OFFICIAL..SPINDLE INSTALL INSTRUCTIONS no pics
Discussion in 'Suspension' started by 08pretaco, Apr 8, 2010.
  1. Aug 30, 2010 at 7:34 AM
    #41
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    $125-150?
  2. Jan 3, 2011 at 12:18 PM
    #42
    08pretaco
    08pretaco [OP] Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
  3. Jan 3, 2011 at 12:27 PM
    #43
    08pretaco
    az
    The only advice is take your time. Some things will piss you off but do not get discouraged. One tedious task is screwing the sensor back into the back of the spindle. It might be easier to just install the sensor before installing the spindle onto the truck.
  4. Jan 3, 2011 at 12:30 PM
    #44
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Ive got a question is the bolt that goes from the uniball of the UCA into the spindle, is the spindle tapped on the top and you screw the bolt right into it or is there like a pocket to put the nut in in the rear.
  5. Jan 3, 2011 at 12:32 PM
    #45
    08pretaco
    az
    UCA bolt goes right through the top of the spindle, nut goes in through the bottom then it gets tightened down. If thats what your asking.
  6. Jan 3, 2011 at 12:35 PM
    #46
    08pretaco
    az
    Ya. It is hard to get at though, at least on the Camburg spindles. The area for movement is very small so its a hand tightening thing.
  7. Jan 3, 2011 at 12:37 PM
    #47
    ktmrider
    Junk
    that would suck to cross thread it then, I dont know what you would do if you did.
  8. Jan 3, 2011 at 5:02 PM
    #48
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    @ktm: it's not threaded. You just shove the bolt all the way in. You gotta be a loser to crossthread it. Lol
    For the sensor, I ended up just siliconing mine it. Won't bugde and took seconds!
  9. Jan 4, 2011 at 9:39 AM
    #49
    08pretaco
    az
    Ya the tires being stuck in almost act like a resonator in the fender well lol Good job with the install!
  10. Jan 20, 2011 at 7:43 AM
    #50
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
  11. Jan 20, 2011 at 7:52 AM
    #51
    08pretaco
    az
  12. Jan 20, 2011 at 7:54 AM
    #52
    08pretaco
    az
    Aftermarket spindle:
    Stock spindles (with TC gussets):
  13. Jan 24, 2011 at 8:37 PM
    #53
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
  14. Jan 27, 2011 at 10:20 AM
    #54
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    what do you guys use or recommend to release the tie rod from the spindle?
  15. Jan 27, 2011 at 12:39 PM
    #55
    HBMurphy
    Paul
    So California Coast
    None
    If you are good at it, turn the nut upside down screw on so that the top surface of the nut and the threaded part of the tie rod is flush and smack with a hammer - can also smack the little tab on the part that the tie rod end goes into. Otherwise go to Orielys and borrow a tie rod puller.
  16. Jan 17, 2012 at 5:19 PM
    #56
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    will spindles work with LR UCA?
  17. Jan 17, 2012 at 5:59 PM
    #57
    08pretaco
    az
    Yes but are not necesaary
  18. Jan 17, 2012 at 6:50 PM
    #58
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    ok thanks, already have them for OME lift just seeing if I could add spindles to that set up
  19. Jan 17, 2012 at 7:11 PM
    #59
    08pretaco
    az
    What are you doing out back if your going to be 7" up front.
  20. Jan 17, 2012 at 7:12 PM
    #60
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    I'm not going to be doing this for a while, but will be going with alcan 6'' leaf packs with 5125's
