Official* New England Buy/Sell Tacoma Marketplace
Discussion in 'North East' started by Eagledynasty, Jan 2, 2013.
  1. Apr 13, 2018 at 12:57 PM
    #5821
    BillyKistner
    BillyKistner Active Member
    Billy
    2015 Tacoma
    @rdtompk Did you sell those suspension bits?
  2. Apr 15, 2018 at 11:10 AM
    #5822
    youngsurfrat
    youngsurfrat Well-Known Member
    Sullivan Ny
    2017 Tacoma TRD Sport
    Still searching for a 3rd gen DCLB raised cap. MX/180 style... prefered quicksand color but will look at anything (upstate ny) willing to travel
  3. Apr 15, 2018 at 4:22 PM
    #5823
    Khanhyeeast
    Khanhyeeast Well-Known Member
    Massachusetts
    TRD OR 4x4
  4. Apr 15, 2018 at 5:34 PM
    #5824
    jprovencher8
    jprovencher8 Well-Known Member
    WTB: complete front sway bar setup for 2013 Tacoma Access cab V6 4wd
    I'm located in Manchester NH
  5. Apr 15, 2018 at 5:40 PM
    #5825
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    Still have these?
  6. Apr 15, 2018 at 5:51 PM
    #5826
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    There's a couple options for 4wd. I believe there's the normal swaybar, and the Offroad swaybar (flexes more).
  7. Apr 15, 2018 at 5:58 PM
    #5827
    jprovencher8
    Either would work. It seems the prior owner removed the oem sway bar (TRD Sport) when installing a block lift. The truck gets REAL squirrelly on the highway and going over bumps. I do have an OME suspension precise coming in with the 90000 shocks and 886 springs with Dakar heavies in the rear. Searching the forum leads new to believe this should tighten up the steering a bit.
  8. Apr 15, 2018 at 6:03 PM
    #5828
    yellow_bandit
    yellow_bandit Well-Known Member
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    Yes I do
  9. Apr 15, 2018 at 6:04 PM
    #5829
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    I've got a sway bar that I took off my 2013 TRD Sport Double Can Short Bed .
  10. Apr 15, 2018 at 6:20 PM
    #5830
    jprovencher8
    Edit: Saw your post above startin the Framingham area.
    Is the front bar complete with end looks and how much are you asking good Sir?
  11. Apr 15, 2018 at 6:22 PM
    #5831
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    Framingham MA
  12. Apr 15, 2018 at 6:23 PM
    #5832
    jprovencher8
    Is the front bar complete with end links and how much are you asking good Sir?
    Edit: links, not looks.
  13. Apr 15, 2018 at 6:37 PM
    #5833
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    Yes. I took it straight off by unbolting the end links. Also includes bushings. But the mounts that hold the bushings are still on my truck. Not sure if you need them. Asking $120
  14. Apr 15, 2018 at 6:44 PM
    #5834
    jprovencher8
    I'll have to look under the truck tomorrow to see if I need the mounts. Any chance you can meet me somewhere between Manchester and Framingham?
  15. Apr 15, 2018 at 6:47 PM
    #5835
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    I could meet in Wilmington.
  16. Apr 15, 2018 at 7:04 PM
    #5836
    jprovencher8
    Ok. I'll get back to you tomorrow
  17. Apr 15, 2018 at 8:49 PM
    #5837
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    I've got a sway bar with bushings but no end links I'll let go cheap.
  18. Apr 16, 2018 at 4:45 AM
    #5838
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    just a heads up theres a 50 post minimum per TW rules before posting something for sale. Otherwise good luck with the sale, def a reasonable price.
  19. Apr 16, 2018 at 4:51 AM
    #5839
    Tacoma/Taco
    Tacoma/Taco Well-Known Member
    Josh
    Southern Maine
    Tacoma13'build in process
    3inKing coilover with clickerreservoirs 600lb King struts clicker reservoirs Total choas UCA Total choas Race series LCA Total choas bed stiffnners Timberland bump stops front/rear Welded gusset All pro aluminum apex bumper Warn 9000 Pia fog lights Pia off road light led Baja light bar Spider projection lights U bolt flip kit All pro 3in expedition leafs ARB front & rear locker ARB twin compresser Large ARB tank 4:56 gear ratio CBI slider bolt on CBI rear bumper steal Marlin crawler Taco Box 4:7 Optima blue top BFG 285/75R17 mud tires Body mount chop 1.25 wheel spacer Budbuilt Full body armor with crossmember support for dual transfer case skid plate Redirected exhaust Spider headlights warn Synthetic winch line Factor 55 fairlead Fiberglass hood, front-rear fender wells Beaded rims Spare tire mount in bed
    Should I cancel it and put it up in the future
  20. Apr 16, 2018 at 4:51 AM
    #5840
    Tacoma/Taco
    Josh
    Southern Maine
    Took me 29 minutes to upload the pics I have horriable internet where I live
