Official Group buy for gears and lockers!!
Discussion in 'Group Buys' started by 97yota4wd, Nov 23, 2011.
Thread Status:
Not open for further replies.
  1. Mar 7, 2012 at 11:22 AM
    #561
    rcfreak201
    rcfreak201 Well-Known Member
    my rear was done in half a day so im assuming a day or maybe two at the most
  2. Mar 7, 2012 at 1:19 PM
    #562
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    tracking numbers??? so my wife can expect when theyll show up at her office is all :D
  3. Mar 7, 2012 at 1:50 PM
    #563
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    My buddy told me 2 full days for front and rear at his shop! He said tha back aint bad to do, its tha front that sucks ass
  4. Mar 7, 2012 at 3:23 PM
    #564
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    Gears just got delivered!! Now I have to find a shop that will install... ;)
  5. Mar 7, 2012 at 5:05 PM
    #565
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    ^ This please?? :pray:
  6. Mar 7, 2012 at 11:15 PM
    #566
    97yota4wd
    97yota4wd [OP] Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    brandon did mine in like 8 hours for front and rear gears, and a rear locker.
  7. Mar 7, 2012 at 11:18 PM
    #567
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    damn install is gonna be more than the gears :cool:
  8. Mar 7, 2012 at 11:28 PM
    #568
    97yota4wd
    Eric
    Mesa, AZ
    yep usually is lol. it sucks for sure!
  9. Mar 8, 2012 at 7:59 AM
    #569
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Most of tha money is for getting ur 3rd members out! If u take them out urself and take them to a shop it will cost less
  10. Mar 8, 2012 at 8:06 AM
    #570
    blackhawke88
    SGV, CA
    07 TRD Offroad
    hmmm, so if i pull out the front and rear diff, take them to the shop to have the gears done, and take the re-geared 3rd members back, it will be a lot cheaper?
    interesting
  11. Mar 8, 2012 at 10:51 AM
    #571
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I got qouted half price if I took them out myself and brought them up there :D
  12. Mar 8, 2012 at 10:59 AM
    #572
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    yes, all they need is the front diff, which is the hardest, and the rear third member for a regear/rebuild kit.
    To pull the rear, take of wheel, and brake drum cover, then you simply undo the ebrake, the clip and bolt. then take off the break line,, if you have rubber lines use vice grips and a plug, if you upgraded to steel use a plug quick. The lines you could squeeze, the rubber are a little further up as they go up from the axle to the frame rails, on the axle are solid, DO NOT PINCH THESE. once the solid brake lines are off, undo the 4 bolts on the hub, and pull the axle all the way out. do not rest on inner seal, the seal is NOT reusable as per the fsm. but honestly, some have gotten away with it. nows a perfect time to do wheel bearings, as well as a break job if you need either. then simply undo the driveshaft, pull all the little bolts holding on the third member and boom there you go. pretty sure the factory locker is on the clam shell not on the third member, but i could be wrong as its been a while.
    For the front, id recommend pulling the cv's, that means the tie rod ends need to come off, which means starting by taking off the wheels. as well as the lower ball joint, the four bolts holding the bastard on. make sure to use loctite when you put them back on, and torque to i think its 96ft/lbs as per the fsm. have some coat hanger or zipties to hold spindle up out of the way.
    Anyways, once the cv's are out, this is hard, use a big crowbar and a bfh to pry them out. spin and bang, spin and bang, sping and bang. and they should pup out, take off the front driveshaft, and i do believe thats it. then simply undo the bolts holding it in, and wiggle the bastard out. if you are running a first gen, its a good time for a diff drop if you have a lift, if you are running a second gen, then ignore the diff drop and go about your business.
  13. Mar 8, 2012 at 2:29 PM
    #573
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    got my gears today
  14. Mar 8, 2012 at 3:06 PM
    #574
    blackhawke88
    SGV, CA
    07 TRD Offroad
    This is awesome, +1 rep for you my friend :D
  15. Mar 8, 2012 at 3:44 PM
    #575
    purple taco
    purple taco Well-Known Member
    jesse
    gulfpot/biloxi
    99 ext cab SR5 4x4
    weapon-r intake,allpro 3"leaf springs,magnaflow exaust,ss break line,billy 5100's,allpro 1.5 greasable shackles,rear diff mod,u bolt flip kit,eibach 3"spring,light racing uca.blhm,plasti dip front/rear bumper, painted stock rims,04 gauge swap w/led,billet grill,tinted tail lights,bench to 4runner bucket seat,lockrite locker,bpv relocate,roof light bar/w 4hella 500ff,33x12.50r15 duratracs.
    Got my locker. Thnx brandon for the group buy!
  16. Mar 8, 2012 at 6:28 PM
    #576
    Slodgetto
    Slodgetto Über Posre
    Silas
    :eek: LUCKY!!!!!!!!!
    Can't freakin wait, now!!!! :goingcrazy:
  17. Mar 8, 2012 at 6:29 PM
    #577
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    I know I haven't got mine yet either. Tomorrow maybe :pray:
  18. Mar 8, 2012 at 7:00 PM
    #578
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    gee, i cant wait for mine to cum in the mail...
  19. Mar 8, 2012 at 7:03 PM
    #579
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    got my gears and locker yesterday!! WOOOOOOO!!! and they both come with very detailed install instructions! Actually doesnt look nearly as hard as i originally thought! Powertrax locker looks very easy and gears looks like a little patience and it shouldnt be too hard . . . .
  20. Mar 8, 2012 at 7:41 PM
    #580
    Slodgetto
    Silas
Thread Status:
