Official Colorado HAM and cheese thread
Discussion in 'Colorado' started by Stig, Apr 18, 2016.
  1. Feb 22, 2017 at 6:32 AM
    #601
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Could someone shed some light on the adapters needed to get a Baofeng connected to a mag mount antenna? I ordered the adapters detailed in the first post of the thread, but was sent two female adapters and have no way to connect everything together :notsure:
    Bummed because I tried to get everything up and running last weekend and now I just have an antenna mounted for looks...
  2. Feb 22, 2017 at 6:37 AM
    #602
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Hey Austin, this was just posted over in the EAF thread. Not sure if the adapters mentioned might help or not.
    Also, I JUST posted in your build about the shopping list of HAM stuff you recently bought. Shoulda posted here...
    alee891[QUOTED] likes this.
  3. Feb 22, 2017 at 6:39 AM
    #603
    alee891
    Austin
    Black Hills
    Tacomaless
    I'll take a look in the other thread and get back to later today! Have a meeting to get to right now
    jubei[QUOTED] likes this.
  4. Feb 22, 2017 at 6:43 AM
    #604
    jubei
    NoCo
    Stuff. Also things.
    :thumbsup:
  5. Feb 22, 2017 at 7:08 AM
    #605
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Take it over to HAM Radio Outlet in Aurora and they will get you whatever you need to make it work. Cost me $4 I believe for my adapter. Tons of knowledge there too.
    http://www.hamradio.com/locations.cfm?storeid=10
  6. Feb 22, 2017 at 7:42 AM
    #606
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
  7. Feb 22, 2017 at 10:06 AM
    #607
    WillT
    WillT Well-Known Member
    Colorado
    '21 Colorado ZR2 Bison
    Baofeng Tech imports the BF-F8HP
    Baofeng US imports the BF-F9 V2+ HP
    There's a lot of arguing online which importer is actually the "real" Baofeng.
    A lot of the evidence points to the BF-F9 V2+ HP having older firmware and being less compatible with some data cables. Technically the two radios are the same hardware.
    I believe most of us that have this style radio have the BF-F8HP which, with the big battery, is about $15 more expensive.
    BF-F8HP HT:
    https://www.amazon.com/BaoFeng-BF-F...e=UTF8&qid=1487786439&sr=8-4&keywords=baofeng
    Big Battery:
    https://www.amazon.com/Baofeng-3800...rd_wg=drOo9&psc=1&refRID=E6BAAXDRW7DMZHDQSFW4
  8. Feb 22, 2017 at 10:45 AM
    #608
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    https://www.amazon.com/gp/product/B00CVQP7CW/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
    jubei likes this.
  9. Feb 22, 2017 at 11:58 AM
    #609
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    You will want and need the extended battery regardless of choice. Comes in pretty colors is about everything else I could add. I have seen a few that are waterproof to X feet as well.
    Oh, it has 8 watt ability are most are 5 watts so a bit more power.
    Deathbysnusnu likes this.
  10. Feb 22, 2017 at 12:59 PM
    #610
    alee891
    Austin
    Black Hills
    Tacomaless
  11. Feb 22, 2017 at 2:12 PM
    #611
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Thread it in to the radio first.
    The antenna connection has a ring that spins independently but if you connect that first you'll have to twist the wire all up to thread it into the radio.
    jubei and alee891[QUOTED] like this.
  12. Feb 22, 2017 at 5:33 PM
    #612
    alee891
    Austin
    Black Hills
    Tacomaless
    Welp, found out I have SMA male adapters. Package says female to female - not the case. I may checkout the place @CO MTN Steve mentioned tomorrow and pickup the correct ones.
    CO MTN Steve likes this.
  13. Feb 22, 2017 at 6:23 PM
    #613
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    OR say fuck it and order up a Yaesu and an NMO mount antenna. Then load that fucker up with 1000 channels and you are good to go! :D
  14. Feb 22, 2017 at 6:24 PM
    #614
    jubei
    NoCo
    Stuff. Also things.
    Hey Austin, FWIW, for SMA connectors and RF connectors in general, the sex of the connector is determined by the center contact, not the threaded mating feature. So a socket center contact is a female connector and a plug contact is male. Apologies if this is already old news....
    Also, adapters can be a PITA to identify. The one in the Amazon listing at the bottom of the page says "SMA female TO UHF female adapter". It is more accurately an adapter consisting of an SMA female connection and a UHF female connection that mates a male SMA to a male UHF. So the description is of the adapter itself, NOT was it is used to adapt to.
    Not trying to be pedantic or anything, it's just potentially confusing.
  15. Feb 22, 2017 at 6:34 PM
    #615
    alee891
    Austin
    Black Hills
    Tacomaless
    Thanks for the clarification, Jason. When I purchased the adapters I blindly purchased a similar item to those provided in the initial post - the wait time for the ones in the initial post was something like a month. It was simply an ordering mistake on my part. When I first installed everything it was around midnight (after the tcase work) and I just didn't have the patience to look into it at that time. I'm hoping a local shop has exactly what I need tomorrow!
  16. Feb 22, 2017 at 6:47 PM
    #616
    jubei
    NoCo
    Stuff. Also things.
    Good luck, man!
  17. Feb 22, 2017 at 7:15 PM
    #617
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Just downloaded an app that was posted a while ago. Starting to take the practice exams. Pretty interesting stuff
    jubei likes this.
  18. Feb 23, 2017 at 7:57 AM
    #618
    alee891
    Austin
    Black Hills
    Tacomaless
    That's the tentative plan at some point :)
    Gramps[QUOTED] likes this.
  19. Feb 23, 2017 at 7:58 AM
    #619
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Trust me they have everything, take the antenna like I did and you will know right then. I need to go back and talk about hard mounted NMO antenna mount I went to put in roof.
  20. Feb 23, 2017 at 8:08 AM
    #620
    alee891
    Austin
    Black Hills
    Tacomaless
    Do you know of any shops north of the city? That's like an hour drive with traffic from where I'm at :oops:
