Official release: Tacoma 2nd gen reverse lights:)
Discussion in 'Group Buys' started by LEDsolutions, Nov 2, 2011.
Thread Status:
Not open for further replies.
  1. Nov 27, 2011 at 8:49 AM
    #241
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    IMHO it helps the camera at night. The only downside is the light is more focused, and it seems to put out light much farther than the stock bulbs. So the light isn't directly behind the truck anymore, there's this gap where there's not much light, then complete brightness. I took several pictures of the rear cam.
  2. Nov 27, 2011 at 8:52 AM
    #242
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    check out the photos here.....http://www.tacomaworld.com/forum/gr...oma-2nd-gen-reverse-lights-9.html#post4005379
    My opinion, the brightness is great.. the THROW is great... but when it comes to flood, it could do a bit better.. thers a pretty big gap of darkness from the end of your truck to where the light actually shines to...
    LJ, I hope you can get something that can throw and flood at the same time.. that would be the perfect reverse light.
    on a side note, LJ I'll be PMing you sometime soon for some interior lights......
  3. Nov 27, 2011 at 12:41 PM
    #243
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Payment sent for 2nd gen rev lights & license plate lights........
  4. Nov 27, 2011 at 1:58 PM
    #244
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I just got my set of back up lights installed and they are awesome! I ended up having to back down a long drive way at night and these LED bulbs definitely throw light a lot better than the stock bulbs. I don't have a back up camera so I can't say how they affect that but just looking backwards or through the side view mirrors they are much brighter.
  5. Nov 27, 2011 at 2:10 PM
    #245
    Tippett's TRD
    Tippett's TRD Well-Known Member
    Josh Tippett
    Lake Linganore, Maryland
    2010 Speedway Dbl Cab L/B 4x4
    6" Pro Comp Suspension Lift, LEER Cap, NFAB Nerf Bars, Avid Off-road Bar, K&N Intake, Weathertech Liners, 2011 Grille, BedRug, Westin Taillight Guards, Tinted Windows, RedLine Hood Struts, Mag Lite Mod, Stubbie Antenna...
    That's what I am worried about... I back my truck up and try to get as close as possible. So, at nighttime.. if there is a gap of darkness in the rearview in the section that is closest to the tailgate, that would suck IMO
  6. Nov 27, 2011 at 2:16 PM
    #246
    AsianAnts
    AnT
    i find that my brake lights kind of help fill that gap or flood that little dark area...
  7. Nov 28, 2011 at 4:08 AM
    #247
    oneshot808
    oneshot808 Well-Known Member
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Wet Okoles/Weather tech all around, LED's +HIDS, 6"Fabtech w/ Fox front & rear
    got mines in yesterday!! woohoo! great improvement from my stock bulbs which could not pierce my tinted tails lol.
  8. Nov 28, 2011 at 5:49 AM
    #248
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    Thank you
    The money has been sent!
    marianne, you have sent $35.00 USD to Lennard David.
  9. Nov 28, 2011 at 5:50 AM
    #249
    Jez
    Jez Hittn' easy steet on mud tires
    Ohio
    06 Black DC TRD SR5
    K&N air intake, Fox 2.5 coilovers, Total Chaos UCA's, AllPro Expo rear leaf pack, Fox 2.0 rear shocks, Diff Drop, U-Bolt Flip kit, Drive Shaft shim kit, Weathertech's, Borla cat back, Ultra Gauge,Clarion Radio, 18% tinted windows all the way around, smoked tail lights and rear break light, painted front chrome grill black, stained yellow fog lights, black head light mod, Interior LED kit, LED reverse lights, black leather arm rest mod
    Payment Sent
  10. Nov 28, 2011 at 7:54 PM
    #250
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Pymt & PM Sent
    Thanks
    CC
  11. Nov 28, 2011 at 11:14 PM
    #251
    Hawaiian Taco
    Hawaiian Taco Member
    Pacific Ocean
    TRD Sport Taco
    Plenty
    Are these just plug and play- or do I need to add anyting else to get these to fully function? When is the group buy over, and theres no additional shipping to HI is there?
  12. Nov 29, 2011 at 1:56 AM
    #252
    bobby15
    bobby15 Well-Known Member
    SoCal
    09 DC LB 4x4 magnetic grey tacoma
    Is it to late to get in on this ??
  13. Nov 29, 2011 at 2:14 AM
    #253
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    x2. How did I miss this thread and are Canadians welcomed?
  14. Nov 29, 2011 at 5:47 AM
    #254
    viperstd
    viperstd Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    I will be removing these LEDs and going back to stock I think. I don't feel that the light output (beam pattern) is useable. They look very 'cool' but provide almost no visibility directly behind the truck.
    If there was a way to get a more diffuse pattern and aim them down a little bit they would be much more useable.
  15. Nov 29, 2011 at 6:56 AM
    #255
    Tippett's TRD
    Josh Tippett
    That is exactly what I was worried about after seeing pictures... that sucks man, thanks for the heads up though
  16. Nov 29, 2011 at 7:56 AM
    #256
    AsianAnts
    AnT
    Im gonna try to play with a small mirror or something reflective to try and deflect the light downards a bit.. but you are correct in regards to the lack of visibility directly behind the truck.. Looking through the rear camera, its almost (if not more) half the area that is unlit by the LEDs.
  17. Nov 29, 2011 at 8:03 AM
    #257
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    Get rock lights if this concerns you.
  18. Nov 29, 2011 at 8:56 AM
    #258
    viperstd
    Maryland
    Have a set of D2s facing rearward on the bumper and rocklights (sitting on the living room floor at the moment). This does not address the issue of backing up in PUBLIC situations.
    I don't want to need to flip on rock lights or my Duallies everytime I need to backup at night. I think putting them on in a busy packing lot or public road would be dangerous.
    After trying them out, I think the Crees are great if you want to look cool backing up right until the point of hitting something. Just my .02. They do throw lots of light, just not where I want it.
    Hopefully someone figures out something clever with a diffuser, however I don't want to bake/pull apart my taillights for the sake of running this bulb.
  19. Nov 29, 2011 at 9:39 AM
    #259
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    To each their own. I think they look good, and perform well. The only complaint I have is directly behind the vehicle, it doesn't light up very well. 99.99999% of the time this hasn't been a big deal to me. I showed in the pictures I took the gap I was talking about.
  20. Nov 29, 2011 at 9:58 AM
    #260
    Pugga
    Massachusetts
    Well said. I have one of those backing systems that beep when I get close to something so it was more important to be to see further back. I can see the concern of putting light on the ground though. Hopefully Ant will come up with something clever.
Thread Status:
