*Official* Ask A Detailer Thread
Discussion in 'Detailing' started by mShu7, May 12, 2008.
  1. May 6, 2018 at 4:07 PM
    #3341
    LILBEAR
    LILBEAR Well-Known Member
    Winnipeg , Manitoba
    2018 Tacoma SR5 Black
    None brand new
    OK thanks ACE.
  2. May 6, 2018 at 4:08 PM
    #3342
    LILBEAR
    Winnipeg , Manitoba
    None brand new
  3. May 7, 2018 at 12:54 AM
    #3343
    Miggsy21
    Miggsy21 Active Member
    Miguel
    New York
    TRD PRO
    None
    A++++++
  4. May 7, 2018 at 7:23 PM
    #3344
    kravmaga
    kravmaga Member
    Utah
    2018 Inferno Tacoma TRD OR DCSB
    If you're wanting to use a foam cannon, most electric pressure washers are going to suck. Get a gas powered pressure washer. It's a myth that they are too much for cars. If you want you can always use an inline regulator to bring down the pressure, but it's not necessary if you use a 40 degree white nozzle and hold it away from the paint at least a couple of feet.
    When using a foam cannon the volume of water is more important than the psi. That's why electric pressure washers mostly suck; they just don't produce the volume needed. You can get some foam cannons that are specifically calibrated for low volume electric pressure washers, but they still just suck. People go to the Adams website and watch those guys use a foam cannon to spray shaving cream thick foam and wonder why they can't do it home with their electric pressure washer. They blame the soap. But the reality is that those guys are using a gas powered pressure washer. That's how they get that thick foam.
    I futzed around with various electric pressure washers and various foam cannons for some time until I got a Simpson 3300 psi and 2.5 gpm washer with a Honda engine--$399--and a good foam cannon. Zero regrets. I tried the cheap MATCC foam cannon and it sucked. I bit the bullet and bought a MTM. Night and day difference.
    crazychris4124[QUOTED] and Jcyr like this.
  5. May 8, 2018 at 8:22 AM
    #3345
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Question for the detailer. What do you use to remove water spots from cloth seats? I used a cloth cleanser solution and it did work, but left 3-4 quarter sized spots.
  6. May 8, 2018 at 10:57 AM
    #3346
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    My process:
    1. Clean stains with an upholstry cleaner from Walmart (aerosol can).
    2. Let truck seats dry overnight
    3. Spray all seats down with a can of Scotch Guard
    4. Let truck dry completely and air out overnight.
    5. Install Clazzio leather seat covers to ensure you NEVER have to deal with pesky water spots again
  7. May 10, 2018 at 4:23 AM
    #3347
    3Tacos
    3Tacos Well-Known Member
    Maine
    2017 Silver. TRD OR DCSB
    Sorry if this has already been asked, what’s the best way to remove tree pitch off my truck? Seems like the past few years the pines have been puking pitch in giant globs :annoyed:
  8. May 10, 2018 at 4:31 AM
    #3348
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Hows everyone take bugs and bird poop off without removing the fresh wax you put on
  9. May 10, 2018 at 6:16 AM
    #3349
    PackCon
    Connor
    Thats why you use a sealer or a coating and not wax. Wax will wear off much faster.
    Remove bugs gently with warm water and a pH balanced soap.
    Over the summer typically sealers will get rubbed off any place you have to do heavy washing. I usually reapply the sealer to the front end once you can tell its gone.
  10. May 10, 2018 at 7:30 AM
    #3350
    Jcyr
    Jack
    North east
    It was a synthetic wax that’s supposed to lastt 6 months
  11. May 10, 2018 at 8:03 AM
    #3351
    PackCon
    Connor
    So its a sealer.
    Just use a pH balanced soap and be gentle. You may have to reapply the sealer after a couple months if you feel its wearing off.
    Jcyr[QUOTED] likes this.
  12. May 10, 2018 at 8:25 AM
    #3352
    Jcyr
    Jack
    North east
    And clay bar should always be done before reapplying sealer right
  13. May 10, 2018 at 8:33 AM
    #3353
    PackCon
    Connor
    My rule is I always clay before any buffing motion.
    So yes clay before adding more to avoid swirls.
    And I would use a clay bar and not any replacement clay product. Just because they cause more marring and you won’t be paint correcting before adding another coat of sealer.
    BVita and DrFunker like this.
  14. May 10, 2018 at 9:15 AM
    #3354
    Jcyr
    Jack
    North east
    What do you mean replacement clay product
  15. May 10, 2018 at 11:02 AM
    #3355
    aphillips916
    aphillips916 Well-Known Member
    Aaron
    Winchester, Kentucky
    2018 Cement TRD Sport
    Best soap to use with foam cannon? Chemical guys?
    Also, when using s foam cannon what steps should be take after? Hand wash still?
  16. May 10, 2018 at 1:24 PM
    #3356
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    There are a million different answers out there for best soap. Find what you like and use it.
    You still have to hand wash after cannon. So lay down some foam then proceed to hand wash. Do not rinse off foam first.
  17. May 11, 2018 at 8:02 AM
    #3357
    ManInTheMaze
    ManInTheMaze Well-Known Member
    Mendo
    2003 and 2017
    So I removed my bed stickers the other day. I didn't use heat, I just got a corner with my fingernail and peeled it slowly. Might have been cleaner with heat. I used goo gone, washed the area and applied wax. I even did this again the very next day. However, when I pour water over the area (to rinse after washing, for example) the water maneuvers around where the sticker used to be and forms a vague outline of where the sticker used to be. And in the mornings when there is a mist layer on my truck, if you look at the right angle, you can see an outline of where the sticker used to be. Is this a concern, or will it go away with time? Is there anything I can do to get rid of this?
  18. May 11, 2018 at 8:14 AM
    #3358
    PackCon
    Connor
    Claybar the area. See if it picks up tge remainder of the adhesive.
    If you still notice it, polish it off.
    ManInTheMaze[QUOTED] likes this.
  19. May 11, 2018 at 8:31 AM
    #3359
    ManInTheMaze
    Mendo
    2003 and 2017
    Will do this weekend, thanks!
  20. May 12, 2018 at 6:03 PM
    #3360
    pudge
    pudge Well-Known Member
    Pudge
    Enfield
    2025 Bronze Oxide Trail Hunter
    So are foam cannons worth it? I use the 2 bucket method for washing. I just feel a foam cannon is just another thing to set up and just make the process longer. I have a life to live. LOL.
    CusterFan likes this.
