Official 5-lug Suspension Setup Thread
Discussion in '5 Lug' started by comiesutra, Feb 8, 2011.
  1. Sep 30, 2015 at 4:57 PM
    #341
    Bristow.907
    Bristow.907 Well-Known Member
    Onterrible
    07 AC sr5
    After 3 years of fatbobs kit, I can honestly say the shocks are on their way out. They are beyond rusted and bottom out extremely easy. I want to lift my 5 lugger more without spending a shit ton of money. Was thinking of getting the front blocks custom made bigger and another leaf or 2 in the rear.
  2. Sep 30, 2015 at 5:05 PM
    #342
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    IIRC .. if you are wanting additional height in the front - you have to take the Next Great Leap forward - a mid-travel kit. 2.75" is at the limit of adjustability for front end alignment in terms of the standard LCA ... i could be wrong, but i think that's the issue of going any larger for spacer lifts.
    Replace your rear shocks with Bilstein's 5100's.. you'll be happy again.
  3. Sep 30, 2015 at 5:07 PM
    #343
    Bristow.907
    Onterrible
    07 AC sr5
    Are the 5100 all the same in terms of fitment? Am i able to just pick up set off ebay or something?
  4. Sep 30, 2015 at 5:15 PM
    #344
    HackD
    William
    For the rear only, Part No. 24-185073 Front struts need to be 4600's.
    People have gone the cheap route, and put on 5100's yanked from a TRD that's been upgraded further from the Bilstein's.
    Rolis12 and SleazyPetey like this.
  5. Oct 7, 2015 at 6:10 PM
    #345
    Tomass321
    Tomass321 Well-Known Member
    Thomas
    San Luis Obispo
    2014 Base Tacoma access cab. 1994 Toyota pickup long travel
    Hey guys! Just picked up some new total chaos ucs's and sway away remote reservoir coilovers for a mid level travel setup :) ready to put them on this weekend
  6. Oct 9, 2015 at 3:54 PM
    #346
    4 Season Taco
    4 Season Taco Well-Known Member
    2010 5 Lug Taco
    Does a spacer lift restrict travel in the front end and should you put bigger bump stops?
  7. Oct 9, 2015 at 8:24 PM
    #347
    tunabrad
    tunabrad Well-Known Member
    Brad
    California
    2019 White DCSB SR5
    Pictures of it didn't happen....but seriously though would love to see some pictures! Thinking about doing the same
  8. Oct 10, 2015 at 4:18 PM
    #348
    Tomass321
    Thomas
    San Luis Obispo
    I will post pics when the rest of the parts come the coilovers from sway away will take a min of 2 weeks :( which is fuckin killin me due to a pismo meet up trip this weekend haha but the set up im doing is 6" 2.5 sway away reservoir coilovers with 500 pound eibachi springs with the sway away top mounts. Also the 5 lug total chaos made ucs's. Also have done the black box delete in the front for better clearance. That will be my current front set up just in case you wanted to know before i can get pics up
  9. Oct 16, 2015 at 12:45 AM
    #349
    Regularcabjordin122
    Regularcabjordin122 Well-Known Member
    Jordin
    Escondido, CA
    2013 white regular cab tacoma
    Pro Comp Alloy Wheels 16x8 4" of backspacing. BFG Rugged Trail tires 265/70/16 Icon 2.5 Coilovers Total Chaos upper control arms Custom leaf springs built by a friend of mine Bilstein rear shocks K&N Drop In Air Filter Crawford Performance Eco-Block Q3. 30" Baja Designs Hi-Power light bar mounted in the bumper
    Can somebody please tell me how stupid my truck would look if I installed the full fat bob kit with stock tires? I believe they are the 215/65r15.
  10. Oct 16, 2015 at 12:45 AM
    #350
    Regularcabjordin122
    Jordin
    Escondido, CA
    Quick correction 215/70r15
  11. Oct 16, 2015 at 5:26 PM
    #351
    HackD
    William
    Stock 5-lug tires are P-rated 215/70R15 Dunlop AT20's.
    If you are planning a level-lift using one of the common spacer/add a leaf kits - i strongly suggest that you don't plan doing it around the stock tires. They aren't all that great, and they won't last all that long. You can go up to 235/75R15 on the stock rims.
    The question shouldn't be 'will this truck look stupid?' .. it should be 'is there a reason to upgrade the stock suspension?' .. if there is no reason, you can upgrade the tires when they are past their due date, without messing with the suspension. There are trade-offs with messing with the suspension - a level-lift just by itself, will impact your fuel economy by 1-2mpg due to changed aerodynamics/being higher off of the road. It will however, firm your suspension up, and reduce body roll.
    My suggestion, plan around your reasons for a level-lift .. and go from there. You are going to need to spend money on it to address weaknesses as they appear - once a level-lift is done, the next weakness will be the tires/rims. (15x6 rims are stock - 235 width is the design limit on them).
    Not trying to spend your money for you - but these are the realities of improvements for this base truck, IMHO.
    TownvilleTim likes this.
  12. Oct 17, 2015 at 8:37 PM
    #352
    SleazyPetey
    SleazyPetey Popeyes > KFC
    Pete
    Northern Virginia, USA
    2013 Regular Cab
    Wait, HackD. 15x6 are the width limits with 235's? I have 235/75r15's, but wanted to get 15x8 wheels
  13. Oct 17, 2015 at 11:22 PM
    #353
    Regularcabjordin122
    Jordin
    Escondido, CA
    A
    are 235s equivalent to a 31"? Sorry still new to this tire stuff haha.
    If so could I fit a 15x10 inch wheel under the stock truck with 31s?
  14. Oct 18, 2015 at 6:16 AM
    #354
    SleazyPetey
    Pete
    2013 Regular Cab
    No, 235/75/r15 are not equivalent to 31's. The 235/75/r15 wheel diameter is 28.9 inches
  15. Oct 18, 2015 at 10:05 AM
    #355
    Regularcabjordin122
    Jordin
    Escondido, CA
    Could I fit a 31 under the wheel well? Or is that pushing it? I am going to lift it eventually. Also would I have to re gear?
  16. Oct 18, 2015 at 1:17 PM
    #356
    Tomass321
    Thomas
    San Luis Obispo
    You would be able to just make sure you do the black box delete to keep rubbing low and more clearance and regearing it would be useful if you are using it offroad
  17. Oct 18, 2015 at 1:36 PM
    #357
    Regularcabjordin122
    Jordin
    Escondido, CA
    May I ask what is the black box mod?
  18. Oct 18, 2015 at 2:09 PM
    #358
    SleazyPetey
    Pete
    2013 Regular Cab
  19. Nov 3, 2015 at 9:36 PM
    #359
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Hey guys I'm current sitting with stock suspension in the front and just a TRD Bilstein shocks in the back. I found a pair of nice rear shocks locally that I am considering grabbing but I think they may be a little too long.
    If I'm understanding this right the TRD Bilsteins are 13.98 in collapsed and 22.94 in extended. The new shocks I'm looking at are 14.75 in collapsed and 24.5 in extended.... is this too long and if so would an aal fix it?
  20. Nov 4, 2015 at 1:12 PM
    #360
    Rolis12
    Rolis12 Well-Known Member
    Rolis12
    San Diego
    2015 5lug access auto
    Goodyear Wrangler TrailMark 31's. F.B's 2.75" spacer, TRD rear shocks, stub antenna, ripped out charcoal filter added AFE dry, Chrome grille, upgraded to SR5 sun visors, variable wipers, backup camera, HID DDM 35w 5000kv, ebay fogs w/yellow LEDs.
    Has anyone put spacers in the front only and nothing in the rear? I'm going for a little + rake to the front. I searched TW but i can't find anything.
    Also I don't carry any loads and no cover. Is there any reason why I should do the rear? I'll be getting some better shocks.
