Official Road Shower 2 Group Buy Offically Closed
Discussion in 'Closed Group Buys' started by scott96929, Sep 11, 2015.
  1. Dec 14, 2015 at 6:08 AM
    #141
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Finally got my road shower installed and went camping with it. One problem
    The radiator cap popped open and lost my water in the tank. Anybody else had this problem?
  2. Dec 14, 2015 at 6:38 AM
    #142
    scott96929
    scott96929 [OP] IRoniK
    Scott
    Phoenix, Az
    2007 Tocoma PreRunner (Ironik)
    All Pro Front Plate Bumper, MaxTrac 4" Spindles, Light Racing Upper Control Arms, BOSS Leaf Springs, Toytec Adjustable Coilovers, Fox 2.0 Rear shocks, 17" Raceline Assault Wheels, Toyo RT 285 70R17, AFE Stg II Cold Air Intake, Prinsu Cabrack, Prinsu Bedrack, 10K Kensun HID Headlights, Avec 20" Optic LED Light Bar, Avec LED Fog Lights, Heretic 30" Combo LED Light Bar, Viper Max 12000 Winch, Quick Fist, Tepui Kukeman Ruggerized RTT, Smittybilt Awning, Relentless Fab Tailgate Reinforcement, Anti-Dark Hood Lighting Kit, Fog Lights Anytime Mod, Rear Differential Breather Mod, P&L Tailgate Lock, KMFAB Rock Sliders, KMFAB Rock Light Kit, KMFAB Bed Light Kit, KMFAB RTT Light Kit, KMFAB 12 VDC Outlet Kit,Optima Dual Battery, SSCS Kit, Switch Pro 8100 Kit, Cali Raised Ditch Light Kit
    Sometimes you may think it was locked all the way, but I push down and turn and it And it locks down with another quarter turn. When I pressurized mine one time the cap came loose on one side. I noticed I didn't have it fully turned and locked down.
  3. Dec 14, 2015 at 7:43 AM
    #143
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    Ok will try it on my next camping trip
  4. Jan 22, 2016 at 3:00 PM
    #144
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    Those of you that participated in the GB, how do you like the Road Shower? I'm looking at possibly getting one, but wanted to get some real life reviews from some guys on here.
  5. Jan 27, 2016 at 8:51 AM
    #145
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    I really like it, I have discovered it is soo much more useful that I initially thought, on top of showering and rinsing off the pups on hot weekends at the lake, I have found during the cold season it is perfect for rinsing washed dishes off, good drinking water for my pups and water gun fights, or dousing the morning campfire. You don't realize just how much water is in there either, I have yet to spent a weekend out and run out of water in it.
    Edit: Do any of you guys keep yours mounted? I have been mounting it up when I plan to go camping, otherwise its in storage. I have been considering just mounting it up and leaving it tho
  6. Jan 29, 2016 at 12:29 PM
    #146
    Mcdees84
    Tallahassee, FL
    Thanks man. Any feedback on water temperature? How well does the sun actually heat the water and does it go cold pretty quickly after the sun goes down or if outside temps drop?
  7. Jan 29, 2016 at 1:04 PM
    #147
    WhiteNemesis
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    If your not careful it can get boiling. I typically let it cool off a little, sun go down, depending on the night temps. It all depends on how hot and sunny the weather is. If the temp is going to drop after the sun goes down it'll get cold rather quick, but a hot summer days, it remains warm. On cold nights it actually feels real nice, till you gotta dry off. Direct sunlight on a winter day, it gets warm, not hot like a home shower but more than warm enough for a nice rinse.
    scott96929[OP] likes this.
  8. Feb 1, 2016 at 4:01 PM
    #148
    Mcdees84
    Tallahassee, FL
    Last question for ya'll. How often do you find yourselves needing to pressurize it per fill up? Is pressurizing it once sufficient to pump out all the water in the tank, or is it a repeated process? Just wondering if I need to take a bike pump or small compressor with me. Also, I just pre-ordered the roadshower 2! Stoked to have this in the setup.
    WhiteNemesis likes this.
  9. Feb 1, 2016 at 4:21 PM
    #149
    scott96929
    Scott
    Phoenix, Az
    So you pulled the trigger and ordered, great. Well I've used mine quite often. If you feel the tank with water to its fullest capacity, then there isn't much room for pressurized air so you will have to re-pressurize, but it doesn't take long to pressurize the tank. If the tank is like 1/2 or 3/4 full the pressure last a long time, enough to take a shower and then some. I recommend getting a portable air compressor instead of a bike pump, unless you have arms like popeye...... Also there are videos on RS2 website that shows how long a pressurized tank last. I personally have talked to the owner and his videos are legit, no tricks of any kind. Hope you enjoy your RS2 as I have..... See you on the trails.......
    Mcdees84 likes this.
  10. Feb 1, 2016 at 4:40 PM
    #150
    Mcdees84
    Tallahassee, FL
    Thanks for the info man. I have a little portable compressor which should do the trick. It can inflate my tires, so I'm sure its enough. See you out there:thumbsup:
  11. Feb 1, 2016 at 4:45 PM
    #151
    WhiteNemesis
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    I have to presureize it every time I go to use it, wheeling causes constant change in elevation same with air within the tube, its constantly expanding or contracting. Be sure you pack a bike pump and keep it handy for regular use of the shower. I keep my pump in my door pocket on the side I mount the shower
    You will really like having it, high price point but I use it a lot. If you live on beach you will get even more use out of it than I
  12. Feb 1, 2016 at 9:17 PM
    #152
    Mcdees84
    Tallahassee, FL
    Cool man. I surf a lot so that was one of the perks to me. I can't wait for it to arrive now based on y'all's comments.
  13. Feb 2, 2016 at 7:05 PM
    #153
    CaptainReverso
    CaptainReverso Well-Known Member
    Cory
    Gardena
    2015 TRD off road 4x4 DBL cab Magnetic Grey
    Off Road Stuff
    anyone trying to sell theirs ??? :rolleyes: lol
    mlbdriver likes this.
  14. Feb 2, 2016 at 8:57 PM
    #154
    WhiteNemesis
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    You gonna have everyone else jelly while you rinse your board off befor heading home!
  15. Feb 3, 2016 at 12:07 PM
    #155
    scott96929
    Scott
    Phoenix, Az
    RS2 has them in stock now. Hurry and order before they are gone.
  16. Feb 3, 2016 at 1:13 PM
    #156
    CaptainReverso
    Cory
    Gardena
    Off Road Stuff
    I'm penny pinching now my friend. Any buck I can save! Lol
  17. Feb 7, 2016 at 11:52 PM
    #157
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I just ordered my rs2. Road shower has a $50 off w/ free shipping coupon on their Facebook. Going to mount it above my tonneau cover using a kbfab bed bar.
  18. May 12, 2017 at 6:41 AM
    #158
    Phessor
    Phessor Well-Known Member
    I think you should do another group buy!
  19. May 12, 2017 at 6:42 AM
    #159
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I think @Pirhett had something going on..
  20. May 12, 2017 at 10:15 AM
    #160
    Gabex35
    Gabex35 Well-Known Member
    Gabe
    San Diego
    2020 Tundra Limited 4x4 Crewmax
    I have a used once RS2 for sale. PM me if interested. local San Diego or surrounding area only.
