Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jul 17, 2015 at 8:39 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    so yes, I checked the POS and NEG screws on the blue sea that I used for the lights and once connected, it showed 12V passing though.
    I had the switch grounded to a screw that is directly behind the little cubby that's directly in front of your left knee as you sit in the driver seat (coin pouch or whatever that little pocket it). My old wiring system used that as a ground and the switch worked so I assume its still good.
  2. Jul 17, 2015 at 8:40 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Is the switch lighting up?
  3. Jul 17, 2015 at 8:41 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    I usually forget to check the fuse in the blue sea.
  4. Jul 17, 2015 at 8:42 PM
    Skootter14
    Jeremy
    It did NOT on my last attempt (when i orignally had the switch wired, the LED was ON when the lights were OFF and the LED went off when the ditch lights were switched on (that was annoying and I am trying to fix that with the jumper between the positives on the switch)
  5. Jul 17, 2015 at 8:43 PM
    Adamw1988
    Adamw1988 Well-Known Member
    Adam
    West Tennessee
    2015 Trd sport
    After looking at the pictures of my bumper I've decided I need a much wider stance. What all are my options?
  6. Jul 17, 2015 at 8:47 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Well this is what I would do since you have it all off the truck again I'm assuming. If not still do this. Make sure the lights work. Test each one individually and make sure you didn't get some crap lights. It's happened.
    Next check your relay. Very easy to do just like you have it. Flip your switch if it's still connected. You should hear the relay click. If no clicky not worky. If you don't have it hooked up to a switch just very quickly touch that wire to the battery and you'll hear a click. Don't hold it there you might burn it up. Just a quick twitch and done. If no clicky no worky. You following me slick?
    Ok if you hear the click on the relay via switch then your switch is working, and your relay is working And the lights passed your test , You have a bad ground on the actual lights.
    If no click with the switch but you hear it on the battery then your switch is shit.
    If no click on battery then bad relay.
    Wiring shouldn't be as complicated as you've made this.
  7. Jul 17, 2015 at 8:48 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Wait what the led is on when the lights are off and goes off when the lights are switched on?
  8. Jul 17, 2015 at 8:50 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    That sounds like you switched the wires for the switch. You have a hot wire running to your ground and vice versa.
  9. Jul 17, 2015 at 8:51 PM
    Skootter14
    Jeremy
    good point. I just checked the fuse and it was good to go (I visual inspected it way before now, and it looked good so I didnt check it earlier)
  10. Jul 17, 2015 at 9:00 PM
    Skootter14
    Jeremy
    OK, I had the lights/relay hooked up and everything worked. And yes, the LED went off when I flipped the light switch on, and vice versa. but even then, we tried hooking up a NEG jumper and that didnt fix it, we then tried a POS jumper and that didnt fix it, so I said fuck it and the LED will be on 24/7 unless the lights were on (now that I have everything unwired, I do not want to make that same mistake, whatever mistake that was).
    And I wanted to show you all the picture because you're right, this shouldnt be that hard and I'm not a complete idiot (contrary to popular belief :crazy: ) This should have worked in my mind, which is why I am hoping I narrowed this down to a bad ground on the switch.
  11. Jul 17, 2015 at 9:02 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    The led shouldn't be on 24/7 unless. You either have ground switched with a pod wire or you have the two pos wires switched on the switch. That's an easy fix.
  12. Jul 17, 2015 at 9:03 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    When you say everything worked do you mean lights worked and all or just relay and switch worked?
  13. Jul 17, 2015 at 9:03 PM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    Here is a quick sketch.
  14. Jul 17, 2015 at 9:04 PM
    Skootter14
    Jeremy
    my entire ditch light system worked. I took it all down to wire it all to the blue sea fuse panel and make things cleaner
  15. Jul 17, 2015 at 9:04 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    And then what happened
    At what point did something go screwy and what exactly happens
  16. Jul 17, 2015 at 9:06 PM
    Skootter14
    Jeremy
    When I went to rewire everything from scratch last weekend. I hooked everything up and when the moment of truth came to flip the switch in the cab.....nothing haha
  17. Jul 17, 2015 at 9:07 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    And that's when the led went screwy? On the switch ?
  18. Jul 17, 2015 at 9:07 PM
    Skootter14
    Jeremy
    negatron, the led on the switch has been screwy since day one.....like 4 months ago haha
  19. Jul 17, 2015 at 9:09 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Fuck dude idk I'm going to sleep I'll read over this tomorrow and call me after you've seen me post something. I pmd you my number.
  20. Jul 17, 2015 at 9:14 PM
    Skootter14
    Jeremy
    I might have found the problem in the sketch...im thinking for a sec
