Official Colorado HAM and cheese thread
Discussion in 'Colorado' started by Stig, Apr 18, 2016.
  1. Jan 2, 2017 at 1:58 PM
    #481
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    I just unscrew the antenna from the base for car wash, low garage, etc.
    @BDN my whole set up is pretty brainless. Didn't put any @thefatkid technicianing into it, just set it up and ran it and it works well.
    So easy even a choo choo aficionado could do it.
  2. Jan 2, 2017 at 2:04 PM
    #482
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
  3. Jan 2, 2017 at 2:04 PM
    #483
    thefatkid
    Brian
    Colorado
    2004 thingy
    Do you have a body mounted antenna for the 2m/70cm stuff?
  4. Jan 2, 2017 at 2:06 PM
    #484
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    nope. Tram mag mount.
    handheld, external mic/speaker, battery adapter for power, antenna adapter for tram mag mount on roof, cable ran in through back slider (can even close/latch the slider)
    the whole set up can be installed or removed in under 5 minutes.
    I think it's just not as hard as your 200jiggawatt breaker breaker rubber ducky stuff.
    jubei and CO MTN Steve like this.
  5. Jan 2, 2017 at 2:09 PM
    #485
    Stig
    Stig [OP] Resident smartass
    Brandon
    Ta no mo
    If i need it down for some reason, I'll just tip it over... For the garage, it'll just hit... Maybe I'll just keep it like that.
  6. Jan 2, 2017 at 2:11 PM
    #486
    thefatkid
    Brian
    Colorado
    2004 thingy
    Generally most people with have more "plug and play" luck with mag mounts. Even with CB those mag mounts do really well when they are close to center mass. They generally have a really good factory tune knowing they are going to be roof stuck.
    Try a ditch light bracket mount or off of the bed rail, even the front bumper
  7. Jan 2, 2017 at 2:25 PM
    #487
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Hey Brett, do you mind if I ask where you found that deal? Thanks!
    ETA: Disregard. I'm guessing it's Amazon based on previous posts.
  8. Jan 2, 2017 at 3:01 PM
    #488
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    @BDN I have become proficient in CHIRP over the last few weeks and have a good "master" file built. I have already programmed 6 Beofangs with the file. I can help you out with the programming. I have a Beofang now for walking around and I am working on a Yaesu that will stay in the truck all the time.
  9. Jan 2, 2017 at 3:10 PM
    #489
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Did you not like the master file we had started on earlier in the year?
    Hated it so much you didn't even want to collaborate on it? :D
    One thing to note about the baofeng radios... Even radios that look identical, with identical model numbers, can have different firmwares and not accept the same img file.
    Best practice I've found is to download the stock setup, save it, then save a copy and import channels and settings into that file and upload it back on to the radio.
    CO MTN Steve likes this.
  10. Jan 2, 2017 at 3:14 PM
    #490
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Order the radio with standard battery, then add the 3800mah to it. They charge the extra 13 bones for the battery either way, Alone or with radio. Sorry, on my phone or could explain better.
  11. Jan 2, 2017 at 3:16 PM
    #491
    jubei
    NoCo
    Stuff. Also things.
    Thanks, Brett :thumbsup:
    Deathbysnusnu[QUOTED] likes this.
  12. Jan 2, 2017 at 4:24 PM
    #492
    Gramps
    Gramps
    07 TRD DC 4x4
    I don't recall this file you are referring too. But that doesn't say much.
    Screw .IMG files. Everything is just saved in .CSV. I copy and paste it over. I have had zero issues not VR3 and VR5 models with this method and CHIRP. Biggest issue is have seen is the radio being programmed initially on different COM'S and CHIRP does not auto detect that.
  13. Jan 2, 2017 at 4:29 PM
    #493
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    it's in the OP. I had to shame @aero3685 into bolding it and everything so old folks like you could see it.
    The idea behind the common file was that all of our colorado wheeling group could have identically programmed radios making channel selection easy for new users until they get the hang of offsets and tones for repeaters and such.
    I'LL PUT ANOTHER LINK RIGHT HERE FOR YOU GRAMPS
    https://drive.google.com/drive/folders/0B0nBiqObudNyQjFFZ3RxdWFucjg
    I'd be interested in seeing what you came up with.
    CO MTN Steve, alee891 and Stig[OP] like this.
  14. Jan 2, 2017 at 5:53 PM
    #494
    Gramps
    Gramps
    07 TRD DC 4x4
    :facepalm:
    Cool. The Moab ones would be nice to add to mine. I haven't filtered down Utah yet. I also have race channels on my file that I sourced somewhere.
    Basically what I have done is grab a master file of all channels and repeaters by state for the western states in .CSV from CHIRP. From there I can tailor build a file for the Beofang based on where I will be since it is limited to 127CH. Just copy and paste he CSV files together until I have what I want. Then import that into CHIRP and copy/paste it over to the radio load file.
    I need to start building a file for the Yaesu. But it will be easier because I don't have to filter out so much since it will hold 1000CH. Also the Yaesu does not play well with CHIRP. So I will again build the file in CSV first and then import it into the Yaesu programming software. I also got the proprietary Yaesu cable that I will leave attached to the radio after install. I will tuck the cable until I need to program the radio again. I will just pull it out and attach it to my Surface.
  15. Jan 2, 2017 at 7:25 PM
    #495
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    That was part of the reason I chose my kenwood. It works OK with chirp......the same file for everyone should make things easy......
  16. Jan 3, 2017 at 3:49 AM
    #496
    Gramps
    Gramps
    07 TRD DC 4x4
    Yeah but I wanted the data cable anyways for future programming and the software comes with the cable.
  17. Jan 3, 2017 at 6:36 AM
    #497
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Sorry for disappearing, wanted to add. The "regular" battery makes the length of radio "small/ short" kind of like trying to hold one of those mini cell phones. The 3800 battery adds over an inch and much easier to hold the radio for my big mits.
    alee891, Stig[OP], Gramps and 2 others like this.
  18. Jan 3, 2017 at 11:19 AM
    #498
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    What are you getting for approx distance with the upgraded antenna? Sorry if that was already answered...
  19. Jan 3, 2017 at 11:33 AM
    #499
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Never really tested it but once on Alpine loop we were in Animas Forks and I could talk to buddy coming out of American Basin up the switchbacks somehow (Cinnamon Pass high point between us)
    alee891[QUOTED] and Stig[OP] like this.
  20. Jan 3, 2017 at 11:52 AM
    #500
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Those using the Magnetic Antenna's, what are you using to keep the Antenna set screw from coming out (Which is why I stopped using it)
