Official* New England Buy/Sell Tacoma Marketplace
Discussion in 'North East' started by Eagledynasty, Jan 2, 2013.
  1. Nov 10, 2021 at 1:51 PM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    But what are your thoughts on it? Seem like a better solution than Dakars/Deavers? You know anyone that tows stuff around every so often with not so much in the bed?
    Seems like that's the case.
    NoFear9491 likes this.
  2. Nov 10, 2021 at 2:10 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    All about what you want to accomplish. He doesn't want the little sag while towing. Aal and bags or sumo seams the cheapest easiest way I can think of.
    Yes, Dakars will be harsh with empty bed by comparison. My .02
  3. Nov 10, 2021 at 3:22 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    If constant load, leafs if not...bags and sumo springs. I always have a cap and tools and miscellaneous stuff in the bed so dakars for me
  4. Nov 10, 2021 at 3:46 PM
    CttAznRanger
    Brandon
    Boston, MA
    @NoFear9491 That good enough for you?
    NoFear9491 and jpereira2[QUOTED] like this.
  5. Nov 10, 2021 at 3:52 PM
    raspy87
    raspy87 Active Member
    Andrew
    Northern RI
    '19 Cement Tacoma SR5 DCSB
    Air freshener Tonneau cover
    I’m usually empty but just upgraded or pop up to a TT. I’m just waiting to pull the trigger until after winter when I buy the truck out of my lease to throw some airlift in, no compressor. Probably just going to do a stand-alone system at some point. Now I’ve gotta look at sumo springs! More research. :confused:
  6. Nov 10, 2021 at 6:54 PM
    Blindsider
    Blindsider Well-Known Member
    Craig
    Upstate NY
    18 DCLB TRD OR
    Also a good weight distribution hitch will help a lot for towing.
  7. Nov 10, 2021 at 8:31 PM
    raspy87
    Andrew
    Northern RI
    Just picked the camper up a couple weeks ago. Coming home empty with the WD hitch I was riding even, completely dry/empty and it towed well. Took the back roads to see how she handled with some curves/hills. Definitely new it was back there but I was pleasantly surprised. As mentioned bags are in the future but also plan on additional transmission cooler and some sort of monitor for transmission temps.
    jpereira2 and NoFear9491 like this.
  8. Nov 11, 2021 at 1:35 AM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Ive used both of these in the past while towing they get the job done!
    B&M Supercooler:
    https://www.amazon.com/70264-SuperCooler-Automatic-Transmission-Cooler/dp/B000CIIDZE
    ScanGuage II:
    https://www.amazon.com/ScanGauge-Automotive-Computer-Customizable-Real-Time/
    jpereira2 likes this.
  9. Nov 11, 2021 at 1:38 AM
    Fatback17
    Fatback17 Masshole
    Billy
    2020 TRD Pro MGM
    Bumpity Bump Bump
  10. Nov 11, 2021 at 5:39 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    I need that for just daily driving sometimes... My scangauge says my trans temps are north of 200 degrees during the summer and that's without towing....
  11. Nov 11, 2021 at 6:07 AM
    NoFear9491
    NoFear9491 Well-Known Member
    Jeff
    Boston, MA
    2015 Magnetic Grey Tacoma AC
    Small stuff but not for long!
    So I feel like I should give more background. The truck isnt a daily (more of a princess as it sits in a heated garage on blocks to not spot the tires) In the summer it does get more use towing the boat. Boat is a 17" Whaler 2500ish lbs. I kinda agree more with @JanBoothius on this one that anything worth doing is worth doing right espcially when the truck gets used it does have weight in the back..... junk in the trunk if you will...
    JanBoothius and raspy87 like this.
  12. Nov 11, 2021 at 6:12 AM
    raspy87
    Andrew
    Northern RI
  13. Nov 11, 2021 at 6:23 AM
    jpereira2
    Massachusetts
    Time for you truck to go on a diet :D
    NoFear9491 and SR-71A like this.
  14. Nov 11, 2021 at 8:49 AM
    zjcas
    zjcas Well-Known Member
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Fox 2.0 COs, Fox 2.0 Resi's, Wheeler's Prog. AAL.
    First items up on the "I'm moving and need to part with sh*t since I traded in my tacoma" dump. Forgot I still have my aluminum 2nd gen skid floating around. 30$ takes it. Second is a bummer for me. Ordered the custom decal below and it came right before our baby arrived so between that and work and weather never got to put it on the truck. 35$ takes it (had it made for by a member here for 75 I believe so I value this more than a 10 y.o. skid plate). I also have a HF hitch extender that I need to get pics of. Planning for like 30$? I think new they run 65-70. Going to offer it up to my dad also so if pics never make it that means he took it!
    Local pick up only. I'll be making the drive to Charlotte next week so maaaaaaybe willing to meet you on the way but I don't plan on going way off route to meet you.
    Enjoy!
    NorthCountryTRD likes this.
  15. Nov 12, 2021 at 3:43 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Winter is coming! Get these out of my garage!
  16. Nov 13, 2021 at 8:48 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Anybody need a set of beater wheels? Free to a good home...
    (Pic from web)
    Have 4 of these 16" that I'd used as winter wheels. Lug nuts included, no sensors or center caps. I'm east of Hartford two minutes off I-84.
    Hate to just toss them if somebody can use them.
    NorthCountryTRD and jpereira2 like this.
  17. Nov 13, 2021 at 3:28 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    :spy:
    Cleaned up. No hammers swung. We good.
  18. Nov 13, 2021 at 3:39 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Anyone looking for a soft topper? Located on cape cod
    802Tacomas and jpereira2 like this.
  19. Nov 13, 2021 at 9:47 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Im just here for photos of the Whaler :spy:
    crashngiggles likes this.
  20. Nov 15, 2021 at 7:08 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Looking for a set of 2nd gen short bed OEM bed rail caps. Preferably in 'new' or good condition.
    Figure someone in here might have a set kicking around after they upgraded to metal caps.
