Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jul 17, 2015 at 1:59 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Aight, battery it is probably. I really want to get my shit set up this weekend so you people better expect phone calls from me and ready to offer assistance! haha
    Mike, not trying to rush a man, but hows the switch panel coming along? Cant wait to load that stuff up. How did you connect the wires to the rear of the switches (just drimmel a hole in that pocket and run wires through)???
  2. Jul 17, 2015 at 2:33 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
  3. Jul 17, 2015 at 4:23 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    I have to cut the center which i will have time to do tomorrow. Then i'll send it out. I drilled 2 1/2" holes in the center console which i then found was not enough, so i drilled 2 more and 1 1" hole for my grounds. When it's not so damn hot, I'm going make all the holes 1". So my advice to you is to: 1) give zero fucks, and 2) drill 3 or 4 1" holes. It will make it way easier to get wires through and give you more room for adding more wires later.
  4. Jul 17, 2015 at 5:02 PM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Public service announcement: Weston is looking to buy a ford!!!!
    UNDEAD1153 likes this.
  5. Jul 17, 2015 at 6:02 PM
    Skootter14
    Jeremy
    Awesome, thanks!
  6. Jul 17, 2015 at 6:13 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    I've owned one before, its a mistake.
  7. Jul 17, 2015 at 6:47 PM
    longrifle76
    longrifle76 Member
    Nashville, TN
    2013 Black 4x4 DCLB
    I agree it's total foolishness but it's hilarous!
  8. Jul 17, 2015 at 7:10 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Boo this man!!!!!!!!!
  9. Jul 17, 2015 at 7:14 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Just fyi, from 8 tom morning till about 4 i won't be available. Got important shit to do. Supra time!!! We rolled the fenders earlier. I cut the end off a baseball bat and used that. Stick the bat in the front of the fender, slowly drive backwards and and the bat rolls itself around the fender. Pretty ingenious. Haha but we got most of the body back on except the rear bumper. So hopefully come tom I'll have some drift pics and videos
  10. Jul 17, 2015 at 7:18 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Go back over it with a towel wrapped tightly around the bat. Will smooth the insides even more. That's how all my mustangs have been done
  11. Jul 17, 2015 at 7:32 PM
    Skootter14
    Jeremy
    that means im going to need your phone number haha
  12. Jul 17, 2015 at 7:40 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Aight. We are gonna "finish" it at some later date. We just needed it to clear for tom. Meanwhile at Road house ...... I got a 32 oz steak. Haha
    lowinhz likes this.
  13. Jul 17, 2015 at 7:53 PM
    Adamw1988
    Adamw1988 Well-Known Member
    Adam
    West Tennessee
    2015 Trd sport
    rhion82 and KnoxTac0713 like this.
  14. Jul 17, 2015 at 7:58 PM
    Skootter14
    Jeremy
    looks good man
  15. Jul 17, 2015 at 8:08 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Work may have me near Johnson City this fall. Any good places to wheel around there?
  16. Jul 17, 2015 at 8:21 PM
    Skootter14
    Jeremy
    OK, in the pic, this is how I had my lights wired. Now, I just checked continuity between the battery and all blue sea fuse panel outlets---> good continuity (and all the ports were showing the proper 12V so the panel works)
    I just checked continuity between EVERY wire pictured below and it all checked out. This leads me to assume that once I had everything hooked up, one of my GROUNDS was not solid (I did not have the multimeter to test this when it was all set up last week in the truck, however I tested a few grounds under the hood tonight to expand the areas I will be able to ground the compressor too).
    Am I correct in assuming I had a bad ground if every wire depicted here checked out continuity-wise??
  17. Jul 17, 2015 at 8:34 PM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    I'd make all the connections, then see that I had voltage to switch in off position, then voltage to relay in on position, ground to relay , cycle switch to verify relay is cycling, check blue sea power to relay, you should also have continuity on power through lights to ground with switch off, with a resistance reading for the lights.
  18. Jul 17, 2015 at 8:34 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Looks right but what is the blue sea as well as the lights and where's your switch ground?
  19. Jul 17, 2015 at 8:36 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    You do have a ground for the switch right?
  20. Jul 17, 2015 at 8:38 PM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    Only if it has a light, otherwise the positive just gets interrupted by the switch.
