*Official* Ask A Detailer Thread
Discussion in 'Detailing' started by mShu7, May 12, 2008.
  1. Jul 29, 2019 at 10:25 PM
    #3921
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Thank you :thumbsup:
    pinktaco808 likes this.
  2. Jul 30, 2019 at 4:38 AM
    #3922
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    In.
    Really need to start washing on my own versus paying for it.
    I’ve seen a couple of things not mentioned in the OP:
    Clay 2.0
    Ceramic sealant
    What else do I need to know before I start buying stuff?
    Budget should be considered, and I wheel my truck, but I’d like it looking nice despite being scratched.
  3. Jul 30, 2019 at 11:54 AM
    #3923
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Maybe you guys can offer advice.
    I just got a craftsman 2.3GPM 2800PSI gas pressure washer.
    The thing is a champ but it doesn’t like to be started and used more than once.
    I can get it started and use it until I am getting empty on gas but if I stop it, tank it back up and go to start it, it won’t budge. It has to cool down before it starts again. Its like its not getting fuel. All seems to be OK with the fuel line but I havent checked it for obstructions.
    I run it for about 1 minute after I let go of the wand then shut it off so I try to not flood the carb.
    Anything simple I’m overlooking?
    Air flow is good and spark is good.
    Are these things designed like this?
  4. Jul 30, 2019 at 4:01 PM
    #3924
    gorram
    gorram Well-Known Member
    2016 Limited
    If temp related maybe it's a choke thermostat or something in that assembly that's bent or hung up when hot.
    PackCon[QUOTED] likes this.
  5. Jul 30, 2019 at 5:10 PM
    #3925
    pudge151
    Sean
    Connecticut
    You probably only need to clay once or maybe twice a year. A synthetic clay like 2.0 is great and a huge time saver.
    Before you clay you wanna wash really well, and ideally use some kind of iron deposit remover. Then use clay after rinsing off the fallout. Make sure you use lots of lube with your clay, important in other aspects of life as well.
    After you clay you'll wanna wash again and dry well. Then if you want to remove scratches and swirls you can with a polish and DA polisher, if not then move onto using a sealant or wax to protect your paint. If you wheel alot and get trail pinstripes then I wouldn't do a true ceramic coat. A sealant with sio2 in it would be great, like carpro reload or hydro2, of shine supply clutch.
    Once you have it sealed you should be able to use a good cash wash soap, and utilizing the 2 bucket, or multiple mitt meathod wash as often as you can. Reapply sealant every few months. You can also use a maintenance spray like beadmaker or megs ceramic wax as a drying aid when you wash, itll keep it looking great and repelling dirt and crap and make it much easier to wash. A good detail spray is nice for quick wipe down of bird crap or bugs splatter, there are a ton out there, griots speed shine is good and cheap and available. There is much much more you can do... but wash, clay, seal, maintain is the main stuff.
    jamesfishn09 likes this.
  6. Jul 30, 2019 at 5:12 PM
    #3926
    pudge151
    Sean
    Connecticut
    Remember that this thread was started 11 years ago. Detailing products and technology and techniques have come a LOOONNGGG way in 11 years
  7. Jul 30, 2019 at 6:18 PM
    #3927
    Naveronski
    Fort Worth
    Thank you! That's a great help. That's about what I had expected, and I do wheel it, so there are a ton of pinstripes.
    Right, that's why I wanted to come ask. Is there a more updated list?
  8. Jul 30, 2019 at 6:26 PM
    #3928
    pudge151
    Sean
    Connecticut
    There is just so many products out there your head will spin. I like detailedimage and autogeek message boards, also check out the detailing subforum on tundras.com, lots of good updated info there. That's where I learned. My suggestion is maybe choose a brand and get a few things they offer for different purposes. I suggest carpro, shine supply, optimum in that order. Be careful of your budget though. Lol
  9. Aug 9, 2019 at 4:22 AM
    #3929
    geoscot
    geoscot Active Member
    South Florida
    '17 TACOMA SR5, V6
    Bed Mat and Go Pro. Toyota made it so good, doesn't need much mods. Don't like getting her dirty!!
    Sounds like vapor lock, which is mentioned in some pressure washer product reviews. I have a Homelite 2700 psi that I got new from HD at a ridiculously low price of $120 several years ago. It has happened to me once but was able to choke out, flood, start in about 10 pulls. Now I just top off before use and it is not a problem. That’s my experience... good luck!
  10. Aug 10, 2019 at 11:10 AM
    #3930
    CoTacoTy
    CoTacoTy Well-Known Member
    White 2017 sr5
    So I was perusing these threads and read about a fabric cleaner that also protects the fabric, making it pretty much waterproof. But naturally I cant find that thread again. Does anyone know what I'm talking about? If I remember it was in like a red can I think it was aerosol but I'm not sure. Help? Thanks in advance!
  11. Aug 10, 2019 at 4:44 PM
    #3931
    gorram
    2016 Limited
    Scotchgard comes in a red can. The boutique detailing brands all have fabric coatings as well (carpro, gyeon, IGL). I've never used one but I hear your clothing can rub them off fairly easy over time. So durability on the drivers seat may be poor.
  12. Aug 14, 2019 at 12:09 PM
    #3932
    Maine_Tacoma13
    Maine_Tacoma13 Well-Known Member
    Hey mShu, I've asked this question in another thread and had some good input but figured I'd ask you since you're the pro. Thinking of removing badges/TRD stickers. I'm concerned about ghosting and I've read some sort of mild abrasive like Meguires Scratch X can sometimes help removing the ghosting. I've read though that then you should treat afterwards with some sort of wax/sealant.
    I'm looking for the most efficient way to take care of the paint IF I have to use scratch X to remove ghosting. I don't have a bunch of tools and stuff to use to treat so I'd just be good ol fashion human application. I'd be hoping not to spend the entire day working on it so efficiency/ease is ideal.
    Thanks!
  13. Aug 14, 2019 at 1:28 PM
    #3933
    pudge151
    Sean
    Connecticut
    If you have any ghosting you could try to polish out that area and blend it. I doubt it will be too bad though as your truck looks petty new. Its definitely a good idea to use something to protect any area that you debadge or polish. You could use a wax or a sealant. What do you normally use for paint protection on your vehicle? I prefer spray sealants like carpro reload or optimum optiseal. Both look great and give up to 6 months of protection and water beading. You don't need anything special but you wanna use something. Mind as well do the whole truck while your at it. You can get meguiars ceramic spray wax at most auto retailers and walmart. That stuff will work great for thos purpose and you can re apply it every 3 or 4 months forever to keep your paint looking good and prevent damage.
  14. Aug 20, 2019 at 5:20 PM
    #3934
    McTempleton
    McTempleton Member
    Brandon
    2016 Inferno Tacoma TRD Off Road
    Stereo Upgrade Pop & Lock tailgate Interior LEDs Interior & Exterior Decals Custom painted grill.
    I'm sure it has been mentioned but my searches didn't find it for me, so I will ask...
    Any tips / advice for restoring the black plastic and maybe even the paint near the exhaust. Bought the truck 3 years old, everything is in really great shape except for that area for obvious reasons. Didn't know if there was anything special to bring it back.
    Tried Mother's Back to Black on the plastic and a cheap Turtlewax product on the paint with no luck so far. (The back to black did wonder's on the Toneau cover though, literally took years of wear of it!)
  15. Aug 20, 2019 at 5:34 PM
    #3935
    pudge151
    Sean
    Connecticut
    Check out shine supply, they have trim shield which is really good but also what they call trim paint, I haven't used it but I hear it's legit. Shine supply makes some really good stuff, small company and amazing customer service. The owner will talk to you on the phone if you need help with something. Members over at tundras.com get 10% off there. I usually use carpro products but have found quite a few shine supply items that are better than similar offerings from carpro.
    For the paint, give it a good wash, then an IronX type spray, then use a clay bar or synthetic clay, then polish it out, I bet it'll clean up, maybe use compound then polish of it's really bad.
    McTempleton[QUOTED] likes this.
  16. Aug 21, 2019 at 2:22 AM
    #3936
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Heat gun.
  17. Aug 21, 2019 at 4:43 AM
    #3937
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    No. If you are not careful you will end up with blotchy plastic.
    I would suggest GTechniq C4. I have gotten over a year of protection out of it.
    McTempleton likes this.
  18. Aug 21, 2019 at 8:18 AM
    #3938
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Did my wifes jeep and it turned out great....
  19. Aug 21, 2019 at 9:06 AM
    #3939
    ace96
    Western KY
    I have done it as well. Don’t recommend it due to the blotchiness that will show up over time. You still have to do something to protect the plastic or you will have same issue again.
  20. Aug 24, 2019 at 9:48 AM
    #3940
    McTempleton
    McTempleton Member
    Brandon
    The clay definitely helped! That has been the first thing to dent that area. Unfortunately, I all ready have some blotchiness going on at the very bottom of the body panel that I know won't come out. Thankfully I don't think it is the actual paint, just that plastic film around the bottom 3 inches or so.
    Did the entire truck while I was at it, depressing when you get to see just how much little damage was done over the 3 years before I owned it. Stuff you don't notice casually or from more that a couple feet away, but now I know and I can't un-know lol. Going to hit it with the polish as a follow-up after lunch, hopefully that helps with some of the small scratches and swirls anyway.
    Thanks again for the advice.
    pudge151[QUOTED] likes this.
