Official 5-Lug Picture Thread
Discussion in '5 Lug' started by Yota Newb, Oct 26, 2010.
  1. Jun 9, 2024 at 3:35 AM
    #3541
    Mogely
    Mogely New Member
    Waco
    1998 Tacoma
    Belltech suspension, Corbeau seats, and a lot of cleaning
    My 1998 Tacoma
    holland1 and ireymon like this.
  2. Jun 9, 2024 at 5:40 AM
    #3542
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Cool shot
    Theboy07[QUOTED] likes this.
  3. Sep 19, 2024 at 6:23 PM
    #3543
    bottomfeeder777
    bottomfeeder777 Well-Known Member
    Lincoln
    Outer Banks, NC
    08 Single cab 5 lug
    3/2 inch lift, snorkel, 9k winch, stereo, only the finest air fresheners AutoZone has to offer
    Made myself a high clearance hitch. The one I had hung down way too low, especially with how I have the bedsides cut.
    Also 33x12.50r15 Hankook Dynapros
    5 Lug Fury and rblalliance like this.
  4. Sep 20, 2024 at 7:28 AM
    #3544
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    A high clearance bumper is on my short list. Even with 35s I still drag from time to time. That last photo almost looks like you got drag tires on lol.
  5. Sep 21, 2024 at 9:20 AM
    #3545
    1 Limited Toyota
    California
    08 XRunner
    I like the looks
  6. Nov 1, 2024 at 1:57 PM
    #3546
    Sjomxs1
    Sjomxs1 Member
    Costa Rica
    98, 2WD, 5 Lug, Extra Cab, A/T
    lifted unknown brand
    Here is my new to me ride...
    bottomfeeder777 and 5 Lug Fury like this.
  7. Dec 7, 2024 at 9:15 PM
    #3547
    trinidadlad
    trinidadlad Well-Known Member
    Dakota
    08 white base 5lug
    2015 5 lug work truck
    5 Lug Fury likes this.
  8. Mar 31, 2025 at 9:56 AM
    #3548
    KRH307
    KRH307 New Member
    Kelton
    Wyoming
    2000 Tacoma 5 lug SR5
    235/75r15 Toyo ATs Fuel lethal 15x8 wheels
  9. Apr 23, 2025 at 11:23 AM
    #3549
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    My 5 lug lemons racer.
    Tour991, 5 Lug Fury, gstodd and 2 others like this.
  10. Jun 29, 2025 at 3:35 PM
    #3550
    spacetiger
    spacetiger Well-Known Member
    Jerry
    99 Tacoma extra cab
    My 1999 Taco with less than 47,000 miles, 2WD with Ford Escape (2005-2007) 16" wheels. They were a surprising, good fit for a direct bolt on swap. I'll add more information when I start my thread on the newest truck parked in the driveway.
    ireymon and Bandido like this.
  11. Jun 30, 2025 at 7:11 AM
    #3551
    ireymon
    ireymon Unknown Member
    Kenneth
    Winston-Salem, NC
    99 X-Cab 5 lug 5 speed
    Hyundai wheels, dings & dents...
    YES!!! Looks great!
    Here's my '99 w/ 210k miles with 16" Hyundai Sonata wheels.
  12. Jun 30, 2025 at 10:34 AM
    #3552
    spacetiger
    Jerry
    99 Tacoma extra cab
    Yes, I saw your earlier posting which led into a much deeper dive into wheel options. Hyundai and Kia make the largest selection of options that match up well to our needs. Key for me on the wheel selection was the hub match up (67.1mm or 4.5") so the vertical load coming up through the wheel was carried through the hub and no use of hub adapters. I know some here have gone with wheels with a larger hub interface. I consider that a structural no-no because the studs would then have to carry that load + centering the wheel, something they were not designed for.
    There were lots of options and almost went with a 17" Kia wheel, but it looked too "Chip Foose"ish with a bigger diameter wheel and rubber band tire. Mine is a semi working truck, so no 17" rims. Even 16" rims had a too long looking spokes, so I chose a design with some extra "noise" on the spoke (at the ends) to reduce the look of the spoke length. Near the end of the search, I found that the Ford Escape wheel matched up well and had the extra design in the spoke to reduce the appearance of longer spokes. The only challenge was the center cap. The newer Toyota Yaris uses a size that fits (on order) the Escape wheel (2.125" OD).
    Tire selection was also a factor to try and keep the speedo close to factory setup. I went with 205/60 R16 size due to very good selection number options with sufficient load index for my use (92). The tire width keeps weight down and has less drag (width) - all small things but they add up.
    I'll post more when I finaly get my thread started. Since we have the same looking truck, I'dbe interested in all your mods to see what you decided to spent time and money on.
    ireymon likes this.
  13. Jun 30, 2025 at 11:15 AM
    #3553
    ireymon
    Kenneth
    Winston-Salem, NC
    Curious to see how that center cap works out. For a split second I thought about finding a cap to fit but I was digging the capless look.
    I went with 215/60/16 because that's what they had in stock at the time. Speedo is off slightly (only a couple MPH off above like 60) and MPG took a hit but i think that has more to do with the increased wheel/tire weight over the stock 14" combo.
    I'm lowered 2/3 and it handles decently but I'd love to step up to a lighter weight 17" at some point with better tires and kick it up a notch.
  14. Jun 30, 2025 at 12:28 PM
    #3554
    spacetiger
    Jerry
    99 Tacoma extra cab
    Your mpg probably did not take a hit. Remember with taller tires/wheels you are covering more distance than is indicated on the odometer. If you are figuring out mpg by dividing the miles from your odometer by the gallons used, your miles driven is understated with the taller tires. Download an MPH app on your phone and on the next 50+ mile trip use the app to tell you the actual distance covered vs indicated on the odometer. Use the GPS miles indicated to figure your MPG. Then, convert the GPS/odometer miles to a ratio to use from now on in your future MPG calculations. (Ratio x odo miles indicated)/gal used = actual MPG.
    I also lowered my rear by 1" so it sits with a slightly lowered rearend. I'm not going to do more as it's a 2.4 manual, so there are only so many beans that can move you down the road. In my motorcycle days, I chased mods to open up the riding envelope of almost every bike I owned. After 40 yrs of riding I learned if you want a larger riding envelope, move up to a bigger/more powerful bike. It's cheaper in the long run. I think that holds true for 4 wheeled cages too.
  15. Jul 1, 2025 at 6:09 AM
    #3555
    ireymon
    Kenneth
    Winston-Salem, NC
    The tire size difference is only 1% so i don't think it had that much of an impact on MPG but I could be wrong. I went from averaging 26 to 21. I don't remember the exact weights but the 14" wheel was like 15 lbs and the 16" wheel was like 22 lbs. I could definitely tell the difference in acceleration with the 16s!
    1 Limited Toyota likes this.
  16. Jul 1, 2025 at 11:04 AM
    #3556
    spacetiger
    Jerry
    99 Tacoma extra cab
    Are you referring to the dynamic tire size difference or simplified static tire difference? There is a difference between the two; I think the tire/wheel size you are running should be greater than 1% over stock (stock to me is the steel wheel running 195/75-14 tires). The easiest way to take the dynamic vs static reference out of the equation is to use a GPS app. It also takes into account your air pressures, etc. It will give a good difference between your speedo and odometer and what is really going on. We have a lot of speed cameras around here and the app speed is always the speed shown on the radar. This is the #1 reason I use/display the app reading while driving.
    Wheels will be different in weight and all logic tells you the smaller diameter of the wheel is less than the larger diameter wheel... until you take into account the mass of the tire. The 14" tire has a lot more weight than the 16" tire and that mass is spread further away from the center of mass. For a given radius of a wheel/tire combo, less rotational mass = better performance. So, your 16" wheel/tire should outperform the optional stock set up that uses the 215/70-14 tire. It probably outperforms the stock wheel too as the steel wheel is much heavier over an aluminum rim off setting any advantage the 195/75-14 tire might give the stock setup.
  17. Jul 1, 2025 at 3:20 PM
    #3557
    ireymon
    Kenneth
    Winston-Salem, NC
    Never heard of dynamic/static tire difference. Will have to give that a quick google.
    Stock for me was 215/70-14. Discount tire says 14" tire is 21.7 lbs and 16" tire is 23 lbs. I did weigh both wheels so the combined wheel/tire weights would be 36.7 lbs (14") vs 45 lbs (16"). 8.3 lb increase in rotational mass was certainly felt by the butt dyno.
    I should compare speedo to GPS speed at some point so I can see how far off it really is. that would be interesting to know.
  18. Jul 2, 2025 at 1:14 PM
    #3558
    Dirty Dude
    Dirty Dude Well-Known Member
    2004 Tacoma SR5 Xtra cab 5-lug
    Dirt, miles, and wear.
    You guys are overthinking it. The weight difference here isn't going to cause a measurable decrease in mpgs. There's an error in either the miles or gallons measured.
  19. Jul 13, 2025 at 10:29 PM
    #3559
    apbright
    apbright Well-Known Member
    Aaron
    2007 Silver Tacoma Base
  20. Jul 14, 2025 at 4:32 AM
    #3560
    spacetiger
    Jerry
    99 Tacoma extra cab
    Bolt pattern is fine; the offset can work but the centerbore at 3.3" (83.82 mm) is too big. That means you can offer up the wheel/tire to the vehicle but it will only be aligned to the axle centerline by the 5 lugs - now not the hub interface. The hub interface was designed to center the wheel on the axle AND carry the loads coming from the wheel; the lugs were not really designed to carry that load - they were there to pinch the wheel to the hub. To make it worse, the steel material around the center of the wheel has a small surface area at the center, the back drum is a large diameter and might be okay but the front hub is much smaller, so the wheel might flex at the front hub which puts more stress on the 5 lugs. I'm sure you're planning on running wider tires (the rims are 10" wide) so that will compound the front structural challenge.
    A Hyundai 17" steel wheel might work (bolt, offset and hub interface work), but they are only 7" wide. Hyundai wheel to the left, a 2001 Taco rim to the right, so similar design.
    It's possible the 2001 taco center cap can work on the Hyundi steel wheel but I'm not 100% sure. You can see from the diagram above it would mount differently on the Hyundai rim relative to the radial spokes but dimensionally it looks doable with some backside modification.
    here is a Hyundai rim on eBay: https://www.ebay.com/itm/145082222281?fits=Model%3ATiburon%7CMake%3AHyundai&_skw=2002-2009+17"+Hyundai+Tiburon+steel+wheel&itmmeta=01K04RCGXX29K95SMCA4W2JK7V&itmprp=enc:AQAKAAABEFkggFvd1GGDu0w3yXCmi1e31WkwrBw/oUZJFG7S9JFeTJavMA5GJsSXT0MZngOE4oEPSGH8D9IySHroQtFmLPliO0QPyTXetulcPWssqullcWuPexlPL4RFsr3sGAEZwXr1hknOijwLCpTm0u3g2G15qx4tBLVcdsQ+St6VYbZoLU1tCxqAMwMB0cFX1mwFY6x+WfI5iEA8ANfkdXuFZ/2DBxlJRtwleh/Pks8p84gmfjmkZG86N4Rjmd1qO+xnrtUZrSkD0tgdXEckZ0o4W8+91oSxA8mYx/m+vjcYPsCF1ZHomHgwnDeISZIW5OyY55pmxVNvNp+kP421NQOhgitm+7qGZc2Jd7HG1jd/wfVz|tkp:BFBMio-ymIFm
    Terra Hunter makes 2 tire options (LT245/70R17 @ 30.55" or LT245/75R17 @ 31.50") that you might be looking for that fits a 17" diameter/7" wide rim:
    https://www.venompowertires.com/Light_Truck/terra-hunter-xt.html
    Let us know what you do.
    Such is the life of a 5 lug taco.
