*Official* Ask A Detailer Thread
Discussion in 'Detailing' started by mShu7, May 12, 2008.
  1. Mar 23, 2014 at 8:03 PM
    #1501
    Mops
    Mops Well-Known Member
    Mop
    NW NC
    I would try APC.
  2. Mar 24, 2014 at 7:37 AM
    #1502
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    APC and a small stiff brush should do the trick. Consider a protectant after the residue is removed. I find it easier to use sealants and waxes that do not stain trim. That way I can get right up to the plastic bits without worry.
  3. Mar 24, 2014 at 7:42 AM
    #1503
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    Ultima Waterless Wash + is the most versatile product in detailing! I use it to remove bird bombs, bugs, and smudges. If you are looking for something to use after a maintenance wash consider Duragloss Aquawax. With whatever product you choose make sure you use a high quality towel.
  4. Mar 24, 2014 at 7:53 AM
    #1504
    Mops
    Mop
    NW NC
    +1. The "waterless" products are pretty amazing. Adams has the waterless wash, and also released a rinseless wash recently as well. ONR is also very good.
    For sealant, Adams has a "quick sealant" product that comes in a aerosol can. Will not stain any exterior surface, and lasts 6+ months. I use the liquid sealant on my body, but find the quick seal to be amazing for trim, wheels, glass etc.
  5. Mar 24, 2014 at 12:55 PM
    #1505
    SR5808
    SR5808 Well-Known Member
    J10
    Honolulu,Hi
    Black Prerunner SR5
    Tint/ weathertech visors/ truxedo tonneau cover/ color matched front emblem and door emblems/ Clazzio Leather seat covers/debaged tail gate/depo black tail lights/color matched front grill/led headlights/ Pioneer Avh-5800/ Alpine Type R Front and Rear speakers/ Alpine Pdr-v75/ JL audio 10tw3/ Mr. Marv Custom sub box/amp rack/ Stealth Custom Series Stealth 6 17x8.5/ 265/70/17 Nitto terra grapplers...
    Can anyone recommend a good combo for a one step/stage polish? Thinking about a lake country white pad with megs m205 on a flex polisher. Thanks.
  6. Mar 24, 2014 at 1:53 PM
    #1506
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    The Megs 205 is usually used with 105 as a two step system.
    Do you only have swirl marks to remove?
    What do you have available at no additional cost to you?
    If you have an orange pad you can try that with the m205. The white pad may leave some very light trails. Which ever way you go work the buffer across the surface slowly. As with any combo try it out on a 2ft section of the hood to see if you like the results before doing the entire vehicle.
    Lots of guys like HD Speed product as a AIO one step.
    I have used Megs D151 as a one step AIO with success. Usually with an orange pad.
  7. Mar 24, 2014 at 1:56 PM
    #1507
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    I would def recommend CG Black Light if you are looking for an AIO! Works extremely well and application method truly determines results of what it is best at, either a polish or sealant or glaze.
  8. Mar 24, 2014 at 8:36 PM
    #1508
    SR5808
    J10
    Honolulu,Hi
    Black Prerunner SR5
    I have swirl marks and water spots. Just looking to improve my paint but not make it flawless. It is my daily driver. Plan on buying the pads and polish product and rent the machine. I thought the orange pad was a more aggressive pad than the white. Not too sure though. Got more research to do.
  9. Mar 24, 2014 at 8:38 PM
    #1509
    SR5808
    J10
    Honolulu,Hi
    Black Prerunner SR5
    Heard good things about it. Isn't it more of a glaze though. Might use it as the glaze after my polishing step. Then an LSP after it.
  10. Mar 25, 2014 at 3:34 AM
    #1510
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    It is a little more aggressive but it works well getting rid of light swirl marks.
    I would just skip the glaze. The fillers usually wash off after two washes.
  11. Mar 25, 2014 at 3:59 AM
    #1511
    TacoFMS
    Justin
    Louisa County, VA
    It has glaze properties as well as a sealant and some very fine abrasives in it for a very light polish as well. If you use it with something like an LC gold pad it will act as a glaze and sealant. yet if you use it with say a blue LC pad it will act solely as a sealant, but if you use it with maybe a green or gray LC pad then it will act as a final polish with built in sealant. I have used it several times, think i am on my 2nd or 3rd bottle, and i typically use it with a gray pad and then top coat it with either jet seal or something like that and then whatever carnuba is next in the line up...
  12. Mar 25, 2014 at 7:51 PM
    #1512
    SR5808
    J10
    Honolulu,Hi
    Black Prerunner SR5
    Thanks guys. Looking to get some good correction power but want it to finish out fine with no marring or micro swirls. If that makes sense? Might be tricky w a one step polish bit I will try.
  13. Mar 26, 2014 at 4:03 AM
    #1513
    TacoFMS
    Justin
    Louisa County, VA
    I'm afraid you may have unrealistic expectations out of a one step. You say you want "good correction power" and "no swirls or marring". Unless I misunderstand what your idea of good correction power is, then you cant really get both out of a product. In order to make the good corrections then the polish has to abrasive enough to put the fine scratches and slight haze into the finish, then you have to step down to a finer polish to get those marks out and so on and so forth until you get to a finish polish, or if the correction needed is not that bad then you could use a less severe first polish and finish with an all in one. but an all in one is not going to be "the best polish" or "the best glaze" or even "the best sealant". because it is trying to be good at all three and a devoted sealant or glaze or very fine polish only has to be good at one thing.
    Make sense? Hopefully you dont take that as me trying to burst your bubble, and instead take it as me trying to pass on the knowledge that Tom and others have shared with me.
    BTW CG has a 10% sale on their PC 7424xp's no coupon needed it just is instantly applied when you put it in your cart, so maybe you can use another coupon on top of that???
  14. Mar 26, 2014 at 7:42 PM
    #1514
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    nvm misread
  15. Mar 27, 2014 at 10:13 AM
    #1515
    Creole Knight
    Creole Knight Man's got to know his limitations.
    Ulysses
    So. Cal
    05 Super White PreRunner
    gear shift knob and other things.
    I have a set of XD rims black satin finish but the inside of the rims are looking pretty bad with brake dust what should I use to get the rims looking good again, I was also wondering if you could suggest something to keep up my plate bumpers they are powder coated satin black also.
  16. Mar 27, 2014 at 11:41 AM
    #1516
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Wash with your regular paint soap solution. Clay bar then seal with a synthetic sealant such as Meg's 21.
    After doing the wheels with the clay bar plan on tossing the clay bar. Use 1/3 of a full clay bar rather than the entire bar.
    If you like the sealant do a second coat.
  17. Mar 27, 2014 at 7:28 PM
    #1517
    Lindsey Walrod
    Lindsey Walrod Well-Known Member
    Lindsey
    Oregon
    '13 black beauty
  18. Mar 27, 2014 at 7:32 PM
    #1518
    jeffy
    jeffy Well-Known Member
    Jeff
    WV
    '11 base mgm...1st pickup/4x4
    intermittent windshield wiper redline hoodstruts bfg rugged terrain
    Just washed my truck today because the weather forecast says it's not supposed to rain for a few days...But a few hours after I'm done washing/detailing..guess what?!?! It f'n rains!!!
  19. Mar 27, 2014 at 7:55 PM
    #1519
    Coast2Coast
    Coast2Coast Well-Known Member
    Northern Alberta
    2009 TRDOR
    Black Sand Pearl factory paint - flattened "au natural" by tree branches.
    Swissvax Opaque wax is designed for vehicles with matte paint jobs, but it is $$$$$. The container will last you a lifetime though for personal use. It's what goes on the lambos and ferraris you see rolling around in matte. There are more and more matte wax options popping up as matte paint has become trendy again lately.
    The best way to keep the inside of those wheels looking good is to coat them with whatever wax or sealant you plan to use before you even have tires mounted on them. Then take them off once in a while and give them a good cleaning, reseal them. Your best bet now is to just take them off and go at them with an aggressive all purpose cleaner and a soft brush. Rinse them really well when you have them good and clean. You might be interested in a product like iron-x to dissolve all the brake dust that's become embedded into the wheel. Then you can follow up with a clay bar, final clean up with mild soap or 15% isopropyl alcohol, then seal them up.
  20. Mar 27, 2014 at 8:26 PM
    #1520
    Coast2Coast
    Northern Alberta
    2009 TRDOR
    When you say flex polisher do you mean the 3401VRG? If that is the case I'd recommend you try and find a place that can get you the meguiars microfiber polishing system. If you have an air compressor, this is the kit to get. Clean the pad off with your air nozzle at 90PSI after EVERY section, this is important to make it work. The 6" kit is pretty much designed for the flex 3401 because it is a forced rotation random orbital and has the extra kick to spin the larger pads, all other normal random orbitals (PC9424, Griots DA polisher, Megs G110) should use the 5" kit. It's about the most user friendly system I've ever seen, just use as they suggest in the videos.
    If you don't want to spend any more money then there's no stopping you with the megs 205 on a white pad, that will be fine and will improve the look. If you find you want more correction than that, you can just use the same polish on an orange pad and get more correction, but you may get a bit of haze and have to clear that up by going over it again with the same polish and the white pad. Your choice. Clean the pad with a dedicated cloth after each section.
    If you're using the flex rotary polisher than that's a whole different ball game. But I'm guessing that's not the case.
    When you've finished polishing clean the polishing oils and residues off by washing with a wax stripping soap or dawn dish soap, and giving it a wipedown with 15% isopropyl alcohol if you want to. That will make your sealant last longer. Finally, apply your wax/sealant as your last step.
