*Official* Ask A Detailer Thread
Discussion in 'Detailing' started by mShu7, May 12, 2008.
  1. Oct 1, 2018 at 3:51 AM
    #3521
    lynyrd3
    Bill
    East Central Upstate NY
    For the glass use 0000 steel wool and any window cleaner . Clay bar on the paint .
  2. Oct 1, 2018 at 3:57 AM
    #3522
    lynyrd3
    Bill
    0000 steel wool and any glass cleaner !
  3. Oct 1, 2018 at 4:02 AM
    #3523
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    Yeah, I wasn't very happy when I picked it up and saw that they just ran a DA over the whole thing. The whole truck is going to get ceramic coated soon so I might just pull them and replace after
    ALI3N_123[QUOTED] likes this.
  4. Oct 1, 2018 at 4:26 AM
    #3524
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Wait... a prodetailer did that?
  5. Oct 1, 2018 at 7:14 AM
    #3525
    Naumoff42
    Ohio
    2015 TRD Offroad
    Pro would be a bit of a stretch. A guy I went to school with who has taken up detailing as a side gig did it. Lesson learned.
    CusterFan and BVita like this.
  6. Oct 2, 2018 at 12:19 PM
    #3526
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    Feel your pain... we moved from CA to FL, started new jobs, bought a house and had our first child!!!! The tacoma and wife's car went a while without much love. Glad I clayed and sealed them before I moved, otherwise that FL summer sun would have done some serious damage.
    bigfoote13 and PackCon[QUOTED] like this.
  7. Oct 9, 2018 at 4:30 PM
    #3527
    PackCon
    Connor
    When you guys do your detail have you ever removed the plastic trim off the bed rails?
    I noticed this past time washing my truck there was quite a bit of nasty dirt under mine. I'm wondering if next year when I do my detail I need to pop them off and wash under them.
    Benzdriver81 likes this.
  8. Oct 9, 2018 at 5:56 PM
    #3528
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I also have some dirt under the plastic bed rails but trying to get off the rails without breaking the plastic clips is an obstacle in doing so that I don't want to risk and having to buy new rails, I try to lift up the rail and blow out the dirt under there the best I can but always seems to streak dirt anyways, mines super white and those streaks really look bad after busting my butt detailing and washing it.
    PackCon[QUOTED] and bigfoote13 like this.
  9. Oct 9, 2018 at 8:47 PM
    #3529
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    It would probably be a good idea. I have just enough play in my top caps that the water pressure dislodges any built up dirt without removing them.
    PackCon[QUOTED] likes this.
  10. Oct 10, 2018 at 3:30 AM
    #3530
    PackCon
    Connor
    My concern is rust.
    I’m not sure if you guys have pulled back your mud flaps but the friction between the plastic and paint have pretty much worn the paint off. I’m worried if there is worn paint under the rails Shoving water up there might be no bueno.
    I have white too and it streaks all the time.
  11. Oct 10, 2018 at 6:41 AM
    #3531
    BillsSR5
    bill
    2014 SR5
    I even get some of the same dirt streaks from my back side windows on my access cab part of the truck for some reason even after sudsing and rinsing numerous times, super white streaks again.
  12. Oct 10, 2018 at 6:46 AM
    #3532
    BillsSR5
    bill
    2014 SR5
  13. Oct 14, 2018 at 7:10 AM
    #3533
    Fishingeek603
    Fishingeek603 Well-Known Member
    New Hamphire
    2023 TRD Sport, Super White Access Cab 4x4
    Fox 2.0 front with res adjustable rears jba ucas icon rxt leaf pack.
    Any suggestions on door sealant conditioners for winter? I've researched and found that regular silicone supposedly does the trick, then I found the 303 product with mixed reviews some claiming there is now squeaking from the doors on any inclination or broken pavement after application.
    Thanks in advance!!
  14. Oct 14, 2018 at 1:17 PM
    #3534
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    I picked up a tube of Sil-Glyde from a cheap auto store down the road. The engine bay seals aren’t sticking to the hood like they used to, so I’m hopeful for this winter with the door seals. Here’s the Amazon link, but you can find it cheaper in stores:
    “AGS SG8 Lubricant” https://www.amazon.com/dp/B000KXLR5E/ref=cm_sw_r_cp_api_sk6WBb5VQ7V2E
    Is this the 303 protectant that you found, or were you looking at the regular 303 Aerospace protectant?
    “303 Rubber Seal Protectant and Conditioner for Weather Seals - 3.4 fl. oz.” https://www.amazon.com/dp/B00T44D1R2/ref=cm_sw_r_cp_api_zo6WBbADM5WFD
  15. Oct 14, 2018 at 1:45 PM
    #3535
    Fishingeek603
    New Hamphire
    Thanks for the links much appreciated!
    and the negative squeeky reviews were after applying the one you posted above
    Benzdriver81[QUOTED] likes this.
  16. Oct 14, 2018 at 3:08 PM
    #3536
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    I’ve never experienced it myself, but I can see where a softened rubber seal would squeak against an unwaxed surface. Or, the seal is so old that it slides instead of flexes. :notsure:
    I would clean off the seals with some mild soapy water before applying either of those products. Then clean and wax the mating surfaces/door jambs (spray wax works), and you should be good to go :thumbsup:
  17. Oct 15, 2018 at 4:01 PM
    #3537
    ecness
    ecness New Member
    Eric
    2018 Midnight Black Tacoma TRD Off Road
    None - just purchased
    I haven't a lot fo discussion on engine bay cleaning after offroading in the mud. Anyone with suggestions? Ive seen youtube videos, some using a shower hose with engine off, some with engine on. then degreaser like INOX, then just wipe down, and let dry. No consistent advice or tutorial except one, no high pressure hose because of the concern with electrical wire components/connectors.
  18. Oct 16, 2018 at 6:19 AM
    #3538
    PackCon
    Connor
    Just hose it down
    Do NOT leave a degreaser on the engine. Use your degreaser then hose the truck down. Always rinse well after any harsh cleaning products.
    But honestly if you are just dealing with mud I would hose down well and save the cleaners for your yearly or bi-yearly detail. No need to deep clean the bay several times a year.
  19. Oct 16, 2018 at 7:24 AM
    #3539
    BillsSR5
    bill
    2014 SR5
    ive read the same about using Silicone because it wont deteriate the rubber supposedly, ive never actually tried it myself, although I do use Silicone spray for my door mechanisms and hood latch lubrication, because it doesn't attract dirt and grit like WD40 or white lithium grease.
    Fishingeek603[QUOTED] likes this.
  20. Oct 16, 2018 at 7:26 AM
    #3540
    Fishingeek603
    New Hamphire
    thanks for the advice! hopefully someone will chime in that has used a certain product for x amount of years
