*Official* Ask A Detailer Thread
Discussion in 'Detailing' started by mShu7, May 12, 2008.
  1. Jan 13, 2013 at 10:04 AM
    #1061
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Use an electric leaf blower to blow off the excess water. Then blot dry with a quality drying towel.
    You will probably need to polish the truck to remove the stains.
  2. Jan 13, 2013 at 10:12 AM
    #1062
    DolphinJohn
    DolphinJohn Well-Known Member
    Nature Coast, FL
    '13 Access Cab 4x4 SR5
    Thanks for the quick reply.
  3. Jan 13, 2013 at 4:47 PM
    #1063
    SaveAHoRideATACO
    SaveAHoRideATACO Pro Tech
    Lake Harding, AL
    07 PreRunner TRD Off-Road 2WD
    3" Coil Spacer Lift to Front; 1.5" Add-a-leaf to Rear
    I live in Alabama where it is hot and humid in the summer months. I'm also in a rural area at a lake with lots of trees around.
    Problem: I have this moldy type stuff all around the rear window weather stripping. A regular wash doesn't even begin to touch this stuff. Anyone else have this problem? And, are there any good suggestions for cleaning this stuff without damaging the rubber or surrounding paint? Any help would be appreciated...I cleaned interior/exterior and waxed it for 8.5 hours today.
    The mold (or whatever it is) is on the rubber itself.
    Thanks
  4. Jan 13, 2013 at 5:19 PM
    #1064
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    303 Aerospace protectant
    http://www.amazon.com/s/ref=nb_sb_s...pace+protectant&sprefix=303+Aerospace,aps,205
    I am assuming that the mold is gone from the window trim after the detail today.
  5. Jan 13, 2013 at 6:15 PM
    #1065
    SaveAHoRideATACO
    Lake Harding, AL
    No it's still there. That is the problem. It's the only thing dirty on the truck at the moment. If I ever get it off, I'll definitely start using the protectant you recommended. Thanks for the reply.
  6. Jan 14, 2013 at 3:04 AM
    #1066
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    You might try a little bit of cleaner wax rubbed in with a cloth and your fingers to try and remove the mold without a lot of damage to the rubber.
    Go over to the Autogeek on line forums and search on "Mold on trim"
    http://autogeekonline.net/
    Very interesting reading.
  7. Jan 14, 2013 at 4:47 AM
    #1067
    SaveAHoRideATACO
    Lake Harding, AL
    ^Thanks 95SLE, I'll definitely give it a try.
  8. Jan 14, 2013 at 5:17 AM
    #1068
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    What I gleened is that mold is a living organism that has worked its way into the rubber. You will need to kill and remove the organism which will require an abrasive to be worked into the rubber. The megs cleaner wax, or another type if you already have one, will be the lease abrasive cleaner you can use on the rubber surface.
  9. Jan 14, 2013 at 6:07 AM
    #1069
    SaveAHoRideATACO
    Lake Harding, AL
    Thank you for your response Tom. Yeah, that stuff has been there for a good while now but it never bothered me that much until after I spent all that time and effort on cleaning the taco so well. Sounds like that stuff may do the trick with a little elbow grease. I know if it returns afterward, I'll probably have to find some kind of fungicide or something to get rid of it permanently. Anyway, once I do get rid of it, I plan on using that protectant you mentioned before.
    Thanks again.
  10. Jan 15, 2013 at 5:50 AM
    #1070
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    I live on the coast as well. I always try to park in a semi protected spot especially when it's windy. You could try clay to get the sap off but be gentle. I agree with 95sle though, sometimes a complete polish job is the best bet. Make sure you follow whatever you do with a hight quality sealant. It is important to have that sacraficial barrier, expecially on the coast.
  11. Jan 15, 2013 at 5:52 AM
    #1071
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    Some waxes could stain the rubber so do a test spot. Maybe try a all purpose cleaner.
  12. Jan 15, 2013 at 6:20 AM
    #1072
    SaveAHoRideATACO
    Lake Harding, AL
    ^ Yes, thank you, I'm aware of that possibility. A guy I work with has used that product before and he says that although it may seep into the rubber, it's pretty easy to work out if it does, and it doesn't leave the whitish residue afterwards.
  13. Jan 15, 2013 at 12:17 PM
    #1073
    JeanClaude
    JeanClaude Well-Known Member
    East Atlanta
    2009 Tacoma Prerunner
    For cleaning plastic/vinyl/rubber, try out 1z Plastic Deep Cleaner.
  14. Jan 15, 2013 at 2:52 PM
    #1074
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    1z makes a lot of quality products. I still have some of the iz polishes in my detail cabinet. Real easy to work with and just does a decent job.
  15. Jan 16, 2013 at 1:14 PM
    #1075
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Listen to your co worker. ;)
  16. Jan 17, 2013 at 8:08 AM
    #1076
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    There are some decent OTC products out there. Meguair's and Duragloss make some nice products. It would be wise for you to do your "homework" though. www.autogeekonline.net is packed full of useful information and helpful people. It has been a great resource for me since I bought my first new truck. The detailing bug has bit me very hard!
  17. Jan 25, 2013 at 6:19 PM
    #1077
    Bamafever50
    Bamafever50 Member
    Birmingham,Al
    13' Prerunner Dbl Cab V6 TRD Sport
    What about using a pressure washer on your paint, not just tires?
  18. Jan 26, 2013 at 6:32 AM
    #1078
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Perfectly fine, I do it all the time. Just keep the stream a safe distance from the paint.
  19. Jan 26, 2013 at 7:28 AM
    #1079
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    I always use a pressure washer when she is especially dirty. (like road salt) I use the yellow or green tip. 15 or 25 degree maybe?
  20. Jan 26, 2013 at 12:45 PM
    #1080
    Bamafever50
    Bamafever50 Member
    Birmingham,Al
    Here in Bama salt is not an issue but bugs are crazy during the spring and summer. I hav the Barcelona Red and it looks awesome shined up, just want to keep it that way. The clear coat seems above average on this color to me, my 02' white never shined like this.
