*Official* Ask A Detailer Thread
Discussion in 'Detailing' started by mShu7, May 12, 2008.
  1. Mar 17, 2013 at 7:35 PM
    #1141
    SR5808
    SR5808 Well-Known Member
    J10
    Honolulu,Hi
    Black Prerunner SR5
    Tint/ weathertech visors/ truxedo tonneau cover/ color matched front emblem and door emblems/ Clazzio Leather seat covers/debaged tail gate/depo black tail lights/color matched front grill/led headlights/ Pioneer Avh-5800/ Alpine Type R Front and Rear speakers/ Alpine Pdr-v75/ JL audio 10tw3/ Mr. Marv Custom sub box/amp rack/ Stealth Custom Series Stealth 6 17x8.5/ 265/70/17 Nitto terra grapplers...
    Hey guys,
    I have a black 2013 tacoma with water spots/stains on the paint. Black just shows everything. Anyways I was wondering how do I get rid of them? Any products that can help? Thanks!
  2. Mar 18, 2013 at 3:22 AM
    #1142
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I would start with a wash then use either Mothers or Meguires clay bar kit. If that takes care of the problem throw two coats of wax on the Tacoma and call it a day.
  3. Mar 18, 2013 at 6:30 AM
    #1143
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    I agree. If that doesn't work they have started to etch in and will require polishing to remove.
  4. Mar 19, 2013 at 11:18 PM
    #1144
    SR5808
    J10
    Honolulu,Hi
    Black Prerunner SR5
    Thanks guys, I've actually clayed my truck but the spots still remain. Which must mean its etched in. Any good water stains/spot remover out there for paint?
    Thanks again!
  5. Mar 20, 2013 at 3:29 AM
    #1145
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    mixture vinegar/distlled water
  6. Mar 20, 2013 at 5:07 PM
    #1146
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    Try a finishing polish and see if that will remove them. If not use a more aggressive polish.
  7. Mar 23, 2013 at 10:11 PM
    #1147
    Marcs2012
    Marcs2012 Well-Known Member
    Honolulu
    Trd sport
    Hello tw members I was wondering if anyone uses blackfire all metal polish and sealant to keep the stock rims looking new? Any reply if helpfull thanks
  8. Mar 24, 2013 at 4:17 AM
    #1148
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I have not used that product but have never heard anything bad only good reviews. I have used Megs 21 or Zaino Z2P or Z5P with great sucess on rims. Either product you use will make rim clean up a snap going forward after applying the product and your rims will look sharp.
  9. Mar 24, 2013 at 5:26 AM
    #1149
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Stock wheels are clear coated so a metal polish won't do much good. You should just use a light polish, such as what you would use on paint. Then coat with a sealant and you should be good.
  10. Mar 24, 2013 at 11:08 AM
    #1150
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I also use DP Wheel Glaze which cleans the wheels up rather well. On the Tacoma I have winter tires on the stock steelies and summer tires on a set of 17in rims. I clean them up before going into storage in the off season. Really nice to just take out the wheels, dust them off and be ready to install. I also use Zaino on the tires before going into storage as well and clean up the lug nuts too.
    Summer tires go back on in the 2nd week of April!!!!
  11. Mar 24, 2013 at 6:10 PM
    #1151
    Marcs2012
    Honolulu
    Trd sport
    Thanks guys for the info:cool: I was told by a detailer shop that sells product here and he said it will polish and seal it to keep them looking new. Just wanted to get some info before or If spend 30 bucks on it thanks everyone!
  12. Mar 30, 2013 at 12:27 PM
    #1152
    169.254.255.201
    169.254.255.201 Well-Known Member
    Interwebs
    Anyone have tips on cleaning out their applicator pads for a buffer?
    Also, how much wax should we go through in detailing a car? I used probably 3/4 of the carnauba wax. I never felt like there was enough going on to the paint. This is what I was using. When I was wringing it out for probably 30 minutes, I kept on getting wet wax that was lodged in there
    And any liquid wax anyone can recommend? Not a sealant.
  13. Mar 30, 2013 at 12:47 PM
    #1153
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    This is what I use to clean my buffer pads.
    http://www.chemicalguys.com/Chemical_Guys_BUF_333_16_Foam_Wool_Pad_Cleaner_p/buf_333_16.htm
    As far as the amount of wax to use, a little goes a long way. Using 3/4 of a container of wax sounds like waaaay to much!
  14. Mar 30, 2013 at 4:01 PM
    #1154
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Way too much wax on the applicator pad. I have used Mother's carnuba wax in the past done at minimum 4 cars with it and not even used half of the container.
  15. Mar 30, 2013 at 4:20 PM
    #1155
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I use a pad cleaning bucket. Cost a little more but makes pad clean up a snap.
    You are using way too much wax. Apply the coat so thin you can barely see it. Wait 12 hours and apply a second coat for a truly stunning finish.
  16. Mar 30, 2013 at 5:47 PM
    #1156
    169.254.255.201
    Interwebs
    So should I have dabbed the wax on a 2 by 2 area, then spread it using the pad, then used the machine?
  17. Mar 30, 2013 at 6:43 PM
    #1157
    28Gauge
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Google "Junkman2000". He has quite a few videos on detailing and how to use proper technique when polishing and waxing.
  18. Mar 31, 2013 at 4:27 AM
    #1158
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I usually use a foam pad to apply wax. With the P21S it is wipe on wipe off so the thinner the coat of wax is better.
    I usually let the 1st coat of wax sit over nite to cure/bond to the sealant. Then the next day I apply a second coat of wax. If you do this you will see the depth of color really come out on the vehicles finish.
  19. Mar 31, 2013 at 5:19 AM
    #1159
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    My door to window weatherstripping on exterior has "spotted". It was neglected one summer outside but now is parked in garage. I haven't ordered 303 protectant yet,just using what I have on hand.
    Would his help or is there anything else to try. I'm using clear magic,it seems to soak in and spots come back. I like meguiars products and have tried a back to black stuff by doesn't help.
    Thanks for help.
  20. Mar 31, 2013 at 7:43 AM
    #1160
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    I find that the only way to completely restore LSP pads is to soak in mineral spirits for several hours then wash them in pad cleaner(snappy). I then rinse many times and let dry. This is the only way I've been able to remove all traces of wax.
