*Official* Ask A Detailer Thread
Discussion in 'Detailing' started by mShu7, May 12, 2008.
  1. Jan 7, 2018 at 8:07 AM
    #3181
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I have used it for that and it blackens the trim up but I’m not sure it will condition the rubber. If you wre just going for a good dressing for UV protection it works. I apply with a Qtip
    Kolunatic[QUOTED] likes this.
  2. Jan 7, 2018 at 8:14 AM
    #3182
    PackCon
    Connor
    Wax is, not really an outdated product entirely but it is in terms of a protective coating. I see most people use waxes for color/visual effects of paint.
    If you want a product that is going to keep your paint looking good and protect it. Go for a sealer. They last 6-12 months while a wax will typically last 4 weeks.
    A coating is something to consider if you want more clear coat protection from mud/dirt. Coatings are semi permanent to permanent and last 1-5 years. You can buy some coatings to apply yourself for a couple hundred. Professional applications run more like $800-$1,500.
    I would not waste your time on a wax. Especially on a silver truck. I would go for a sealer. They last longer and give a glass like look which I think makes silver shine better.
    PS paste waxes are not necessarily superior. There are many great liquid waxes. I like Chemical Guys Butter Wet Wax. Makes dark cars look awesome. Plus its cheap and easy. Its a good basic wax for most uses.
    Kolunatic likes this.
  3. Jan 7, 2018 at 8:58 AM
    #3183
    Onehugenut55
    Onehugenut55 Well-Known Member
    Dave
    2017 TRD OR DCLB
    Thanks for the help. Gonna give he chemical guys trim gel a try because it has a UV protectant built in.
  4. Jan 16, 2018 at 12:56 PM
    #3184
    Dudeman86
    Dudeman86 Well-Known Member
    Scottsdale, AZ
    2016 Black DCLB OR
    I have a question. I searched and found mixed results, so I am looking for a clear answer. Is it ok to power wash the engine bay, and if so, what precautions should I take? I frequent some really dusty places and would like to get the dust off after each trip. Thanks for any help.
  5. Jan 16, 2018 at 1:08 PM
    #3185
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I use a fine mist with some cleaners available at local ports stores. I cover alternator and that’s about it. I clean cold engine and start it afterwards. Been doing it for years on my 07 and it still looks new. Others may have suggestions.
    Dudeman86[QUOTED] likes this.
  6. Jan 16, 2018 at 1:22 PM
    #3186
    PackCon
    Connor
    You can you just need to be careful about pressure. You can’t blast your engine bay with 2500psi washer and not expect to knock hoses loose.
    Just use the hose. Not sure what dust a hose can’t take care of.
    I use Simple Green diluted 1:3 with watee for the engine bay and spray it down real well, let it sit for a few then hose it down.
    I have a long handle soft bristled brush I use to scrub before rinsing. My engine bay gets compliments whenever I open the hood. Looks new (except for my custom painted engine cover :))
  7. Jan 16, 2018 at 1:35 PM
    #3187
    Dudeman86
    Scottsdale, AZ
    2016 Black DCLB OR
    Awesome. I will start with the hose and see if that gets what I am looking for. I’m not looking for compliments, just a rinse. Thanks for the responses.
  8. Jan 16, 2018 at 1:40 PM
    #3188
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Forgot to add I’ve used both 303 and Black magic engine dressing afterwards.
  9. Jan 16, 2018 at 1:43 PM
    #3189
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    On many vehicles - Fords with modular motors for instance - pressure washing the engine bay is the kiss of death for many electrical components. (Ask me how I know that.) Toyotas on the other hand seem to be designed for the real world. I was hesitant to clean the engine bay on my 2014 Tacoma (and my 2006 Scion xB) until my son - a Certified Toyota & Lexus Service Technician - convinced me that with proper care it was indeed possible on Toyota products. As has already been said, "blasting" with a pressure washer can still lead to all sorts of problems. But by letting a cleaner do most of the work, and then using low pressure / low volume water to rinse everything off, you should be just fine. I actually just use a hand pump pressurized Garden Sprayer with hot water to rinse mine.
    One thing I do after cleaning my engine bays is whip out my Leaf Blower and blow most of the water off right after rinsing. I then fire the vehicle up and let it run for 5-10 minutes to bake off the rest.
  10. Jan 16, 2018 at 1:47 PM
    #3190
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    A lot of things have changed since I last worked in a detail shop over 30 years ago. But I’ll never forget one time. We were told to keep engines running while cleaning engine bay. Another guy was with me pressure washing a Mercedes when the engine choked,and started running backwards and died. We just walked away o_O
  11. Jan 19, 2018 at 8:40 AM
    #3191
    PackCon
    Connor
    Yeah but to be honest... that probably had nothing to do with you detailing the engine bay LOL
    You can look at a Mercedes and it will brake.
  12. Jan 19, 2018 at 8:42 AM
    #3192
    PackCon
    Connor
    Total random question...
    Do any of you use your DA polishers for other uses than cars?
    Looking at buying a new home and I’m wondering if my polisher could tackle counter top or shower insert polish jobs.
    Might be an excuse to use my PC for home use and upgrade to a Torx for auto use.
  13. Jan 19, 2018 at 10:51 AM
    #3193
    Too Stroked
    Tom
    I've used mine on my boat - generally just to apply Menzerna Power Lock. (The boat is a 1992 and has never needed or been buffed with a rotary.) I did use my Flex once at home to buff out some scratches in my bath tub.
    PackCon[QUOTED] likes this.
  14. Jan 19, 2018 at 12:16 PM
    #3194
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Sure do. Use it on stainless steel appliances. Bought a floor model fridge once at a great discount due to scratches and scuffs. Good ol’ PC removed them.
  15. Jan 25, 2018 at 10:58 AM
    #3195
    Onehugenut55
    Dave
    2017 TRD OR DCLB
    Any issues with using (Very) diluted laundry detergent to clean fabric seats. Would it be any better or worse than the fabric cleaners on the market?
  16. Jan 25, 2018 at 11:06 AM
    #3196
    PackCon
    Connor
    The only reason why I wouldn’t is because I feel laundry soap has a concentrated smell/scent.
    As a soap I’m sure its fine.
    When you do clean the seats though, spray them down with Scotch Guard (double cab takes a whole can). And then air out the truck well so it dries.
    It helps prevent future staining.
  17. Jan 30, 2018 at 12:55 PM
    #3197
    Wes0311
    Wes0311 Well-Known Member
    Wes
    Denver, CO
    '13 SR5
    Toytec BOSS loft kit, add-a-leaf, AntennaX 13" antenna, 285/75's on MB wheels, and more to come
    Sorry if it’s been asked - 161 pages is just a lot to sift through. I have a home carpet shampooer with extensions that I could use for seats and carpet. Would this be a good idea? Bad idea? Any specific soap I should use?
    If not this route, what’s the best way to clean the seats and carpet? Thanks in advance!
  18. Jan 30, 2018 at 12:56 PM
    #3198
    PackCon
    Connor
    Its a great idea just don’t use it often.
    The carpet on outr trucks is super thin and will start to fall apart with too much cleaning.
    Wes0311[QUOTED] likes this.
  19. Jan 30, 2018 at 12:57 PM
    #3199
    Wes0311
    Wes
    Denver, CO
    '13 SR5
    Thanks! It seems more efficient than something in a spray bottle. Any specific soaps you’d recommend?
    Edit: Or would the shampoo used for the house carpet be good? Would that work for the seats too, then follow up with the protectant mentioned above?
  20. Jan 30, 2018 at 4:06 PM
    #3200
    PackCon
    Connor
    Not sure I dont have a carpet cleaner. Look on detailing sites for a good auto carpet cleaner.
