Official Group buy for gears and lockers!!
Discussion in 'Group Buys' started by 97yota4wd, Nov 23, 2011.
Thread Status:
Not open for further replies.
  1. Feb 26, 2012 at 10:45 AM
    #521
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Just picked up 35s last night, now I need gears!!!! :D
  2. Feb 26, 2012 at 11:40 AM
    #522
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    NICE!
  3. Feb 27, 2012 at 4:31 PM
    #523
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Called and left a message. I think I need:
    - T8S-456RT-NGTOYOTA 8" REV CLAMSHELL IFS 4.56 THICK R&P(FITS 3.73 CARRIER) $198.90
    - TV6-456-29-NGTOY 8" 4.56 R&P ALSO TACOMA W/LOCKER HD 29 SPL V6 DESIGN (USES 01+YOKE) $194.98
    Sorry if this has been covered, but would I need install kits for those?
    Thanks!
  4. Feb 27, 2012 at 4:34 PM
    #524
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Yes and which one really depends on how many miles you have on your truck. If i remember correctly he told me anything over 100k miles you should get the master install kits. I have 60k and am changing my rear end eventually so i went with the cheaper install kit.
  5. Feb 27, 2012 at 4:35 PM
    #525
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Im not even at 50K miles
  6. Feb 27, 2012 at 4:38 PM
    #526
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Double check when you finally get ahold of him but im sure he'll tell you that youll be fine with the cheaper install kits. Where are you getting them installed?
  7. Feb 27, 2012 at 4:39 PM
    #527
    blackhawke88
    SGV, CA
    07 TRD Offroad
    When I take my truck into Engage probably, get everything done at once
  8. Feb 27, 2012 at 4:41 PM
    #528
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Right on, that reminds me I forgot to call and order spindles today. Oh well tomorrow.
  9. Feb 27, 2012 at 5:46 PM
    #529
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    So i talked to a buddy of mine who owns a transmission shop and i told him i ordered the mini install kits only and he went on to tell me that almost every toyota his shop has done gears on they have to replace the bearings, not because of miles put on them but because they are pressed on and they are very easily damaged when taking them off! If yall know tha mini kits dont come with bearings so if while installing gears a bearing gets damaged in anyway its a phone call to toyota, a few more hundred dollars, and the few days waiting to get them in from toyota and installed! Was anyone else aware of this??
  10. Feb 27, 2012 at 5:51 PM
    #530
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    Anyone hear if they were shipping our gears yet.
  11. Feb 27, 2012 at 8:29 PM
    #531
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    I called 2 different shops here to get quotes on gears, locker and install. Both shops recommend the master install kit. Trying to salvage the bearings are a PITA and more times then not get damaged. Any slight knick or scratch helps lead to premature failure. Thus, you're back in there again to fix the problem. For what it's worth, I'll be getting the master install kits for front and rear.
  12. Feb 27, 2012 at 8:32 PM
    #532
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Where.is.my.locker.
  13. Feb 28, 2012 at 6:43 AM
    #533
    Tacodriver08
    Tacodriver08 To have faith, is to trust yourself to the water
    Texas
    05 X-Cab 4x4
    Too many to list
  14. Feb 28, 2012 at 7:49 AM
    #534
    97yota4wd
    97yota4wd [OP] Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    never heard of it before.... but i guess other people have!
    seems like they should be at his place, probably getting sent out from him today? ill shoot him a text and ask.
  15. Feb 28, 2012 at 7:52 AM
    #535
    Tacodriver08
    Texas
    05 X-Cab 4x4
    Too many to list
    Schweet! Thanks man!
  16. Feb 28, 2012 at 10:57 AM
    #536
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    It just really sucks that now more than likely everyone that ordered mini install is gonna be spending another few hundred dollars for tha rest of tha kits
  17. Feb 28, 2012 at 11:14 AM
    #537
    BytorTruck
    BytorTruck Well-Known Member
    Brandon
    Scottsdale AZ
    There is only one bearing that is a trick but most competent mechanics can easily remove it with the correct tools. It is the brearing that sits on the pinion closest to the pinion gear. By chance if it is destroyed you just need to buy, 1 bearing not a complete master install kit. Yes you do need a master kit with a new carrier/locker, note a drop in locker such as a lock right. On a side not we should have the order today!!!!
  18. Feb 28, 2012 at 11:20 AM
    #538
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  19. Feb 28, 2012 at 12:11 PM
    #539
    blackhawke88
    SGV, CA
    07 TRD Offroad
    payment sent :cool:
  20. Feb 28, 2012 at 12:49 PM
    #540
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Would love to see the pics of the pallets of parts :)
Thread Status:
