**OFFICIAL** T/X & T/X Pro Owners Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoePa Fan, Oct 28, 2010.
  1. Jan 31, 2021 at 4:17 PM
    #1081
    vmadams
    vmadams Member
    2013 TX Pro
    Fab Four front and rear bumpers, XRC Wench, Yakima Roof Rack 2inch lift blocks
    Anyone here have a bed rack with a tent mounted? Looking for some suggestions for my 2013 TX Pro
  2. Feb 5, 2021 at 2:55 PM
    #1082
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Just installed a 12volt solutions remote starter!
    Not bad at all. No heat in the garage but it’s like 35 here in Vt today.
    Wish I’d have got it sooner but it’s been cold out anyway.
    Pretty solid product priced below other 2 ways without install.
    Install took a few hrs I’m sure in better weather it would be quicker.
    I heated the inside up to make plastic more compliant. The door lock connector was a pain in the arse. It’s super hidden and has no wiggle room. But even after forgetting the programming process and being slow all works as it should.
    Happy to have a starter again!
    Very pleased with the TX makes it fun again.
    TXpro4X4 likes this.
  3. Feb 8, 2021 at 5:02 PM
    #1083
    vmadams
    vmadams Member
    2013 TX Pro
    Do I need to upgrade my suspension and tires immediately or can I run my bed rack and tent and gear with my stock TX Pro?
  4. Feb 8, 2021 at 5:05 PM
    #1084
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    You can run it
    Why the tires? Rugged fails?
  5. Feb 8, 2021 at 5:17 PM
    #1085
    vmadams
    vmadams Member
    2013 TX Pro
    Just wasn’t sure if my current AT tires (BF Goodrich K02 265/75 R16) and suspension would support the weight of a tent and rack. Pricing out this build is getting really expensive..
    TXpro4X4[QUOTED] likes this.
  6. Feb 8, 2021 at 6:07 PM
    #1086
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    You should be fine I would thinkmight need an aal in the back though
  7. Apr 13, 2021 at 11:29 AM
    #1087
    bcampbe7
    bcampbe7 Member
    2011 Tacoma TX Pro
    2011 TX Pro new owner checking in.
    Purchased this past Saturday. Has the factory supercharger too. We are the 3rd owner and the truck has been very well maintained throughout its life. Also has some nice mods (IMHO).
  8. Apr 13, 2021 at 12:49 PM
    #1088
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Very nice. Welcome
    Jeffch and bcampbe7[QUOTED] like this.
  9. Apr 14, 2021 at 2:14 PM
    #1089
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Cool nice truck!
    Nice to see another TX!
    Welcome to TW.
    bcampbe7[QUOTED] likes this.
  10. May 29, 2021 at 10:54 AM
    #1090
    simplehuman
    simplehuman Well-Known Member
    Sorry I'm so late replying. Went out of the country early last year and just now catching up. Here's my '13 with the Tuff Stuff Elite. This RTT is one of the largest you can get. I did upgrade the suspension all of the way around to accommodate the tent, rack, and drawer system.
    bwog, bcampbe7 and 04TacoRunner like this.
  11. May 31, 2021 at 7:59 PM
    #1091
    Wamo
    Wamo Member
    California
    TRD PRO
  12. Sep 16, 2021 at 8:16 AM
    #1092
    bwog
    bwog New Member
    '12 and '13 Bajas
    Overland rooftop tent RHINO platform rack A.R.E truck cap with Thule bar system, All maintenance records and original window sticker Receipts for all after-market parts Upgrades all in 2020 or 2021 with the exception of the topper Truck topper – A.R.E CX with light strip, 2x12v ports, led brake lights, pet screens, lock, and Thule two bar rack RhinoRack 42100BF - 60'x49" Pioneer Platform plus Rhino Rack backbone 2 base mounting system Overland Vehicle Systems Nomadic 3 rooftop tent, dark grey base with green rain fly NorthStar NSB-AGM27F battery 930 CCA Helper leaf spring installed Bilstein shocks – 6112 coilover shock and struts in the front and B8 5160 reservoir shocks in the rear Replaced all four wheel bearings Timbren front and rear SE suspension upgrades (TOFTUN4 and TORTUN4) Warranty work – air injection air pump replacement, frame corrosion resistant compound application Tires – 4 x brand new - 265/75R16 tires BF Goodrich All Terrain T/A KO2 Pop N Lock lockable (remote) tail gate McGard tailgate protection (so the tail gate can't be stolen) CBI Offroad High Clearance front receiver hitch Power Stop K137-36 1-Click Extreme Z36 Truck and Tow drill and slotted Front brake kit All MOOG - passenger and driver upper and lower control arms, ball joints, sway bar end links, tie rod ends, caster/camber alignment kits 265/75r16 tires BF Goodrich All Terrain T/A KO2 Full size spare mounted on fifth TRD steel wheel Specifications TRD off-road package for Baja series Double cab 4x4 v6 double cab, 4wd, automatic transmission 5 SPD, Barcelona Red Metallic (3R3) V6 tow package for off-road package - class IV towing receiver and hitch with transmission and supplemental oil coolers 130a alternator 4.0l dohc 24v v6 VVT-I 236hp engine 5-speed ECT-I automatic transmission 4WDemand: part-time 4x4 sys w/ 2-speed electronically controlled transfer case - Automatic limited-slip differential - Coil- spring double wishbone front susp - Rear leaf spring suspension with staggered outboard- mounted gas shock absorbers - Variable-assist power rack-&-pinion steering -Power-assisted front disc/rear drum brakes 16" TRD steel wheels, Star safety system Vehicle stability control Traction control Anti-lock brake system (abs) Electronic brake force distribution Brake assist, & smart stop technology (sst) Driver & front passenger advanced airbag system Seat-mounted side & side curtain airbags 3-point seatbelts for all seating positions Driver & front passenger active headrest Side- impact door beams Tire pressure monitor system (TPMS)
    Hi Everyone,
    I hope this finds you all doing well! I've been a Taco owner since '02 and that TRD has over 300K and still runs strong. TW has been a great source of information for me over the years, so it made sense to get an account. So many of you have extensive knowledge about offroading, repairs, parts, etc., and you have my thanks for all of the lessons I've gleaned from your experience.
    Currently, have two T|X Bajas (PRO-precursors), a '12 (Barcelona Red) and a '13 (Super White). I'm pretty much done with the mods on the '12, and have just about finished the suspension upgrades on the '13. It would be great to hear from other Baja owners about their projects and where they source parts. If any of you would like to know where I got mine, I'm happy to share!
    Happy offroading!
    BWOG
    simplehuman likes this.
  13. Sep 16, 2021 at 11:39 AM
    #1093
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    You’ll fit right in here lol
    https://www.tacomaworld.com/threads/trd-pro-tx-baja-official-thread.360056/
  14. Sep 16, 2021 at 2:58 PM
    #1094
    bwog
    bwog New Member
    '12 and '13 Bajas
    Thanks very much! A couple of folks hit me up with that thread! I've been missing out.
    Island Cruiser likes this.
  15. Jan 2, 2025 at 7:07 AM
    #1095
    Trdinferno1
    Trdinferno1 New Member
    Antonio
    Tacoma TRDPro 2015
    Can u guys help me to find were can I buy the trd pro exhaust for my 2015 TRDpro I was on my truck but some body shop steal it I want to put the original (trd pro ) to have the same drone sound on my Tacoma
  16. Jan 2, 2025 at 7:17 AM
    #1096
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Welcome to TW :hattip:
  17. Jan 2, 2025 at 7:23 AM
    #1097
    Trdinferno1
    Antonio
    Tacoma TRDPro 2015
    Thank u guys
  18. Jan 2, 2025 at 7:24 AM
    #1098
    Trdinferno1
    Antonio
    Tacoma TRDPro 2015
    I will like to know how I can or were I can find the exhaust for my Tacoma
  19. Jan 2, 2025 at 8:12 AM
    #1099
    Rod03
    Rod03 Well-Known Member
    14 DCSB OR 300k+ Miles DD
    22 T4R OR, 12 TX Pro, 21 Taco Skewp!, 02 Taco OR (All Sold)
    Unfortunately the TRD exhaust for 2gen's is discontinued, I found that are two left in the country a few months back. But neither dealership that had them want it to ship them, both located in Cali. One around the Bay are and the other close to San Diego.
  20. Jan 2, 2025 at 8:14 AM
    #1100
    eurowner
    eurowner Duke Sky
    Scoty
    https://www.google.com/search?q=201...EgXw&hl=en-US&sourceid=chrome-mobile&ie=UTF-8
    https://parts.elmhursttoyota.com/oe...RraZj1V1ojHcM8uvRKYTdncqHTpMpZbfd-WcmsJCFasEQ
    https://www.tacomaworld.com/threads/2nd-gen-2015-tacoma-trd-pro-part-numbers-list.804979/
