*Official* Ask A Detailer Thread
Discussion in 'Detailing' started by mShu7, May 12, 2008.
  1. Jan 8, 2012 at 3:55 PM
    #821
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Pad color indicates the cut or aggressiveness of the pad. This varies from company to company, so if you know where they came from, I could help you out. I personally do not like the bonnets for removing wax, I just use a microfiber by hand as I find it is easier to remove the wax.
  2. Jan 8, 2012 at 5:40 PM
    #822
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Got them from autopia a few years ago but never opened it.
  3. Jan 8, 2012 at 5:59 PM
    #823
    fishntaco
    Josh
    Mobile Al
    Alright, so they are most likely Lake Country pads. In decreasing order of aggressiveness it will be Orange, White, Green, and then Blue. Use the orange with a polish and it will remove deeper scratches, etc. Then go to your white/green pad to refine the finish. Finally, use the blue pad to apply a wax or sealant.
  4. Jan 9, 2012 at 2:49 AM
    #824
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I use the blue pad and Menzerna Finish Polish PO85RD to really make a dark paint shine. This is a third step amd is usually not needed for our Tacomas.
    To apply a wax or sealant I use the red pad. 95% of the time I do this step by hand.
  5. Jan 9, 2012 at 3:56 AM
    #825
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    got a question for all you detailers out there. i have developed some type of film on my windshield that seems to be oil or something along those lines. it is transparent when the glass is dry but as soon as there is moisture you see the spots all over the windshield. i have used several types of glass cleaners including the invisible glass and s&n glass cleaners. ive also used rubbing alchohol to no evail. what do you guys recommend i use to get rid of this stuff cuz it makes it kinda difficult and tricky when driving in the rain.
    thanks
  6. Jan 9, 2012 at 6:01 AM
    #826
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Try a claybar.
    Do you have access to a polisher with a 4 in pad?
  7. Jan 9, 2012 at 6:02 AM
    #827
    TacoFMS
    Justin
    Louisa County, VA
    yep. i believe i do. ive got a brand new one in the box that i think is a little 4" palm polisher, cheap one from parts store. what would i do with it????
  8. Jan 9, 2012 at 6:04 AM
    #828
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Use a mild polish and polish the windsheild.
    What polishes do you have available?
  9. Jan 9, 2012 at 6:08 AM
    #829
    TacoFMS
    Justin
    Louisa County, VA
    hmmm i think i have some meguiars color x or what ever its called and maybe some of their just regular polishing compound cant rem. its at home and im at work.
  10. Jan 9, 2012 at 6:12 AM
    #830
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I would not use the Megs Color X.
    I would get a mild abrasive such as this:
    Look and see what you have at home. I woul also use either a yellow or orange pad. Set the PC on 4 and polish as you would the paint. You should see quite a bit of black dirt on the pad as you go along.
  11. Jan 9, 2012 at 7:15 AM
    #831
    TacoFMS
    Justin
    Louisa County, VA
  12. Jan 9, 2012 at 10:15 AM
    #832
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    thanks
  13. Jan 20, 2012 at 7:21 PM
    #833
    redrazr
    redrazr Psalm 118:5-6
    Baker, FL
    2001 Xtracab TRD PreRunner
    Bilstein 5100 front/rear, Method NV Diamond wheels, Mickey Thompson Deegan 38 265/75-16's
    I'm looking for a good pre-wax cleaner polish for my new car detail coming up in a few weeks. I definitely want something "non abrasive" because the paint will be in great shape when I get it. Just something I can use to clean the paint after claying it to lay down a good base for the wax.
    Does anyone know if this will fit into that category? I'm reading mixed reviews on it. Some people say it's non abrasive and some say it has mild abrasives? But one review said it's great for scratch free paint. Any help would be great!
  14. Jan 20, 2012 at 7:38 PM
    #834
    fishntaco
    Josh
    Mobile Al
    A prewax cleaner isn't really necessary after claying brand new paint. My suggestion would be to clay, then wipe the vehicle with a mix of Isopropyl Alcohol and water, then apply the wax. This will remove any oils, etc. that would prevent the wax from bonding.
  15. Jan 20, 2012 at 8:57 PM
    #835
    redrazr
    Baker, FL
  16. Jan 21, 2012 at 8:19 AM
    #836
    fishntaco
    Josh
    Mobile Al
    Both of those products contain fillers, which fill in minor imperfections, etc. On a brand new car, given the dealership wash boys don't get a hold of it, swirls should be very minimal, therefore a product like that serves very little use. I always use the alcohol/water mixture to prep for a wax or sealant as it thoroughly cleans the paint surface, leaving it with no oils that would hinder bonding.
  17. Jan 21, 2012 at 8:32 AM
    #837
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
  18. Jan 21, 2012 at 9:15 PM
    #838
    redrazr
    Baker, FL
    Oh ok cool. I appreciate the help man! I'm definitely going to tell them to not let the wash guys touch it!
  19. Jan 22, 2012 at 3:43 PM
    #839
    redrazr
    Baker, FL
  20. Jan 22, 2012 at 4:40 PM
    #840
    fishntaco
    Josh
    Mobile Al
    Sealants are more durably than a caranuba wax but sometimes looks can be sacrificed depending on the color of the car. You can top a sealant with a wax for better durability and looks, but not the other way around. A sealant will not bond to a wax. Are you opposed to using brands other than Chemical Guys?
