    z_thompsonpa
    z_thompsonpa Well-Known Member
    Patrick
    Austin, TX
    2000 Toyota Tacoma Ext Cab SR5 Stepside (5-lug)
    Doetsch Tech 3.5" Spindle Lift Fabtech FTS-7078 Front Shocks Bilstein 5125 Rear Shocks Daystar Front Coil Spacers Fabtech and ProComp Rear AALs 15x8 Black D-Window Steelies 4.0 BS Energy Suspension Front Poly Sway Bar Bushing & Endlink Kit Powerstop Brake Rotors Amber Corner Blinkers & Clear Fog Lights 2001+ Power Mirrors Keyless Entry & Alarm Pinch-weld mod Big 3 Electrical Upgrade w/ 1000A Battery Custom Led High Mount Brake Light 2001+ Rhino-Lined Fender Flares Gentex auto-dimming mirror w/ Compass and Temp 3rd gen 4Runner Map Light Console
    1st gen and 2nd gen 5-lug... Did I mention the 2nd gen is a prius!!!
    Just a few pics from north padre island last summer. I plan on making another trip this summer. We made it to mile marker 25.. maybe planning on a few more next time. It was a blast. Good to see y'all are still alive and well!
  12. Jun 16, 2020 at 5:20 AM
    #3172
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    How u been digging the mid travel set up on ur 5 lug
  13. Jun 16, 2020 at 6:51 AM
    #3173
    z_thompsonpa
    Patrick
    Austin, TX
    Overall it's been enjoyable.
    I moved some cinder blocks, and weight was mostly on one side of the bed. This caused my AAL to sag on the left side. It looks like the fts200 lost its arch. Procomps still strong as ever though. I can't afford anything fancy atm, so just gonna put some adjustable shackles with a different setting on each side to level it from side to side in the rear.
    Bumpstops still limiting down travel.. haven't done anything there yet. Same with traction bars.. crappy stock worn bushes.
    I never replaced those bearing races, either... And let's say I payed the price. Should've taken @Sperrunner advice and talked to my machinist before this happened at 85mph on the tollway.
    I damaged the hub and spindle nut, but found some spare parts in the local junkyard as a turn of luck. Mid travel kit held up very well as you can see. I've got new bearings waiting to be pressed in.
    Still need to get cross shafts milled as well. Camber on alignment is still slightly negative with no positive adjustment. Gives me a reason to get bigger tires at some point lol.
    I pulled the truck in the garage recently to install side indicators on the mirrors and wire up a reverse camera. I'll probably start addressing some of these issues after I get done tracing down wires. I am getting vibes at highway speed, so going to fix bearing races, cross shafts, alignment before looking into the driveshaft pinion angle.
    Got in some mud.. one wheel drive kicked in.. but the all terrains saved me. Lol.. def a locker in my future.
    And.. the last update.. just a few spare parts for 4wd conversion:
  14. Jun 16, 2020 at 6:54 AM
    #3174
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Are you planing to sas or add a front clamshell? Also which tranny are you using?
  15. Jun 16, 2020 at 7:04 AM
    #3175
    z_thompsonpa
    Patrick
    Austin, TX
    I want to find an fj80 front axle and sas it. Also going to source a gear driven xfer case from a mini truck and use an adapter plate to avoid any electronics in the conversion. Just focusing on transmission rebuild research atm. It's an a340e 4sp auto.
    Das it mang likes this.
  16. Jun 16, 2020 at 7:08 AM
    #3176
    5 Lug Fury
    Kenny
    Knoxville, TN
    I'm curious about our shafts I'll dm you :rofl:
  17. Jun 16, 2020 at 12:10 PM
    #3177
    jgwilson88
    jgwilson88 Well-Known Member
    Josh
    1999 Tacoma Single Cab, 2009 Tacoma TRD Sport DCSB
    1999 Rear lowered 2 inches 2009 2" Leveling kit
    Info on wheels please.
  18. Jun 17, 2020 at 6:45 PM
    #3178
    Das it mang
    Az
    1996 T100 SR5 MT
    U going that route versus LT? Would you say both would cost about the same? And what all are the details on this, sounds like a good idea haha. U building similar to the other 5 lug guy on here who sas his?
  19. Jun 17, 2020 at 7:35 PM
    #3179
    z_thompsonpa
    Patrick
    Austin, TX
    I really haven't decided anything other than sas-ing it for the front end. I may go with a non toyota axle and keep it a 5-lugger.
    I've been researching different build threads out there and trying to come up with a good plan. I like the idea of going 3 link or radius arm bc I recently found out about this crossmember.. which has to be replaced either way on our trucks to accept the transfer case. When you start reading what other people have done you start realizing you have a lot of options. I even saw where one guy did leave springs with hangers forward. Send me the thread your talking about, and Ill take a look.
  20. Jun 17, 2020 at 9:56 PM
    #3180
    Das it mang
    Az
    1996 T100 SR5 MT
    Wow u got me second guessing long travel and going this route instead. That cross member is such a good option for us.
    Might have already seen it but here is the one i was referring to
    https://www.tacomaworld.com/threads/5-lug-to-solid-axle—1997-tacoma-build.533243/
